TJM Bullbar(Steel) for Nissan GU
Submitted: Thursday, Oct 14, 2004 at 21:14
DeanoNSW
Today I had to use a Highlift jack on my GU for the first time. On my old Patrol, I had an Opposite Lock Alloy bar, which I was able to jack off. I presumed the TJM All Steel bar would be solid enough to jack off. I jacked off the slots at the front of the bar and I was surprised, and not happy.
After lifting the front of the vehicle up to change a tyre, I noticed I had bent the Bar at the front slot I had used as a lifting point. Whilst it is not too bad, clearly the bar is not heavy enough to jack on.
Maybe I should have bought the ARB bar. The bar I have is a TJM Steel Winch Bar - Air bag compliant.
How the hell do are you supposed to use a highlift jack on the front of the vehicle ?
Reply By: Leroy - Thursday, Oct 14, 2004 at 21:27
arb ones i fink have high lift jacking points!
Leroy
80241
Follow Up By: Member - AndrewPatrol - Friday, Oct 15, 2004 at 12:49
yes
339647
Reply By: Member - Tim&Jan - Thursday, Oct 14, 2004 at 22:30
I have hit a full on goat with
mine bent it slightly but it did do a good job. The welding on top of the bar also needs close inspection as they crack, also
mine rusted after 3 months but it would of been under waranty but couldent be stuffed hassiling them plus the distance to the
shop
80250
