Air Tanks & Fire Extinguishers
Submitted: Thursday, Oct 14, 2004 at 18:33
ThreadID: 17045 Views:3851 Replies:8 FollowUps:11
OK so I was holding off on the air tank idea because it was just all going to be too hard to find enough space to put a unit in that would serve any real purpose, and blah blah etc etc.
It just so happned that for some reason I won't into one of the guys here at work needed to use a fire extinguser. Being all used up I proceeded to take the now rubbish and promptly went to ARB thinking I was pretty smart and bought a pressure switch for my Blue Tounge. So now it's down to HosCo to get the correct fittings and to pumb it and wire it in. Now my air horns will be REALLY loud and I can be one of those arrogunt 4wd owners I'm always hearing about. :-)
The only thing I've just realised is that I'm going to need two holes in this fire extinguisher, one for pumping the air in and one for letting it out.
My Question is would it still work if I were to just put a "T" peice at the top of the tank, would that prevent me from needing to drill a second whole into the tank and thread it? If not, how would I drill the whole and make a thread?
Reply By: Member - PatC - Thursday, Oct 14, 2004 at 18:40
My 240v compresser has a tee piece. I can't see why it wouldn't work for your set up.
AnswerID: 80222
Follow Up By: Member - Jeff M (WA) - Thursday, Oct 14, 2004 at 19:23
Cool thanks, I'm wondering if I would need some kind of one way valve to stop the air back pressure leaking through the compressor? Anyway, will take some experimenting I spose.
FollowupID: 339574
Reply By: Tim - Thursday, Oct 14, 2004 at 19:04
And if for any reason you do drill into the cylinder, remeber that where the current thread is will be reinforced and the rest of the cylinder won't be. It's probably only 2 or 3mm thick which isn't a lot to tap into for a pressurised cylinder.
Tim
AnswerID: 80224
Reply By: Truckster (Vic) - Thursday, Oct 14, 2004 at 19:05
Goto truck wrecker and spend $50. Have no issues ..
AnswerID: 80227
Follow Up By: Member - Jeff M (WA) - Thursday, Oct 14, 2004 at 19:22
Truck Tank will tank some enginerring to fit somewhere, the fire extigushers only 2L and will first easy under the bonnet next to the blue tounge, just enough for a quick blast, I'm not interested in filling tyres with it, I'm happy with the Blue Tounge Nativly for that, I just want to have a quick blast of air to clean out pips, air filters and to blast my air horns and possibly in the future activate some Dif Lockers.
FollowupID: 339573
Follow Up By: Member - 'Lucy' - Thursday, Oct 14, 2004 at 22:04
Good to see you are still on the ball Truckster
FollowupID: 339593
Follow Up By: SteveL - Thursday, Oct 14, 2004 at 22:04
Not all truck tanks are huge,some European trucks (Mercedes,Volvo)have tanks which would be barely 2L. - Steve
FollowupID: 339594
Follow Up By: Truckster (Vic) - Friday, Oct 15, 2004 at 11:03
A truck tank would take no more engineering, infact less.
They would come with the mounting straps that fit them, relief valve, and train valve for fluid buildup, and you only need to join your compressor into it, no drilling, welding to add an outlet, its already there.
They do come in all shapes and sizes, some similar to 3ltr coke bottles, (too small for our application but just the point).. Look at some MAN and other import trucks which are long tube shaped, would be excellent against a chassis rail.
YATMV ;)
FollowupID: 339638
Reply By: Wayne (NSW) - Thursday, Oct 14, 2004 at 20:24
Jeff,
Did somthing simular a few years back. I aslo required a few extra out lets so I got a short length (2") of 1" solid square aluminium. Drill and tap a hole along it's length and make sure it is in the middle of the aluminium block, and attach to the air tank. So far 1 outlet, drill and tap a hole in the side of the aluminium block and you have another outlet. Repeat for as many outlets that are required.
Wayne
AnswerID: 80231
Reply By: Peter 2 - Thursday, Oct 14, 2004 at 21:38
Or you can go to an engineering supplier, they sell short pieces of steel tube with a pipe/gas thread in the middle, comes in different sizes.
Weld the tube end on to the outside of the cylinder where you want it, drill a hole through the cylinder in the centre of welded on tube and you have another fitting.
Repeat as necessary.
Any air tank should have a drain cock to remove accumulated moisture and a relief valve to prevent explosion and possible injury.
AnswerID: 80242
Reply By: Member - John (Vic) - Thursday, Oct 14, 2004 at 22:21
Prudent to place a check valve in line between the compressor and the cylinder.
Will stop the air from leaking back through the exhaust valve on the compressor.
And yes you can tee the cylinder top, the cylinder will only add volume to the system as a whole.
Example the volume of the cylinder plus the volume of the internals of the hose / pipe system you use.
Just for your interest if you cylinder has a internal volume of 2 liters WC , this is expressed as Water Capacity and is the measure used to size the internal volume of cylinders and is charged by your compressor to 120 psi or about 8 bar then you will have a free air capacity of about 16 liters compressed into the cylinder.
The average adult male exhales about 4 liters of free air from their lungs per breath.
This means if you use it to inflate your air bed it will place about as much air into your air bed as 4 breaths from your mouth.
Not worth the effort in my book.
Also once empty then the increase in system volume by having it in system line will slow down your compressor volume / pressure output.
AnswerID: 80249
Follow Up By: Member - Jeff M (WA) - Friday, Oct 15, 2004 at 17:27
John, It's not volume I'm after, it's the small burst of high pressure I was after. I have a high flow low pressure pump for my air beds, bugger stuffing around with the bluetounge to blow up an air bed.
I'm intersted in this theory and I'm no rocket scientist so I hope I don't sound tooooooo dumb.
If I never let the pressure in the air tank empty right down, will it still effect my tyre pumping speed. ie Obviously the small amount of air in the tank will be used up very quickly into the first tyre, but as long as I don't let all the pressure out of the system in won't need to recharge to maintain pressure and just work as normal? Correct? Or am I wildly mistaken. Otherwise I will need to fit some kind of bypass for pumping up tyres and then flick it back again when I'm finished, maybe another 12v solinoid would do it...
FollowupID: 339685
Follow Up By: Member - John (Vic) - Friday, Oct 15, 2004 at 21:12
No worries Jeff, not a dumb question.
This topic always seems to get people a bit confused.
I work in the diving industry and pressure volume relationships are something I do everyday.
The issue of the air bed was only to give you an example of how much air you would get out of the cylinder in a practical aspect, In other word very little.
Hence my comment about it being not worth the effort or the hassle and expense for that matter.
The thing to remember is the more air line or cylinders fitted to the air line then the more volume you have to fill.
If you then attached your flat tyre to the end of the air line then your compressor has to now put out sufficient volume to fill the airlines, the cylinder and the tyre.
Since we use very low volume pumps then it will take longer to fill the whole volume now attached to it to the required pressure.
The only way to get more volume into the cylinder is to pump it to a higher pressure, the diving industry uses a common pressure in scuba cylinders of about 200 bar or 3000 psi.
These pumps we use in our trucks are regarded as Low Pressure at around 100 to 120 psi.
Also the issue with compressors is that when the pressure increases then the volume will decrease hence the output ratings on all pumps will decrease as they build to a higher pressure.
for our application you either have to have a high volume compressor or a very large cylinder anything else is a waste of time.
I am not sure of the volume of a typical 4wd tyre but it would have to be at least 20 liters WC, this would mean to fill it to 50 psi would require about 70 liters of free air, your cylinder has about 16.
Hope this helps.
FollowupID: 339711
Follow Up By: Member - Jeff M (WA) - Monday, Oct 18, 2004 at 11:34
Thanks John, makes more sense now, not only are you pumping up the tyre but your pumping up everything in the system, the tank, the hoses etc etc.
FollowupID: 339920
Reply By: REX.....(Adelaide) - Friday, Oct 15, 2004 at 08:03
any one used a 5 kg gas bottle?????
AnswerID: 80274
Follow Up By: Mick - Friday, Oct 15, 2004 at 09:13
Left hand threads on gas bottles may be a problem!
FollowupID: 339628
Follow Up By: Member - Ed. C.- Friday, Oct 15, 2004 at 12:41
Yes indeed!!
I happened have an "expired" 5kg cyl (the taller, skinnier variety, not the short fat one) "lying about", so removed the valve (pri*k of a job, they are in there so t-i-g-h-t !!), drilled a couple holes, welded fittings for relief valve, press. gauge, water drain etc., & mounting lugs...
Have it mounted on the A-frame of my CT.. not plumbed, reserve air only at this stage.. have not (yet) had to use it to re-seat a bead, but certainly very handy for "dusting off" before setting up camp after several K's of bulldust! .. Usually there is enough air in reserve to re-inflate (4) trailer tyres from 14 to 20 psi, while I do the vehicle tyres straight off the pump...
My "Bushranger look-alike" will pump it up to 100psi without difficulty, will go to 120psi, but by then it's starting to struggle...
The thread in the cyl. itself (once you get the d&$n valve out) is 3/4" BSP.. this is the POL type valve... Primus & companion type valves have different size fittings, of course..
Before anybody jumps down my throat for cutting & welding on a gas cylinder, it had been empty for, like, y-e-a-r-s, and I flushed it thoroughly (several times) with water before working on it... Visual internal inspection showed shiny, like-new metal, so I am comfortable with the safety aspects...
Regards, Ed. C.
Confucius say.....
FollowupID: 339645
Reply By: Member - Camper (SA) - Friday, Oct 15, 2004 at 17:53
As I understand it any pressure vessel needs to be tested after manufacture and at set periods so that you don't have an explosion and the embarrassment of being mistaken for a terrorist. Even a moderate pressure in a closed vessel can cause a big bang if it or the welds let go.
Having said that pressure acts in all directions so your tee peice will work and you can just go ahead and pump up tyres with the cylinder in the line. But I'd do some serious research before I started if I were you or you might just start WW111
Camper
AnswerID: 80346
Follow Up By: Member - Jeff M (WA) - Friday, Oct 15, 2004 at 18:01
The pressure switch I have will cut the compressor out @ 105psi +/- a few. I will be fitting a pressure valve (as a backup) in line also. The Extinguisher was charged to 125psi before and sat like that for years, it also has up to 200psi on the guage, not that I'm planning to go there. I think an explosion with those items in place would be very unlikley.
But on that note I've been down to HosCo and it turns out the extinguisher has a funny thread on it that they can't match anything up to, so might be back to the ol' drawing board anyway.
I'm comited now as I've spent the money on the pressure switch and fittings so might try Truckster's idea of getting a truck tank, problem is there is only one truck wrecker I know of in Perth and it's friggin the other side of the city!
Oh well... Will keep you all updated...
FollowupID: 339693
