fridge slides
Submitted: Monday, Oct 11, 2004 at 13:25
thomo
Hi all not trying to start any fights but im after a fridge slide and there is that many around im not sure which one to get any advice would be appreciated.
thanks.
Reply By: Coops (Pilbara) - Monday, Oct 11, 2004 at 13:51
I have an Engel slide and don't rate it highly at all - too flimsy !
79712
Follow Up By: Member - Chris M (QLD) - Monday, Oct 11, 2004 at 14:09
2nd that!
The ones that Dept. of Interior use and Outback seem to be pretty good. Don't know whether they are made in house or not...
Cheers.
339097
Reply By: Member - John (Vic) - Monday, Oct 11, 2004 at 14:10
I have a Engel slide for my 60 litre fridge, it is less than 12 months old and is very good.
Very
well built, with no problems at all.
Some of the early models apparently are a bit flimsy.
79716
Follow Up By: squizzy - Monday, Oct 11, 2004 at 16:36
My sentiments exactly John, I also have an Engel slide and it is very strong, and also quite heavy.
Holds my fridge full of goodies without any worries.
Had a slight rattle when it was first installed, but I fixed that by adjusting the rubber stoppers.
Geoff.
339122
Follow Up By: Coops (Pilbara) - Tuesday, Oct 12, 2004 at 08:09
How early?
Mine is also 60 Litre and only 2 years old. I don't rate it at all considering how much it cost and Engel didn't want to know me when I spoke to 'em.
339239
Follow Up By: GeoffSA - Tuesday, Oct 12, 2004 at 16:20
I must admit Coops,
mine is only 12 months old.
339304
Reply By: locallaw - Monday, Oct 11, 2004 at 14:53
Gidday,I bought my slides from the ARB dealer here in Mackay for $99.They came in kit form so you can make them to fit any size fridge.
Work
well for me.
Seeya Locallaw
79723
Follow Up By: Baz (NSW) - Monday, Oct 11, 2004 at 15:43
Hi Locallaw are these still available sounds like what i am looking for.
Baz.
339116
Reply By: Glenn (VIC) - Monday, Oct 11, 2004 at 15:58
I have a Piranha slide for my 50L Waeco and it is fantastic. Cost abit,but very strong.
79733
Follow Up By: thomo - Monday, Oct 11, 2004 at 16:31
This was the slide i was thinking off getting and i have the same fridge so it might be the go thanks.
339120
Follow Up By: Glenn (VIC) - Monday, Oct 11, 2004 at 16:35
No worries thomo,
I bought
mine at one of the 4wd shows (Wandin I think) as it was a bit cheaper.
339121
Reply By: Gossy - Monday, Oct 11, 2004 at 16:07
I have bought one from TJM in
Adelaide (main nth road) for $300. Sounds like alot but you get what you pay for. Very strong and comes out 100% of it's length, unlike some brands which only come out approx 70%.
Needs no support with a full fridge out it's full length. Can't remember the brand name, but it has an Aussie flag on the front of the slide.
79736
Reply By: Member - Brian (WA) - Monday, Oct 11, 2004 at 16:07
Hi thomo
I have a 40lt engel on a engel slide, had it 4yrs no complaints no sagging
lubricate runners its ok.
cheers brian
engel parts might cost a bit extra, I suppose you pay for the name
79737
Reply By: thomo - Monday, Oct 11, 2004 at 16:29
Thanks all just the sort off replys i was after.
79745
Reply By: GeeTee - Monday, Oct 11, 2004 at 22:02
Hi, I purchased a set of 100Kg heavy duty drawer slides from Galvins hardware in
Perth and made the base from a piece of 9mm ply. Works great and cost a little over 100 bucks. Can send you pics off
forum if you wish.
GeeTee
79821
Follow Up By: Member - Ivan (ACT) - Monday, Oct 11, 2004 at 22:23
yes please mate - I've got some slides, just got to figure out where to next - your post was very timely ;-)
isanders at ozemail . com . au
Thanks mate
339196
Follow Up By: crayman - Monday, Oct 11, 2004 at 22:31
Gee Tee
I would appreciate a copy as well fitting 2 40l engle`s in my 4.2tdi
fleay@e-wire.net au
Thank`s Maurie `
339198
Follow Up By: DARREN - Tuesday, Oct 12, 2004 at 13:56
Gee Tee,
I would also appreciate a copy.
doryanthes at telstra dot com
Thanks in advance
Darren
339288
Reply By: angler - Monday, Oct 11, 2004 at 23:23
I made mine up from a filing cabinet drawer, one of the half height ones from a desk. I found it at the local dump. It works fine and certainly holds my 45 Waeco without any probs. I have to tie it down a bit with a stretch rubber strap to stop any rattles. The slides are easy to move and it comes right out for ease of access.
Cost Zero: except for a little welding.
79833
Reply By: duncs - Monday, Oct 11, 2004 at 23:32
Well just to add to the confusion. I have a 40l Engel on a Black Widow. Cost about $100.00. Had it about 12mths and no probs.
Out here in the capital city of Dust (
Broken Hill) the biggest problem all my gear suffers from is just that, dust. Gets into everything. But a quick hit with the WD 40 before I put the fridge on it and all is well.
One concern I do have is that the handles on the Engel are bending from the tie downs. Anyone got ideas on that?
Duncs
79836
Follow Up By: Matt M - Wednesday, Oct 13, 2004 at 14:43
Yep, I found the same with my Engel, so I flipped them!! Now the tiedowns pull in the same direction as the handles, down!
The other option is to make up some brackets with loops instead of the handles, but the mounting points are still the same little m4 screws??
Matt.
339437
Follow Up By: geocacher (djcache) - Friday, Oct 15, 2004 at 01:04
Engel make a genuine accessory pack of 4 tiedowns that go under the handles and secure with the supplied slightly longer screws.
Mine cost about $12. I use 4 turnbuckles to secure it to the slide and it's rock solid.
There are even button holes stitched in one end of the travel cover for the tags to come out, you just have to cut the slit. I don't know why they aren't on the other end but two bits of offcut leather stitched in place by the local canvas blokes (Darche Swags) and the same at the other end now.
See my pics for the "tilting
fridge slide for short bastards and their wives" and download drawings at
my fourbie page
dj
339610
Follow Up By: geocacher (djcache) - Friday, Oct 15, 2004 at 01:08
Oh and the photos of the tiedowns are in the pdf if you download it. The ones on the link page show how it was set up before with the straps over the handles.
dj
339611
