Navara rim OK for Barvo?
Submitted: Saturday, Oct 16, 2004 at 17:06
ThreadID: 17088 Views:2458 Replies:6 FollowUps:0
Is the standard 16" rim which was fitted to Navara 4WD in the 90's suitable for use on a 2000 Mazda Bravo 4WD?
The stud pattern looks the same and the offset the same within about 3mm but the centre hole is larger on the Navara.
I only want it for a second spare.
Any thoughts?
Phil I
Reply By: Utemad - Saturday, Oct 16, 2004 at 19:00
If it's only a second spare I am sure it will do. Just put it on at home to make sure it fits.
Wouldn't matter if my 2nd spare was from a commodore as it has never been on my ute. Even the 1st spare has only been used once when I went too low on pressure and broke the bead on the beach. I didn't have a compressor then so had to change it.
AnswerID: 80446
Reply By: navaraman - Saturday, Oct 16, 2004 at 20:10
Last time i replaced my tyres I asked the guy at the tyre store about getting a second spare wheel for my Navara. He advised to get one from a wreckers yard as he'd heard of problems due to that larger hole in the wheel not being right on some aftermarket wheels. Apparently they don't sit right and put stress on the stud leading to premature failure. If i were you I'd try a wreckers and get an OEM Bravo wheel
AnswerID: 80455
Reply By: Swerv - Saturday, Oct 16, 2004 at 21:46
Hi Phil
Not sure about the navara wheel, but I got two spare rims from South west Four wheel drive wreckers here in Toowomba. They seem to be pretty hard to come by but I managed to get two of them for $55.00 each. I would personally go for that option but that depends whether you can get the rims or not.
Swerv......
AnswerID: 80472
Reply By: Banjo (SA) - Sunday, Oct 17, 2004 at 06:48
Know someone who wanted to do the reverse - 91 Bravo stock rim as a spare for a 2002 Navara - no go - not sure of the technicality but it was a bummer..... rims can be such pain (well, cars in general !).
AnswerID: 80494
Reply By: conman - Sunday, Oct 17, 2004 at 20:52
Hey phil,
I just fitted 15 x 7 sunraysia's on my 2000 courier. They're stamped as navara on the rim and box, they fit great, cost me $65 each brand new.
AnswerID: 80587
Reply By: phil - Monday, Oct 18, 2004 at 10:40
Thanks everyone for the replies. Sounds as if it will do as the second spare anyway.
Phil I
AnswerID: 80662
