Paintwork
Submitted: Thursday, Oct 07, 2004 at 12:05
DiesAl
Some P#$%k has drawn on the bonnet of the hilux with Red Nikko (marker) pen while it was down at the shopping center.....
Does anyone know how to remove it without damaging paintwork ? I was thinking a cut and polish but not sure how deep the pen may have penetrated the paintwork.
Any assistance appreciated.
Al
Reply By: Truckster (Vic) - Thursday, Oct 07, 2004 at 12:23
Metho..
79208
Reply By: Baz (NSW) - Thursday, Oct 07, 2004 at 12:44
WD40 or tar & bug remover, doesn't hurt the paint.
79210
Follow Up By: Magnus - Thursday, Oct 07, 2004 at 13:22
Try going over it with a whiteboard marker. Works on whiteboards for removing permanent marking pens.
Magnus
338654
Follow Up By: DiesAl - Monday, Oct 11, 2004 at 10:24
Thanks magnus, I tried the whiteboard marker as I've seen this used on whiteboards at work, this worked fairly
well except there was still a faint mark on the paint work as
well as a slight red smudge after wiping off with the tissue, I then used meguires scratch remover which cleaned off the rest of the residue without cutting back the paint....Looks good as new. I re-posted at the end of the thread just for everyone's info.
Al
339053
Reply By: crfan - Thursday, Oct 07, 2004 at 13:21
SOLVIT Organic citrus clean from Coventrys
79213
Reply By: Member - Paul J (ACT) - Thursday, Oct 07, 2004 at 13:44
Try a rubber, or maybe some euclyptus oil.
79216
Follow Up By: Baz (NSW) - Thursday, Oct 07, 2004 at 13:51
Hey Paul, whats new.
338656
Follow Up By: Member - Paul J (ACT) - Thursday, Oct 07, 2004 at 13:58
G,day Baz, went up to Yamba for a funeral, would loved to of stayed there beutiful place, but work calls, in the middle of making my budget rear storage _Affordable_Storage_Drawers.aspx, plus very budget fridge slide, but it works. Heading
up to Maitland soon for a 21st, so im going to hit Stokton while im there, should be fun. I read your trip report, wished i could of made it, maybe
next time....
338657
Reply By: Anthony - Thursday, Oct 07, 2004 at 13:46
If all of the above suggestions don't work. A very slow but sure methond ... the UV light from the sun should fade away the red ink. I did say slow.... !!!
79217
Reply By: Rosco - Bris. - Thursday, Oct 07, 2004 at 14:24
Al
Magnus is on the money. Whiteboard marker will do the trick.
Make sure the bonnet is cool (in the shade) and apply liberally over a small area at a time, wiping off with a tissue while it's still wet .... you'll be amazed.
Works
well on any shiny surface.
79220
Reply By: Member Eric - Thursday, Oct 07, 2004 at 15:43
just give it a rub with utrafine , then some polish , will look new
79235
Reply By: ledastray - Thursday, Oct 07, 2004 at 22:22
Paul J have you found a good set of runners for you budget _Affordable_Storage_Drawers.aspx and fridge slide yet. i got on to some 100kg 800mm long double extension bearing runners for $88 a pair for hafele
79296
Follow Up By: Member - Paul J (ACT) - Friday, Oct 08, 2004 at 13:46
ledastray, when i say "Budget", i mean "Budget", the fridge is anchored to some ply, and it slides in and out of the housing with only angle holding it in place, the motor is in the back so most of the weight is still in the housing, works great, will have to do till i can rob a bank and buy a proper setup.
338798
Reply By: DiesAl - Monday, Oct 11, 2004 at 10:19
Hi all, thanks for all the responses.........most helpful. I tried the tip that magnus gave with the whiteboard marker as I've seen this used on whiteboards at work, this worked fairly
Hope this helps someone in the future....
Al
79679
