air jack
Submitted: Monday, Oct 04, 2004 at 21:55
ThreadID: 16790 Views:1801 Replies:2 FollowUps:0
hi i have a 98 hilux traytop and i have just got a air jack for it. i was just woundering where other people position the jack. is the best place at the back, under the spare wheel?
thankyou for any feedback.
Reply By: cokeaddict - Monday, Oct 04, 2004 at 23:22
I am not sure if you are refering to the exhaust jack.
If you are, then it really depends on the situation you are in at the time you need to use it. Sometimes you cant place it where you would prefer it to go. I have used mine in many different places. The most important thing for me is making sure it is well protected from sharp objects. I do this by using sacks both above it and below it. I usually carry 4 and in one instance my only option was to place the bag under some sharp points. The sacks folded to thicken the distance between the sharp objects and the bag were enought to stop it from popping.
They are a fantastic tool. I even use it when i do a tyre rotation at home.
Hope this helps.
Cheers Angelo
AnswerID: 78850
Reply By: Member Eric - Tuesday, Oct 05, 2004 at 19:46
The best possition for a air jack is in the rubish bin . Personaly . I have found it to be the most uslless tool ever invented . In sayin this , we have only tried using them on mud tracks. Some poeple who have used them in sand , say they work ok . make sure you cary 2 pieces of carpet with you . This will prolong the bags life .
AnswerID: 78963
