2nd Battery location in Hilux dual cab
Submitted: Tuesday, Oct 12, 2004 at 11:05
ThreadID: 16990 Views:2011 Replies:2 FollowUps:2
I am looking to put a second battery in a 2.8D dual cab hilux. I would like to avoid putting it in tray and was interesed in other alternatives. The battery I have is 300mm (L) x 175mm (W) x 225mm (D).
Under the bonnet seems out of the question without major modifications. It seems that it may be possible under the tray to the passenger side of the spare.
Reply By: Voxson (Adelaide) - Tuesday, Oct 12, 2004 at 13:36
Hi Greg..That is exactly where my mate Monty had put his.... And his new Hilux seems to be the same....
AnswerID: 79909
Follow Up By: Greg - Darwin - Tuesday, Oct 12, 2004 at 15:42
Voxon,
Thanks for the info. If you mate has a tub (ie not trayback) like myself I assume that he would have to load the battery in from the bottom with the leads already connected. Do you know if he has extended leads to allow this or something like an anderson style plug?
FollowupID: 339298
Follow Up By: Voxson (Adelaide) - Tuesday, Oct 12, 2004 at 22:26
I will ask him next time i see him... Prob weekend... I just cant remember the full setup..
FollowupID: 339335
Reply By: Neil - Tuesday, Oct 12, 2004 at 21:26
Hi Greg the old man has a dual cab too, he has kitted his vehicle out, and the dual batt sits at the rear of the vehicle in a box mounted under the tray to the chasis.
hope it helps
keepsmilin
AnswerID: 79983
