overheating troopy
Submitted: Tuesday, Oct 05, 2004 at 21:12
ThreadID: 16821 Views:4630 Replies:14 FollowUps:2
Hi all.
I was womdering if any body could offer any advice as iam fast running out of ideas.
I have a 91 model troopy with an after market turbo bolted on. my problem is that when i pull up hills or put a mild load on my rig the temperature soars from around a quarter up to more like three quarters which i think is far to much.
Ive had the radiator overhauled,replaced the fan which was free wheeling when it got hot,replaced the themostat,even changed the temperature sensor but had no luck.
Ive been told that the injectors may be burning to much fuel under load which may be causing it but the others tell me it has nothing to do with it.
Our next stop is the water pump but have been told it very unlikely also.
I desperately need ideas, the troop only has 200k on the clock and besides this problem she runs great and everything is ship shape.
Any advice would be greatl appreciated.
thanks
Reply By: Moz - Tuesday, Oct 05, 2004 at 21:26
G'day Kriso,
I'm assuming you have 2H diesel.
Check your bottom radiator hose, it can deteriorate and collapse
under load blocking coolant flow.
Then when you back off the throttle the hose returns to shape
and the temp returns to normal fairly quickly.
Hope this helps,
Moz
AnswerID: 78981
Reply By: Vinnie - Tuesday, Oct 05, 2004 at 22:27
kriso21
Try setting up a couple of theromstatic fans on the front of the radiator. Do you have air-cond? If so these would be very helpful.
I have a 4.2 diesel Maverick, disconnected the fan and set up twin 16" thermo's that cut in at 165deg. I have found a few more horses and no overheating when towing the camp trailer or bigger loads. A big plus is while in the bush, driving around in low range and up-hill work the engine stays at a normal temp all the time even on 35+ days.
Vince
AnswerID: 79006
Reply By: Matt M - Tuesday, Oct 05, 2004 at 22:45
Kriso, overfueling under load will very quickly cause the temp to rise.
Do you have large clouds of smoke when you accelerate? First sign of overfueling and a good Dyno tune in need!
Goodluck, overheating can be very frustrating!!
Matt.
AnswerID: 79009
Reply By: Member Eric - Tuesday, Oct 05, 2004 at 23:16
Gee Kriso . you have just pointed out exactly the problem I am having in my cruiser for the last couple of years . I have done all you have done and still there is a problem . I am about to remove the waterpump to check the impela . Also , how long since you did your radiator . I did mine in Jan , and car was fine till now . I did blow a headgasket not long ago , by dring the car way to hard up a hill . I am under the impretion that the heat could have caused flakes to come off the block , and inturn block my radiator again . I didnt mention that its now the second time that I did my radiator . Both times it had blocked up to 30 % . If the block isnt flushed properly , it will keep blocking the radiatir . I am looking for a aditive now to run in my cooling system to clean the block before sending out the radiator one more time . I also have been told to run genuine toyota cooland , I also have been told this is not the way to go . I am still resurching this for now . Lets keep in touch and see who comes up with a answer first
AnswerID: 79015
Follow Up By: Peter - Wednesday, Oct 06, 2004 at 02:01
eric,
i would suggest you get your radiator manually cleaned if you havent already. the chemical flushes are a waste of time. a mate had it done a few years ago and a few weeks after it was done he was overheating really badly under load. we took it to a place that pulled the radiator apart and put these metal probes down the full length of the radiator that cleaned out so much gunk it wasnt funny. they then flushed the block using a fire hydrant that was on the factory wall. they had made an attachment that fitted it to the block. when they turned that hydrant on the water pressure flushed out so much rust and gunk i reckon the block had just had a jenny craig special weight lose. after that the engine ran so well you wouldnt have known we were travelling through the NT with 35 degree days, fully loaded up and towing a boat as the temperature gauge bearly moved.
so anyway a manual clean of the radiator and high powered water flush is the way to go. if a car radiator place cant do it try a truck radiator place.
good luck
peter
FollowupID: 338436
Follow Up By: Member Eric - Wednesday, Oct 06, 2004 at 08:06
I was thinking of running the cemical just to dislodge the crap in the block before the flush ,
cheera
FollowupID: 338450
Reply By: awill4x4 - Tuesday, Oct 05, 2004 at 23:28
Kriso, I know you said that you had changed the fan but did you also change the viscous coupling as well?
Regards Andrew
AnswerID: 79016
Reply By: Yeah Mate - Wednesday, Oct 06, 2004 at 04:39
kriso21,
If you have A/C check your condenser, it may be blocked up with bugs etc preventing good air flow through your radiator.
AnswerID: 79023
Reply By: CHRIS - Wednesday, Oct 06, 2004 at 11:17
Is the engine a 2H and are you running a oil cooler. If so post a reply and I may be able to help you as I have been down this road before. The 2H can be very susceptable to overheating when Turboing.
AnswerID: 79057
Reply By: Ian from Thermoguard Instruments - Wednesday, Oct 06, 2004 at 11:48
Hi Kriso,
Lots of good advice so far. To what extent was your radiator 'overhauled'? As mentioned, chemical flushes are of limit usefulness. Removing the tanks and 'rodding out' is the way to go. But as also mentioned, it's no good having clean water passages if the core doesn't have good airflow through it. If the fins are badly crushed by many years a kamikazi bugs or if they are simply corroding away, then it's new core (or new radiator) time. Same goes for air-con condenser, oil cooler or anything esle that's out in front of the radiator - all must be clean and free-flowing for good air flow.
Overfueling to the extend that the coolant temp rises so quickly would likey be accompanied by serious black smoke. But, if you do suspect this, get it seen to quick smart, 'cause it'll be doing your turbo-charger not good at all...
AnswerID: 79059
Reply By: Dave from Fraser Coast 4WD Club - Wednesday, Oct 06, 2004 at 15:56
we put an oil temp guage on ours and it never got past normal, even when the troopy was running hot, so an oil coller was not going to be of help.
Instead, we used a big oil cooler to cool the coolant coming out of the Turbo. The cooler is mounted inside the pass side wheel arch, and makes a huge difference.
I'll provide more details and pics if you like!
Still not perfect but I have come to live with the fact that the temp guage is very responsive, and that the area between cold and hot is called normal!!!.
Invest in a coolant level alarm for peace of mind!
AnswerID: 79088
Reply By: Member - Chris (SA) - Wednesday, Oct 06, 2004 at 15:58
I have a '96 troopy with normal 1HZ donk. Had the same problem and found that it was caused by a combination of radiator, thermostat and loss of fluid in the fan.
Replaced the radiator with a new one, had the fan refilled with fluid and replaced the thermostat. the temp gauge is not where it is supposed to be under any load and speed - on and off road. I'd already changed the hoses so didn't do it. I regularly tow a heavy off road trailer with no problems.
good luck
chris
Admittedly it cost around $700, but the unit runs real well now.
AnswerID: 79090
Reply By: Peter 2 - Wednesday, Oct 06, 2004 at 21:05
70 series troopies have always had probs with underbonnet airflow and temp due to the shape of the body and the way it deflects the air when travelling down the road.
Yours being a 91 model will have a 1HZ which are not as bad as the 2H in the earlier pre 90 models.
As has been previously stated check radiator first, then the thermo coupling on the fan, even new the couplings give probs, you can buy the silicone fluid from your toyota dealer to add to it to get it to lock up sooner.
anything you have in front of the radiator/grille will restrict airflow so remove if possible (driving lights, bugscreens etc), make sure all the rubber flaps/foam are in situ between the a/c condensor, rad & body as these ensure the air flows through not around the rad. Make sure the shroud on the back is fitted correctly again it prevents the fan sucking air from the sides.
By adding the turbo you are creating additional heat which has to be dissappated by a cooling system which is already at max for hot weather/climates so it has to be 110% to do the job.
Fitting thermo fans is not a solution and would create additional probs.
I always ran the toyota red fluid in the cooling sytem too. I've had several troopies and as long as everything is working ok it should be able to cope.
My money is on the thermo coupling being the culprit.
A cheats way of testing is to get a length of rubber hose (10 mm vaccuum hose from an auto parts place is ideal) a metre or so and wrap it tightly between the front of the water pump and the back of the thermo coupling, where the 4 nuts are that hold the fan to the pump.This will jam the fan on and you can go for a fang and see if it runs hot.
don't use reinforced hose as you may have to cut it off if it jams tightly, also the vac hose is soft enough to be cut by the fan if it comes off.
AnswerID: 79119
Reply By: Member - 'Lucy' - Thursday, Oct 07, 2004 at 00:10
Kriso - email me at krobbo@optusnet.com.au and I'll give you R&D feedback of a similar, if not identical, mod that I have done to my Troopy over the past 2-3 years with (so far) 100% success.
AnswerID: 79156
Reply By: Gypsymum - Thursday, Oct 07, 2004 at 10:06
Hi there
I don't know if this will help as you have a diesel and I have a petrol but if you read PostID: 16848 that I sent to Eric that might be an option for you. The hubby and I were having probs with our 80 series overheating on hills and under load and after a new rad and all the other things you can replace someone told us about a landcruiser prob. Not enough silicon oil in the viscous coupling fan. They come off the factory floor low on oil (guy from Toyota actually admitted the fact). I hope that is your prob cos it is pretty easy and inexpensive to fix.
Sasha
AnswerID: 79192
Reply By: kriso21 - Thursday, Oct 07, 2004 at 10:23
Hi Eveyrone,
We really appreciate the feedback you have all given us. but everything that has been said we have pretty much tried and sill nothing. We have been speaking to a friend of ours who is in the Landcruiser Club and he seems to thing that it has something to do with the aftermarket Turbo (Denco). We called Denco and they were no help what so ever. So tomorrow its off to the Turbo place in Wollongong (is this a good place?) and hofefully it is something very simple. Any one have any information on Aftermarket Turbos? Denco Turbos.
The worst thing is we were planning a trip for the next two weeks with new Camper Trailer we pick up today so we'll have to put that off to the Troopy is fixed.
thanks again and any more feed back will be greatly appreciated.
AnswerID: 79196
