Static
Submitted: Monday, Oct 11, 2004 at 23:35
Member - Mungo Explorer (NSW)
I'm having some problems with static electricity when I get out from the driver's
seat. Now I know it's not life-threatening but still annoying! I've read somewhere to touch this or that (forgot what) before touching the metal on the door but don't think I'll ever get used to such a routine. Anything else I can do? Different floormats? Different shoes? Any ideas?
Reply By: Muddy 'doe (SA) - Monday, Oct 11, 2004 at 23:47
Mungo,
I have had these problems in the past particularly on windy days.
Many people suffer because they touch a metallic item with an outstretched hand or finger. I find that if you give a suspected static item a quick tap with the back of the fingers than it discharges without the normal jolt that causes pain. If you are badly affected then this can become a healthy habit!
Pain is caused when static electricity forms an arc across
the gap between you and the object. This is made worse if you reach out to the object slowly as the arc will occur just as you get within range. There are many theories on the causes of this, mostly centred around the shoes you wear and nylon carpet.
I find that if you can touch or tap the item quickly then the jolt is much reduced.
Just my experience!
Muddy 'doe
79839
Follow Up By: Member - Mungo Explorer (NSW) - Tuesday, Oct 12, 2004 at 00:17
"Pain" is a bit strong, just an unpleasant feeling. Your suggestions sounds like what I've read but I just don't think I can get into that habit. Shoes and nylon carpet - yes, I wondered if putting a rubber mat over the carpet, or wearing something other than the trainers I'm usually wearing (plastic soles!) would make a difference...
339226
Follow Up By: Muddy 'doe (SA) - Tuesday, Oct 12, 2004 at 00:27
The build up of static comes from being insulated too much from an earth ie: sitting in a car with rubber tyres and rubbing on a
seat cover or walking across a nylon carpet wearing the wrong shoes. You build up a positive electrical charge which then goes to a negative ground (earth) when you get out of the car or touch a door handle or frame that is in contact with the ground. Just like Lightning which is a area of positve charge (upper atmosphere) discharging to an area of negative charge (the ground).
You have to either prevent tha build up or just give it an easy way to discharge without arcing which produces the 'jolt'. Sometimes it can be quite painful but mostly as you say it is just an instant of unpleaseantness.
Muddy 'doe
339227
Reply By: Member - Woodsy - Tuesday, Oct 12, 2004 at 06:16
Hi Mungo Explorer.
I found that a fail safe way of stopping that 'ZAP' is not to touch the ground until you are at least 3m away from the car. Hope this helps.
79851
Follow Up By: Member - Mungo Explorer (NSW) - Tuesday, Oct 12, 2004 at 15:33
How do you do that? I don't think I can jump that far...
339296
Reply By: Baz (NSW) - Tuesday, Oct 12, 2004 at 07:36
I have the same problem and apart from keeping the family amused is a right pain in the arse, i have been told when getting out of the car before you put your feet on the ground to hold on to the metal part of the door, now this works not all of the time but it does work.
A fellow sufferer, Baz.
79856
Reply By: Peter - Tuesday, Oct 12, 2004 at 11:15
you will find that it has to do with the type of clothing u are wearing
79886
Reply By: floyd - Tuesday, Oct 12, 2004 at 11:31
It has got so bad with me that the kids do not touch me for about 5 minutes after a trip.
Thh only thing that I have found that works is not touching the ground within a 5 metre radius of the car after driving.
79890
Reply By: G.T. - Tuesday, Oct 12, 2004 at 11:44
A change of underwear may help. If you wear boxer shorts they may be the culprit, change to cotton jocks or similar. You get static build up as you travel by moving your backside on the
seat. Also a lambswool
seat cover may help. Regards G.T.
79893
Reply By: theshadows - Tuesday, Oct 12, 2004 at 14:20
I have the same problem and it went from funny to annoying very quickly.
2 earthing straps from super cheap has helped a lot but not completely fixed the problem.
Next on the cards is to remove the front door liners adn mounting new earthing straps from the door to the chassis. Failing that it will be selling the the moden wonder and going back to a old G60 wit out the central lockng and power windows.
shadow
79914
Reply By: phil - Tuesday, Oct 12, 2004 at 14:34
The cause is static electricity generated when you slide out of the
seat. It is affected by
seat cover material and your clothing. The charge difference is between you and the vehicle body so static straps do not help. (I tried them)
I have found that spraying the
seat lightly with an anti static spray, available from fabric shops, works for a while but needs re applying after a month or so. The other "solution" is to hold on to some metal part of the vehicle as you get out. I now do this almost automatically having been bitten so often.
If you have insulating shoes, and most are, you can remain charged up for quite a long time...untill you reach out for an earthed object!
Phil I
79918
Reply By: Member - Mungo Explorer (NSW) - Tuesday, Oct 12, 2004 at 15:40
Thanks everyone for your suggestions. There doesn't seem to be an easy answer, though the anti-static spray option seems the easiest and I'll try that out first. It seems to be only me (the driver) who suffers this so a bottle should last quite a while for one
seat only, even if it needs to be reapplied every month or so.
I'll also try to change my underwear and my dress sense :-) Will also train myself to touch the metal frame of the car as I get out - the zap usually happens when I'm just out and touching the door to slam it shut.
79931
