TYRES - STAKED SIDEWALLS
Submitted: Wednesday, Oct 06, 2004 at 02:21
ThreadID: 16828 Views:6953 Replies:16 FollowUps:31
Hi all ,
After staking two sidewalls in 15 minutes in the Little Sandy Desert in August ,I was wondering if anyone had any ideas about how to protect the sidewalls and stop this sort of damage .
I purchased 10 ply Cooper tyres and in my ignorance thought that they would be less susceptable to sidewall damage . But the 10 ply is only in the tread and the sidewalls are just as weak as everybody else's radial tyres .
We had to make our own tracks through some of the spinifex country and it just was not possible to see all the little burnt spikes left after bush fires had burnt out the area . So eventually I was going to get unlucky and drive one of these nicely fire hardened little mongrels through my bulging exposed (20 psi) sidewalls .
Has anybody put any thought into how this can be avoided.I have thought of getting
a set of four old tyres anlcanising extra sidewalls onto these and just using them in the desert . I also thought of modifying a set of chains to somehow protect the sidewalls . Has anybody got any brilliant ideas . Even if they sound crazy now , it might give somebody the spark to develop something .
Please don't email me and tell me that I should just be more careful and keep a better look out for obstacles - I am after positive input even though it might be highly fanciful .
Thanks ,
Willie
Reply By: Well 55 - Wednesday, Oct 06, 2004 at 07:16
Maybe look at the size of the rims, a wider rim will lessen the exposed part of the side wall. Or go back to split rims for desert trips where you may encounter this type of problem.
AnswerID: 79027
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 08:13
Well 55 ,
That's a good point about the width of the rims . Split rims are not available for the Toyo 100 TD - they would have to be specially made and would not be cheap . Changing and repairing the tyres is not the problem though - stopping the damage is what I want to do .
Thanks ,
Willie
FollowupID: 338452
Follow Up By: Member - John (Vic) - Wednesday, Oct 06, 2004 at 14:27
Willie Splits are avaliable for your truck.
They are the same wheel as on the 78 series troopy.
FollowupID: 338509
Follow Up By: Member - DOZER- Wednesday, Oct 06, 2004 at 21:43
Hi The r/v 100 had splitties too, but i believe the offset on the t/d is deaper and the splittie will possibly stick out past the guard.
Way round this is tyre plyers, and 16x6 or 7 ROH rim to suit cheese slice tyre.
Also, cross country in the desert would be a good place for a cross ply tyre, with inherantly stronger sidewall construction.
FollowupID: 338580
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 02:45
Dozerand John ,
Dozer , your right about the 100 TD offset not being the same as the 78 Series Troopy. I have looked right into it and the only way around the problem is to have the wheels custom made from a combo of split rims and 100TD rims welded together . But really , this does not solve the problem of staking the sidewalls and I have no problem with fixing the tyres without split rims anyway.
Maybe what we need is a cross ply tyre that will fit on the wider rims we now use . Is such a thing available anywhere ????????????
Thanks guys ,
Willie .
FollowupID: 338594
Follow Up By: Member - DOZER- Thursday, Oct 07, 2004 at 07:17
Gday
Mickey Tompson and Interco are two tyres that run crossplys for sidewall strength. In particular the M/T claw is a nice tyre for mud and rocks...but i think you will be worse off with these wider tyres as there is more rubber to puncture on the ground x 4. The tread pattern best suited for this purpose is highway tread with no or little siping between thread.
I dont think a split rim would be that dear to make if the std 100 split wouldnt do...have u tried one yet?? if not check out your local Toyota or tyre store for some disguarded ones to try on...because they are only 6 inches wide,(vs 8) they can afford to be 2 inches wider in offset and still sit under the guard.
Good luck
FollowupID: 338603
Reply By: Member Eric - Wednesday, Oct 06, 2004 at 08:11
In some cased , the side wall can be repaired . Then run them as your spare. At least they dont go to waste
AnswerID: 79033
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 08:29
Hi Eric ,
You guys are on line early . It's 6.15 pm here in Ottawa and pretty cool .
You should see the size of the 4wds cruising the streets here . I think I could put my cruiser on the tray . Most of them are four door with a "pick up" / ute section behind that . I saw one yesterday with dual wheels on the back .
I repaired one of my staked tyres with the help of friends and their gear . It was very helpful to have them there to teach me how to do it and I watched while another three staked tyres off the other cars were repaired during the trip . My other tyre was just totally buggered - there is not a patch made that would have fixed it .
We put a patch on the fixable one and put a tube into it . I have heard that putting a tube into a tubeless tyre voids your insurance , but I am not sure if this is or isn't an urban myth .
Im off for dinner now ,
Willie
FollowupID: 338454
Reply By: Nudenut - Wednesday, Oct 06, 2004 at 08:24
yeah...as someone has already said...i staked one thru the side a few yrs back....when i went to get another from tyre dealers in Pt Augusta all asked what pressure was i running....afetr 3 asked me the same i got one to test presure......50psi and tyres were only 2 weeks old?....too high they said. Picked up 2nd hand one to get me back home
when i got back to adeliade i took it round to tyre mart and queried them over presure and they came back with reply ....they can take 60 max!!!
not good enough i said and gave them the staked tyre.....they sent it off and back it came repaired....been on car for two n half yrs since and replaced last week as it was bald...well almost...no charge for tyre repair either
( tyre dealers up pt augusta said the tyre MAY have rolled over the sun hardend bit of salt bush if pressures were around 30-35)....but i know 50 psi was way too high
AnswerID: 79037
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 08:35
Hey Nudenut ,
There is an awful lot of bull bleep going around about tyres . It's pretty hard to cut through it and get to the facts .
Willie.
FollowupID: 338455
Follow Up By: Nudenut - Wednesday, Oct 06, 2004 at 09:08
I agree...
but the above was my personal experience
so is it right for everyone???
God only knows!!
FollowupID: 338462
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 12:27
Nudie ,
I was not suggesting your narrative was bull bleep , just the advice you were given . I have been given so much contradictory advice and info by people in tyre shops and 4wd shops that I do not know whether I am coming or going .
Willie
FollowupID: 338485
Follow Up By: Nudenut - Wednesday, Oct 06, 2004 at 18:03
willie....i knew what you meant..
FollowupID: 338542
Reply By: Flash - Wednesday, Oct 06, 2004 at 08:45
Between a rock and a hard place.....
LOW pressures will expose more sidewall to the obstacles you encounter. The tyre bulges out with a lot of sidewall exposed at the bottom. Likewise wider rims expose MORE sidewall and therefore are not a good idea.
HIGHER pressures on dirt will nearly always REDUCE the chances of tyre damage from rocks etc.- whether that would help with the "little burnt spikes is anyone's guess...
Radials have always been strong in the tread, weak in the sidewall- the old cross plies had much stronger sidewalls. There used to be radial tyres available which had stronger sidewalls- don't know if there's still such tyres???
Good luck Willie
AnswerID: 79038
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 08:54
Hi Flash,
I thought a wider rim would give you more rubber / larger footprint and so less need to lower the tyre pressures and expose those bulging sidewalls to the dreaded sticks .
If there is a radial with a stronger sidewall , I would like to hear about it .
Thanks ,
Willie
FollowupID: 338458
Follow Up By: A Digger - Wednesday, Oct 06, 2004 at 09:22
Flash,,
I can't see how the width of a rim has got anything to do with the amount of sidewall. The profile of the tyre, in combination with the tyre width, will determine the amount of sidewall there is.
For example a 285/75/16 tyre will have almost the same height of sidewall (213.75mm) as a 305/70/16 (213.5mm) yet the 305 is 20mm wider.
And there has been heaps written on this forum about the best way to reduce tyre damage on dirt/rocks and that is by reducing pressures and speed, and that has certainly been my experience. I note also on another thread that you had advocated higher pressures on dirt to reduce tyre damage which would be contrary to the usual line of thinking/experience.
Just trying to work out how you have come to the conclusions above. Thanks.
Digger
FollowupID: 338466
Follow Up By: Flash - Sunday, Oct 17, 2004 at 11:44
There are no rules cast in stone, Digger, and as I said tyres getting staked is a tricky one.
However, 1. wider rims will expose more side wall than narrower on the SAME tyre.
Lower pressures expose much more sidewall. Try pumping your tyre up to say 55psi then look at them end on from road level.
Then lower to say 20 and have another look from road level- there is a huge difference in amount of exposed sidewall.
Whether that amount of exposed sidewall is more or less likely to get staked is dependent on many factors.
Obviously most people lower pressures to get a better ride- but this usually comes at the cost of more chance of sidewall damage- but it depends on what is actually causing that sidewall damage... ie: the surface.
I hate to say it, but you're "between a rock and a hard place".
Good Luck- I'd go and have a talk to as many different tyre manufacturers as possible looking for stronger sidewalls- and seriously consider different tyres from those you normally use before heading out that way again. (As I'm sure you're aware many people have died because of tyre failure)
FollowupID: 339827
Follow Up By: A Digger - Monday, Oct 18, 2004 at 11:12
Flash,
Maybe I didn't explain it, or ask the question, properly.........
"However, 1. wider rims will expose more side wall than narrower on the SAME tyre. "
I can't see how this could be. How do you come to this conclusion/statement?
And yes lower pressure will naturally expose more sidewall.
Digger
FollowupID: 339918
Reply By: craig - Wednesday, Oct 06, 2004 at 09:01
Hi Willie this might be a real long shot but a long long time ago I saw a tv show (I think it was towards 2000) maybe , anyway they were testing these strange rubber tyre things on a land crusier going over sand dunes and driving over nails and spikes , they are kind of hard to explain but they looked like an old wagon wheel but made from steel with thick half loops of rubber running around the outside for the tyre ?? strange I know but they could drive over any kind of spike and no prob as there was no air in them and they were still kind of light as there was no side wall at all. they were testing them for cars that work in mines .
yes not ver practical for on road but no more punctures.
AnswerID: 79041
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 09:07
Hi Craig,
That is the sort of thing I am interested in hearing about . We have to think laterally and come up with some solution no matter how crazy .
I am sure there must be some way of adding bits to a set of chains to protect the sidewall . BUT , will chains be any good on the sand or will they dig down into the sand ?
So many questions !!!!!
Thanks ,
Willie .
FollowupID: 338460
Reply By: ev700 - Wednesday, Oct 06, 2004 at 10:22
If there is a solution, the military probably has investigated it. Any present or ex-military transport drivers on line?
The only alternative I can think of is to have the much thicker side walls that the old cross plys had. These did not bulge much. Commercial tyres. But that may not go well with sand.
AnswerID: 79053
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 12:41
ev700,
That is a good point , I wonder what they use on their Landrovers . Probably cross ply as you suggested as they would be much less interested in performance on the blacktop than we are .I am not sure how those thinner tyres would go on a sand dune - not too well I would guess .
I think what we need is a gadget that can be added to the tyre when you get to an area and take it off again after you get back to a track .
Thanks ,
Willie
FollowupID: 338487
Reply By: Nebster - Wednesday, Oct 06, 2004 at 10:32
Heres one,
Mount a dozer blade to the front of your rig, that way it will do the track so that when we come through it wont damage our tyres either. ;)
Just a thought...
Oh well got to go and have another sedative
AnswerID: 79056
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 12:48
Hi Nebster ,
I actually heard of a design used by some gents contracting to get surface mineral samples as preliminary work for mining companies .
They had a 4 or 6 wheel drive truck and had two arms going out the front with a bar across to take out surface obstacles such as these small stumps .
I don't think our enviro friendly mining companies would use such a device nowdays .
Regards ,
Willie
FollowupID: 338488
Reply By: GeoffSA - Wednesday, Oct 06, 2004 at 11:31
Best advice is to stay on designated tracks instead of cross country driving to make new ones.
This is what gives 4wdrivers a bad name.
Unless of course, you had a legitimate reason for going off the designated tracks.
AnswerID: 79058
Follow Up By: Member - Willie Sydney - Wednesday, Oct 06, 2004 at 12:24
Geoff,
Thank you for enriching this discussion with such great advice .What would we do without people like you .
Willie .
FollowupID: 338484
Reply By: Wok - Wednesday, Oct 06, 2004 at 12:50
How about a Kevlar cover/sock?....they can be bullet-proof
AnswerID: 79066
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 02:54
Hi Wok ,
That is a great idea . I am not sure if kevlar would be tough enough to do the trick but who knows . Perhaps a sock / cover made from woven micro fibres such as produced for use in braided fishing line ( and the new braided winching ropes ) might be tough enough .
That idea has real possibilities Wok - you are a genius .
Thanks ,
Willie .
FollowupID: 338595
Follow Up By: Mad Dog (Victoria) - Sunday, Oct 17, 2004 at 21:59
How about thats small link chain material used in shark proof suits. Tough enough to stop a shark having us for dinner.
FollowupID: 339876
Reply By: Moose - Wednesday, Oct 06, 2004 at 13:58
Willie - have done the same thing. 2 tyres in about 5 minutes and I was only on forestry tracks - just bad luck with bloody sharp objects. So I can sympathise. But back to your question there's a guy from WA who's on this site now and then who does heaps of off the beaten track driving as part of his work. Buggered if I can recall his name. Anyway he swears by rag (cross ply) tyres. But I guess you then have to live with their other issues for the long bitumen stretches in between the real stuff!
AnswerID: 79077
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 03:00
Hi Moose ,
If they made cross ply tyres wide enough to give you good sand performance I would definitely get a set to put on before I went on my trips .
Do you know if they are available , or if they only come in sizes for narrow rims ?
Thanks ,
Willie .
FollowupID: 338596
Reply By: T-bone - Wednesday, Oct 06, 2004 at 14:46
I don't know if you can get them for cars/fourbies, but there's a run flat-type tyre for off-road motorbikes. It consists of a high density foam inner core that is mounted inside the tyre around the rim. When the tyre is inflated, the foam is far enough away from the tyre so that there is an air-space between the two, and the tyre operates as per normal. When deflated, the tyre rests on the inner foam core, thus keeping the shape of the tyre and allowing you to run along at a reduced speed. Obviously, there are some drawbacks (harsh ride when deflated, reduced speed in the event of a puncture, less bagging-out of the tyre when dropping pressures for sand driving, etc), but in emergency situations it could ge a godsend. I bet that lady who got herslef stuck out on the WA coast with 5 flat tyres on her RAV4 would have loved to have this system....
AnswerID: 79082
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 03:06
Hi T-Bone ,
That would be a good idea for emergencies .
I was thinking of getting four wheels and tyres and filling the tyres with a flexible foam that set like EVA , so if a sidewall was staked , nothing would flow out , but the tyre would still have some flexibility .
You could not drive on a public road with them , but they would be great for exploring the Great Sandy Desert !!
Thanks ,
Mike
FollowupID: 338597
Reply By: pjd - Wednesday, Oct 06, 2004 at 19:34
get a set of motorway monoform tyres they have several tread patterns & a monoform tyre is a new tyre moulded from bead to bead so the tyre wall is almost twice as thick .not fool proof but alot better than a standard tyre & about 1/2 the price
AnswerID: 79112
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 03:10
Hi pjd ,
That sounds good . Do you have any info on these tyres ? Are they street legal , are they made for cars or only for quads etc and do you know any manufacturers whose website I could visit ?
Thanks ,
Willie .
FollowupID: 338598
Follow Up By: pjd - Thursday, Oct 07, 2004 at 20:49
willie they are all street legal there web site is www.motorway-tyres.com.au
phone no is 1800 036 016 or 5358 8000 they are made in stawell vic but have dealers everywhere. they have a tread pattern called mongrel which is close to a simex centirpede its a very agresive pattern & @ $170 compared to $380 it is good value
FollowupID: 338695
Reply By: Crackles - Wednesday, Oct 06, 2004 at 21:09
Speaking to an outback WA tyre dealer who recomended a 12 ply Olympic Highmiler (from memory) as a good cross country tyre. Basically for light trucks. With a closed tread pattern it resisted staking very well & has a tough sidewall.
A mining exploration crew we spoke to were getting up to 15 flats per day so sourced a solid tyre with a soft core. (No more flats) Only rated for slow speeds but they ran a standard set when back on the tar. Sorry that was 10 year ago so don't know the name of them .
For a thick side wall on a commonly available trye you can't go past an MTR.
Cheers Craig.............
AnswerID: 79120
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 03:16
Craig ,
I will check out the sidewalls on those 12 ply Olympic tyres .
What is an MTR ?
I will try to find out more about the solid core tyres you speak of and will make a post if I get any good info .
Thanks ,
Willie .
FollowupID: 338599
Reply By: V8Diesel - Wednesday, Oct 06, 2004 at 21:19
Willie, I was a field manager for mineral exploration crews (up to 6 landcruisers at a time) running in spinifex country in the northern goldfields of WA. The only way to go was to use crossply tyres on split rims and carry lots of spares (tubes, patches, tyres etc).
Anyone rolling up to a job with radials (especially road grippers) would be turned around and sent back home as it was a total waste of everyones time. The Hi-Milers handle like s@%t, chip on rocks and certainly still stake, but they last way longer than anything else. My record was 10 flats in one day in the old timber line areas north of Menzies.
There may be a better option for tyres these days, but 10 years ago crossply was the only way to go. My advice to you, is to completely ignore all advice - unless it comes from someone who actually currently earns their livng 4WD'ing in the area you want to traverse on a daily basis. Handling and grip is purely academic if your are sitting on four flat and irreperable tyres in the middle of nowhere.
Also, we used to take our radiators out every night if necessary to blow them out. Doesn't matter what you put in front of them, seeds will get in. Get rid of your airconditioner and wing mirrors too for spinifex and bush bashing.
This is probably an extreme example, but we worked on the theory that it was cheaper to trash Landcruisers than hire six helicopters with pilots. And no, we could not stick to tracks as there weren't any.
Hope this helps.
AnswerID: 79123
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 03:50
V8 Diesel,
YES ! that is the sort of country I am talking about . I can agree with all that you have said BUT , what are those thin cross ply tyres like at negotiating sand dunes ??
Maybe as you say, I should ask the exploration crews from the Nifty , Woodie Woodie and Telfa mines what they are using now . They would have to have the latest equipment .
We used shade cloth over our radiators and also had it hanging off the bumper bars so that it was actually running underneath the car . This got cut up fairly quickly , but it did help keep the seeds out .The spinifex seeds were so compressed between the protection plates and the engine that it was as hard as wood.No wonder they cause fires in hot weather when they get jammed up against the exhaust .
All the rain in the last few years has made the desert bloom and it is especially hard now to see those little clumps of burnt out stakes that did most of the damage to our tyres on the last trip .
I would love to have a job like you had out in that area .
Thanks ,
Willie .
FollowupID: 338600
Follow Up By: V8Diesel - Thursday, Oct 07, 2004 at 09:48
Willie, we used to get over dunes reasonably well with them let down. They are far from ideal, but better than flats. The tyre patches are essential as well as tube patches.
I'd say you are right on the money with those crews listed. Make sure it is an actual 'exploration' crew you speak to. Some 'exploration' drilling crew use Toyota's are for running gear back and forward to rigs on cleared tracks. The ones you want are the vehicles that'll have 2 to 4 spare wheels, 44's of juice, scrub bars, no mirrors etc. They stand out.
I saw an interesting set of tyres on an Ausdrill Landcruiser at Meeka a while back. Michelin's from memory.
We used to put plates under the radiator, thick steel meshover the whole front, then finer mesh. Behind that we'd put green shade cloth. We had stakes through the back, front and side of radiators.
Watch out for fuel lines too. They tear out very easily on Landcruisers. If you have an external GPS aerial, put it at the back of the bonnet just in front of the windscreen where you can see it all the time. Anywhere else, and it won't be there when you stop. Also carry spare wheel studs, they are made of cheese. BTW Curry powder makes anything edible if you get stuck for an extended period of time. Baby Goat is best.
FollowupID: 338625
Reply By: Coops (Pilbara) - Wednesday, Oct 06, 2004 at 21:59
there is only one option I'm afraid Willie and that is to stay on the tracks and off the burnt out sections. It's a common problem and this truly is the only answer.
I've opted for Goodyear Wrangler MTR's which have a sidewall thickness of 16mm as opposed to the 12mm of the competition. Haven't staked 'em yet other than a particularly nasty trek along the old Callawa Track in Great Sandy Desert but still staked them (as did everyone in the group).
You don't need chains in the desert and I'm sure you wouldn't really use 'em anyway.
AnswerID: 79131
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 04:02
Hi Coops,
I don't like your one option I'm afraid . I need to go fossicking , also to get off the track to camp out of sight of the track and also to go and look at different and interesting landforms in the desert .
These things cannot be done without leaving the track sometimes . I do not go roaring off over the sand dunes for fun , but sometimes it is necessary . I see so many people flying up and down the CSR without stopping to go out and enjoy the incredible sites along the way , but I am and not like that - I am a plodder who likes to explore all he sees.
I dont need chains in the desert , but if somebody developed a sidewall protection device that could be attached to a set of chains , then I would use them . My only doubt about this idea is whether the chains might dig the tyre in . Do you know what chains do over sand ?
Thanks ,
Willie
FollowupID: 338601
Follow Up By: Magnus - Thursday, Oct 07, 2004 at 13:37
Willie,
I have seen pneumatic tyres fully enclosed in chains in the slag removal area of a steel mill. We are talking BIG bits of machinery here, but principle is the same. Was to stop punctures from the slag that had solidified.
Worked a treat.
So, someone has thought this out and come up with a solution. All you need to do, is organise a trip to a steel mill and get into the Blast Furnace area and take a look. Then downsize.!!
Magnus
FollowupID: 338655
Reply By: Phil G - Wednesday, Oct 06, 2004 at 22:03
Hi Willie,
I lead a lot of club trips into desert country, and happily say that we very rarely get punctures. My suggestions:
#1 Run low pressures - allows the tyre to "give" instead of being staked. I use 24psi on any dirt road and 18-20psi in desert country.
#2 Keep weight to a minimum
#3 Don't speed on outback roads
#4 Goodyear MTR have the best sidewalls and puncture resistance of any radial tyre. My own opinion is that Coopers are a good tyre but sidewalls are a bit thin.
Now if you stake a tyre, then do a simple plug repair with it still on the vehicle. Just put air back in, find the leak and follow the kits instructions - you may need several plugs. Once plugged, these tyres rarely leak - get it formally repaired when back in civilisation. I personally would only put a tube into a tubeless tyre if its an emergency.
After running split rims for 15 years, and having gone tubeless for the past 9 years, I am now a strong tubeless convert. They give much less trouble, wear better and are safer when punctured because of gradual deflation. They are also much easier to repair because you can simply plug them.
AnswerID: 79132
Follow Up By: Member - Willie Sydney - Thursday, Oct 07, 2004 at 04:16
Hi Phil ,
Thanks for the tips . They all make sense to me .But even doing what you suggest , I still staked two tyres . I will look at those Goodyear tyres though ,as Coops also recommended them .
I am not sure that I could have plugged the tubless Cooper , as I could stick my fingers through the holes . How big a hole can you plug ??
I agree that to plug a tubless tyre without taking it off the car is a great alternative to stuffing a tube in . In both my cases of "staking" we thought that the holes were to big to plug and in fact one was so bad it was too big to patch and put a tube into - and that was done by a small cluster of stakes from a burnt bush that would have been no more than 1.5 cm in diameter each stake .
I envy you your many trips into the desert - it is a beautiful place .
Thanks ,
Willie .
FollowupID: 338602
Follow Up By: Phil G - Thursday, Oct 07, 2004 at 19:53
Hi Willie,
Theres an element of bad luck in punctures and I'm guessing you had your fair share :-)
I used the MTRs on the Madigan Line, where 10 days of cross country travel is a fair test, and I didn't have any punctures.
You'd be surprised at what can be plugged. I'd suggest that its suitable for all holes that are less than your middlefinger in size. Usually need 2 or 3 plugs in holes that size, and I'd guess that the tyre glue type (and not the lubricant type) is better. Anything bigger and I'd take the tyre off and fit a radial patch, and keep the tyre tubeless. The other trick in the bush is to glue the split or hole with Locktite 406 superglue before applying a radial patch from the inside. Of course, these techniques keep you rolling in the bush and should be properly fixed back in civilisation.
FollowupID: 338691
