Section Image
Just useless info for most
Submitted: Monday, Oct 04, 2004 at 21:11
Voxson (Adelaide)
When buying hi-lift springs..... The least amount of coils handle the weight better... EG:::::::I bought 4" springs which had 8 coils and the rear would sag quite a bit when laden with weight.... But then i had a set made to order which were also 4" but had them set with 7 coils (same diameter) and the sag was hardly an issue and ride was not even noticably harsher.....
If you dont mount your ARB compressor with rubber pads in your engine bay it will one day loosen the tank and blow the o'ring out when you really need it... Easy fix with a 13mm socket but just a pain in the arse....
ThreadID: 16786 Replies: 1
Views: 569 FollowUps: 1
AnswerID: 78830   Submitted: Monday, Oct 04, 2004 at 21:44
Ian from Thermoguard Instruments replied:
Hi Voxson,
It's because a coil spring is really a 'rolled-up' torsion bar - a length of spring steel bar that is twisted as the suspension compresses. An 8 coil spring of the same diameter and grade of spring steel as a 7 coil one is a longer length of 'torsion bar'. So, the same twisting force (vehicle weight) twists the longer bar to a greater degree.
I'm no spring guru but I believe the critical factors are the free length of the coil and it's 'rate' - the force needed to to compress it each unit of length - lbf/inch or N/m?? The rate is a function of the overall length of the steel bar (no. of coils and spring diameter) and the thickness of the spring steel (bar diameter) - and presumably some combinations of bar dia. and no. of coils work better than others. That's what we pay the 'spring gurus (gurii?)' to work out.
Thermoguard InstrumentsThermoguard Instruments
Business Member: My Profile  Send Message
Reply 1 of 1
FollowupID: 338352   Submitted: Tuesday, Oct 05, 2004 at 14:03
Voxson (Adelaide) posted:
Yes.. But it craps me no end when a 4x4 shop raves about a certain spring and you put it in and then find it to be saggy... I was almost thinking about poly airs when i decided to use the newer remade spring which hardly even feels the weight of 220kgs of fuel and a trailer full of garden pebbles..
Activities Index
WRX Turbo Rally Extreme 16 laps + 1 hot lap-Sydney WRX Turbo Rally Extreme 16 laps + 1 hot lap-S
Sydney - NSW
Rally driving - you've seen it on TV, so stop thinking about it and do it!
Beginner Wet Canyon - Katoomba Beginner Wet Canyon - Katoomba
Blue Mountains - NSW
This is the best Blue Mountains' introductory canyoning experience, water jumps, swimming and "
2 Day Phillip Island and Wilsons Promontory Tour 2 Day Phillip Island and Wilsons Promontory T
Melbourne - VIC
Come and discover the diversity and abundance of native wildlife on the Phillip Island and Wilsons P
Two Car Rally Blast - QLD Two Car Rally Blast - QLD
Brisbane - QLD
Are you ready for a real rush?
Mother Mother's Day Lunch on Sydney Harbour
Sydney - NSW
If you're looking for a special gift for your mum, then look no further.
2 lessons in 1 Day Surf Package in Noosa 2 lessons in 1 Day Surf Package in Noosa
Sunshine Coast - QLD
Learn how to surf at Noosa's premier surf school in a safe supportive environment on limited time.
Hot Stone Massage & Facial - 2 Hours Hot Stone Massage & Facial - 2 Hours
Sydney - NSW
Experience a hot stone massage therapy and feel completely relaxed in your mind, body and spirit.
Pure Pampering Pure Pampering
Sydney - NSW
Treat yourself to some pampering that will leave you feeling refreshed and rejuvenated!
Adrenalin Rush - 6 WRX STi  YOU DRIVE Adrenalin Rush - 6 WRX STi YOU DRIVE
Gold Coast - QLD
Serious sideways action! YOU DRIVE for 6 exhilarating laps of the circuit.
Fly Fishing Full Day for 2 Fly Fishing Full Day for 2
Jindabyne and Snowy Mountains - NSW
Fly Fishing is a great way to fish and there is nothing more relaxing than standing in a stream cast
Book Now - Things To Do
