communications
Submitted: Thursday, Oct 07, 2004 at 19:01
Member - David P (NSW)
for serious long distance outback communication in isolated regions eg CSR what do you reckon ...
hf radio or sat phone
Reply By: Member - John C (QLD) - Thursday, Oct 07, 2004 at 19:13
In an emergency?
Sat phone's only good if you've got a number to ring. HF you can usually always get someone at least. Then there's the EPIRB.
79261
Follow Up By: Member - John (Vic) - Friday, Oct 08, 2004 at 02:39
Number to ring???????????.
Try 000 it works the same on a Sat phone as with any other phone in this country.
338734
Follow Up By: Member - John C (QLD) - Friday, Oct 08, 2004 at 09:19
'In an emergency' it said, that means urgently! now!!!!
000 is flat out working in the city in enough time let alone in the middle of nowhere.
HF is always your best bet to find someone quicker and closer if their there.
What would you try 1st?
338759
Reply By: Member - Raymond - Thursday, Oct 07, 2004 at 19:59
Hi David
I use
HF radio and carry an EPIRB for a life threatening emergency. I find the VKS737 service very valuable.
You can very expensive with the radio or cheaper depending on the pocket.
Barrett and Codan with the auto antenna about $4000 but also there is Q-mac radios (Much smaller in size, more the size of UHF CB) and a manual adjustable antenna is about $385. Advantage of HF over satphone was seen on the last trip, vehicle had broken down, rang for recovery quote $5000+, through VKS after a member stopped to assist the cost of taking the van and the car to the next town for repair was a case of beer
Ray
79270
Reply By: Michael_FNQ - Thursday, Oct 07, 2004 at 20:25
Had a codan HF with autotune aerial , I found it easy to use but my wife had no idea.
Always liked the idea of a handheld sat phone, have hire one a number of times for remote trips. I have always figured that the most likely accident is either an accident with another vehicle or rolling my vehicle, this would destroy any external aerials. After an accident I do not want to have to rely on someone being capable of using a HF, anybody can use a Sat phone.
79278
Follow Up By: howie - Thursday, Oct 07, 2004 at 23:07
i agree, worked often in isolated areas with me mate who had a hf, good job he didnt get injured, i wouldnt have had a clue how to use it.
sat phone on last trip (hired) seemed easy to use.
you pay your money and takes your chances.
338726
Reply By: Bob of KAOS - Thursday, Oct 07, 2004 at 20:56
Lots has been said on this topic (and I mean a real lot).
Check the archive.
79286
Reply By: Truckster (Vic) - Thursday, Oct 07, 2004 at 21:43
Good question, I dont think its been asskt a trillion times. Hope sumjuan nose.
79290
Reply By: Member - Cocka - Thursday, Oct 07, 2004 at 21:59
There are so many options to cover every possible incident it'll cost you big $$$$$ to have it all. Then some will say "what price your family".
Well, what do you say? If you think everything and anything might happen, you might as
well stay home.
Basically, you know what is necessary for long distance communications.
HF (VKS737) is one of the best all round communication systems in the world. Look at the different aerial systems and understand what it can do for you and what you can contribute to the system. There are some truley great stories associated with this network if that's your bag. Have a look and talk with their web page. This system can be considered a long term committment.
EPERB are changing frequencies in a couple of years, and are really only a "help, I'm here, come and help me" communication to search and rescue authorities.
Sat phones can be hired for a one off if that's all you want, plus you can contact your stock broker. But like some said you have to have phone numbers to call.
In both HF & Sat phone cases you are best equiped with a GPS to be able to give a location.
Me ? I like toys and would go the HF. But do the home work on these, it's part of the deal.
79294
Reply By: Member - John (Vic) - Friday, Oct 08, 2004 at 02:37
Before you spend any money on a HF consider the implications of BPL and the fact that it will render HF pretty
well useless in this country.
I was also going to buy a HF (Codan NGT) but until the issue of BPL is answered definitively I will not spend a cracker on HF.
Check the archives for info on BPL and the VKS network web site.
I own a Sat phone and it has been perfect for all uses in all areas of Aus.
I wanted the HF for the community aspect as
well as satisfying the gadget man in me, but expensive boat anchor it would be when BPL arrives.
79317
Follow Up By: oddy - Friday, Oct 08, 2004 at 09:30
What's BPL stand for??
338760
Follow Up By: Member - Landie - Friday, Oct 08, 2004 at 14:26
BPL has been raised as an issue, however I doubt the authorities will ever compromise
HF radio communication in this country.
For a start, it is a legal requirement that all passenger (RPTs) aircraft carry
HF radio, for communication purposes, when VHF does not provide suitable coverage. This would be a major obstacle to overcome and would fall into the too hard basket.
For what it is worth, if you can afford both (HF/satphone), than indulge yourself because both compliment each other under differing circumstances.
338799
Reply By: Eric from Cape York Connections - Friday, Oct 08, 2004 at 06:35
David I have both and both I use on trips.
I like the HF for finding out whats going on around the place via VKS and there always seems to be someone close by.
Sat phone it is fairly instant for problems, health, ect.
All the best
Eric
79321
Reply By: Willem - Friday, Oct 08, 2004 at 21:58
I have a HF and am a member of VKS and I listen in to the afternoon chatter every now and then. My HF is there if I need to communicate.
I also have a Satphone which is handy to ring home when you want to, or to ring your mates who are working, when you are out bush, to turn them green with envy.
It has just about taken a lifetime to accumulate all these toys. Funny thing though, in the 60's and 70's we used to go deep into the bush without these comms and still survived. But then again, life was so much simpler then....:-)
79416
