Bug Screens
Submitted: Friday, Oct 15, 2004 at 10:43
ThreadID: 17057 Views:7821 Replies:11 FollowUps:7
G'day all
TGIF! Just wondering what the best material would be the best to make up a bug screen for the radiator. Would fly screen or shade cloth be the go? And which is likely to allow the best air flow.
Am going to be heading up to Lightning Ridge for a weekend and will no doubt encounter some of those damned hoppers giving our farmers grief and want to avoid their exoskeletons clogging up my radiator.
cheers,
Sam.
Reply By: Vince NSW - Friday, Oct 15, 2004 at 10:50
Hi Sam
I've used shade cloth. Stops the bugs but still lets some of the air flow in. I say some . I have mounted mine well clear of the front grill to allow air to flow around as shade cloth is a great wind break, I have it on 3 sides of my camper anex
Vince
AnswerID: 80287
Reply By: Banjo (SA) - Friday, Oct 15, 2004 at 11:01
Yep - shadecloth with low percentages - take some spare - if it gets filthy just fling it - when next required I'm going to rig mine simply with ockies - no tailoring - just cut and rig temporarily with the ockies (and I found out that cheap ockies are worthless too - nothing but quality for me from now on.
AnswerID: 80288
Reply By: Member - Paul J (ACT) - Friday, Oct 15, 2004 at 11:29
ARB sell em for around the $70 mark....
Paul
AnswerID: 80291
Reply By: Truckster (Vic) - Friday, Oct 15, 2004 at 11:59
If your car is turboed, its not recommended.
AnswerID: 80294
Follow Up By: Member - Paul J (ACT) - Friday, Oct 15, 2004 at 12:27
Sam's rig details dont mention having a turbo, that's why i posted it.
From reading another post re: lifting, you mentioned getting rid of the sway bars, is it really noticeable round town? much roll etc.
Paul..
FollowupID: 339642
Follow Up By: Member - Sam (NSW) - Friday, Oct 15, 2004 at 12:38
Yeah
No turbo unfortunately.
There will be when the Hilux grows up into a Patrol. Just waiting for someone to buy me one ;-P
FollowupID: 339644
Follow Up By: Truckster (Vic) - Friday, Oct 15, 2004 at 15:30
Paul.
It takes 10-20 mins to remove both swaybars. try it, you will like it. just as you do now, drive accordingly.
FollowupID: 339669
Follow Up By: 28patrol - Saturday, Oct 16, 2004 at 10:24
I use flyscreen across the front of the bullbar. Works well and has had no effect on the turbo so far
FollowupID: 339759
Reply By: Moose - Friday, Oct 15, 2004 at 13:20
Made mine out of the metal insect screening material - has been on there for years without a problem. I've permanently mounted it behind the platic grill and when it needs cleaning properly I just remove the lot and give it a good scrub. Usually though a good hosing gets it clean enough.
AnswerID: 80307
Reply By: Aston - Friday, Oct 15, 2004 at 18:30
I've just finished making a screen that is mounted in a frame that is attached to the rear of the uprights of an ARB bullbar and it is removable for cleaning.
This means that there is an air gap 75mm between it and the vehicle.
The problem comes from the fact that "Locusts" when they smash into anything create a gooey mess 50mm dia.
Heeding "trucksters" words, you must be very careful with vehicles that are turbo'd,
I'll see how it goes on the Disco keeping in mind the temperature of both air and water.
This may help with your design.
Aston
AnswerID: 80354
Reply By: Member - Jack - Friday, Oct 15, 2004 at 19:30
I just bought some shade cloth, folded it at each end and punched in a few eyelets. I sling it across the front of the bullbar, occy straps tie it up, and it works a treat. On my way back from Victoria(Grampians and Little Desert) via Deniliquin, Cowra, Mudgee last week picked up plenty of critters. My vehicle (91 80 Series Landcruiser) is not turbo'd so did not have to consider temps much, but there was no noticeable rise in temp, even when it was full of bugs. On two stops I just took it off, flushed it a bit with water and it was ready to go again. Not the best looking thing on my truck, but what the ...... !!! Works fine for me.
Jack
AnswerID: 80360
Reply By: Croozer - Friday, Oct 15, 2004 at 20:43
Sam,
I have a 100 series TD on which I removed the grill and fixed a piece if gal mesh on the back of it (about 4mm square mesh, from Bummings (bird aviary mesh I think)) cut to size and secured with cable ties. I figure this will stop large critters and stones from clogging and/or damaging the radiator etc, and is easy to clean by hosing from behind. I also have carry a removable (large weave) shadecloth screen which attaches on the front of the bullbar covering top to bottom between the headlights, however given that this would severely restrict the airflow it will only be used where bugs are in plague numbers and I would stop and clean it regularly.
Stu
AnswerID: 80368
Reply By: Member - John- Saturday, Oct 16, 2004 at 00:07
In the Kimberley we use a combination of two screens,
a 4mm mesh permanently fixed over the front of the bull bar to block all the big insect and grasshoppers which can really clag up everthing in quick time. Very small insects tend to dry up and evenually get sucked through. Very important not to limit the air flow for turbos in very hot environments.
We still have the radiator removed annually for a thorough clean.
Tie a double thickness of shade cloth over the bull bar during when on tracks with a lot of grass sees, especially spinifex. Remove it on the highway unless conditions are cooler. Once it gets full of grass seeds we just bin it and make up another one.
I insert a length of thin cane in the fold at the top and that helps to keep it tied straight along the top of the bullbar. Down the bottom we tie to wire loops we leave permanently in place.
JohnS
AnswerID: 80397
Reply By: Member - Blue (VIC) - Saturday, Oct 16, 2004 at 05:11
Got me a whole roll of stainless fly wire, works a treat. Happy to part some off to anyone local or passing through.
AnswerID: 80402
Follow Up By: Member - Blue (VIC) - Saturday, Oct 16, 2004 at 05:20
It may actually help if I let you know where I am... I guess
Ferntree Gully area, Melbourne.
Also it is free as work kindly donated it to the cause, I'll never understand why they just throw out everything they no longer have a use for...
Blue
FollowupID: 339735
Follow Up By: cj - Saturday, Oct 16, 2004 at 07:55
I'd be keen on some if possible. Let me know what suits. cj_zuki at yahoo dot com dot au
FollowupID: 339744
Follow Up By: cj - Monday, Oct 18, 2004 at 15:16
Just want to say thanks for the mesh Blue. It's a great community we have here.
FollowupID: 339952
Reply By: Member - Sam (NSW) - Saturday, Oct 16, 2004 at 19:20
Thanks all for the replies.
Took a trip down to Bunnings this morning (for some reason they decided Sat morning was a good time to repaint the lines for the parking spaces??????) and picked up some shade cloth. I'll see how it goes, may switch over and try mesh at another time.
cheers,
Sam.
AnswerID: 80448
