Tyre Pressure for Challenger
Submitted: Wednesday, Oct 13, 2004 at 14:19
XS Challenger
The tyre Placcard says 26psi whether loaded or unloaded. The Goodyear block says 36psi.
I have 265/70R15 Cooper AT on my Challenger. What tyre pressure should I be using around town??
I do drop them on
the beach etc. But on the black top I would like to know which way to go.
Thanks in advance
Reply By: Leroy - Wednesday, Oct 13, 2004 at 14:25
36 sounds good to me! Mid 20's when loaded on dirt and less than 20 for sand. 26 sounds way too low for running around on the blacktop. Give's a nice sqeeshy soft ride though!!
Leroy
80068
Follow Up By: XS Challenger - Wednesday, Oct 13, 2004 at 18:16
Yeah I guess thats why they recommend 26 so you get a squishy ride.
The goodyear bloak also said not to bother airing down on sand. I have run 36 no worries on Double Island a few times although I guess if it was Dessert Sand or servere
sand dunes it may be a different story.
339463
Reply By: Member - Chris M (QLD) - Wednesday, Oct 13, 2004 at 14:27
Pretty sure that Placard is for the original tyres fitted to the vehicle when new. Go with the recommendations on your current 'after market tyres'.
80069
Follow Up By: Stew53 - Wednesday, Oct 13, 2004 at 21:21
Use the OEM recomendations, Long term if you get a set of verniers and measure the tread depth now, in the centre of the tyre then at the inside then on the outside just off centre of all 4 tyres (probably 12mm new) write the measurement down plus the presures and the KM, Excels good for this.
If you could expect to get 60,000km from the tyres that would be about 2mm for each 10K.
In 5,000km time measure the tyres again, you would expect to see 11mm in the centre and either side of the centre, adjust the tyre pressure up or down to compensate in incriments of only 2-3 psi, (write down the results) in the scheme of things this is a change of approximatly 10% ie if the tyre is worn more in the centre lower the presure etc.
You may not get it right for this set of tyres but you will have a good starting point for the next set.
339478
Reply By: MrBitchi - Wednesday, Oct 13, 2004 at 14:29
I run the Coopers on my Pajero NM at 36 front, 34 rear. The Challenger will probably run about 2 psi less both ends as it's a bit lighter than the Paj.
80070
Reply By: Allan Mac (VIC) - Wednesday, Oct 13, 2004 at 14:46
HI XS,
I run my XS on 36psi around the burbs even though the placards says 26. I'm still running the original Geolanders. The ride seems okay at that pressure
80072
Follow Up By: green man - Wednesday, Oct 13, 2004 at 18:13
I run the same pressure 36psi on my Challenger for tarmac duties
(255/70-16) standard rubber
I have checked them after a couple of hours at highway speeds and found they only went up to 38psi so the 4 psi rule is there
339462
Reply By: Member - Jeff M (WA) - Wednesday, Oct 13, 2004 at 16:56
26psi!!!! What are they thinking! Bloody hell, I used to run my Nissan Maxima at 42!
80091
Reply By: XS Challenger - Wednesday, Oct 13, 2004 at 18:19
Thankyou to all
I think I will stay at 36 all round and buy some Staun deflators so I can easily deflate.
80098
Reply By: Glenno - Saturday, Oct 16, 2004 at 12:29
My 2000 Challenger with Cooper AT's ran at 36psi its whole life. Tyres wore perfectly even across the tread.
Glenn.
80425
