Split rims have to go
Submitted: Monday, Oct 18, 2004 at 16:04
ThreadID: 17140 Views:2655 Replies:8 FollowUps:20
Hi all
After having a bad run with the tubes in my split rims I have decided to go to one piece rims.
My questions is will my current tyres (225/75/16) fit ok on 16x7?
Reply By: Utemad - Monday, Oct 18, 2004 at 16:22
I have BFG KO 225/75 16 on my Rodeo on the standard 16x6 one piece. BFG recommend minimum 6in and max 7in. So you should be fine.
BF Goodrich KO click on technical details under the tyre picture.
AnswerID: 80717
Follow Up By: Utemad - Monday, Oct 18, 2004 at 16:25
Link to the actual bit that I sent you to
FollowupID: 339962
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 18:52
Thanks Utemad. I thought they would fit but I just remember reading otherwise on the forum one time.
FollowupID: 339979
Reply By: equinox - Monday, Oct 18, 2004 at 17:12
Hi Earvin,
What kind of dramas have you been having?
Eq.
AnswerID: 80726
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 19:09
Hi Equinox,
I should start off by saying that I have had split rims for over 3 years and have had no problems until my trip last month.
On that trip I had one tube develop a slow leak before even getting off the tar, another was completely destroyed and ripped right down the seam, and another was punctured but it looked like it had worn.
These were brand new tubes and tyres. Now there could be a couple of reasons why this occured. I figure that they could have been dodgy tubes, although they were Michelin which I believe to be a reputable brand.
There could have been some crap in the tubes which eventually wore on the tubes.
Maybe the pressures I was running were too low and caused a heat build up. I was running Cooper st and because of their well known chipping problems I ensured tyre pressures were a bit lower than I would usually run. Perhaps this was too low for the split rim set up.
I don't really know the reason but a conversation I had with a tyre guy (not the one I got the tyres from) before I left on my trip sticks in my mind. He said that whilst split rims had their advantages there were basically more things that could go wrong with them, i.e. you may simply have problems with the tubes rather than having something puncture the tyre. This is exactly what happened to me. There was no punctures but the tubes just faultered for whatever reason.
I do not want to have to go through that again so I am changing to one piece rims. My friend however who has much more experience than myself absolutely loves splitties and has had very few problems.
I did not let this spoil my trip however and I just saw it as part of the adventure and a real learning experience.
FollowupID: 339983
Reply By: Phil G - Monday, Oct 18, 2004 at 19:18
Earvin,
Wise move. I used splits for about 10 years before changing to tubeless and never looked back.
I had some scary experiences with tube blow outs on the highway. The quality of tubes is not what it used to be. The Korean branded ones were the main culprit back then.
Now with tubeless, the tyres run cooler, wear longer, and have fewer punctures. And when out in the bush, punctures are simply plugged.
AnswerID: 80744
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 22:22
Thanks Phil,
I hope I have as much trouble free running as you have once I made the switch.
Now all I have to do is find some suitable rims.
FollowupID: 340025
Follow Up By: Phil G - Monday, Oct 18, 2004 at 22:31
Earvin,
Not sure what vehicle you have, (I'm guessing a Hilux), but I'd go the 16x6 rims for a 225 tyre - Prado RV, Navara, early Jackaroo etc Just want to be sure the offset is OK.
If you get the 16x7, then I've heard the Prado GXL rims fit nicely on the IFS Hilux.
FollowupID: 340028
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 22:41
I have the IFS Hilux and I am looking for some Prado rims but they seem hard to come by. I want the 16x7 as I intend to go to 245/75 when I wear the Coopers out.
Why would a 16x6 be preferable in your opinion?
FollowupID: 340032
Follow Up By: Phil G - Tuesday, Oct 19, 2004 at 20:43
16x6 are preferable for the skinnier 225 tyres because they are less likely to come off rims when aired down in sand or mud, and easier to reinflate tubeless if they do.
But from what you've described, the 16x7 are better for you because the 245/75R16 fit up nicely on the 7 inch rims.
You can also get the 16x7 Prado Kimberley mags for a very cheap price from some dealers and tyre shops (eg Ballarat Toyota).
FollowupID: 340179
Reply By: pjd - Monday, Oct 18, 2004 at 19:35
your tyres may fit on the rims but if they are not tubeless tyres they will not hold air & are not designed for tubeless rims
AnswerID: 80748
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 22:08
pjd they are Cooper ST's - tubeless tyres so no problems there.
FollowupID: 340020
Reply By: Aandy(WA) - Monday, Oct 18, 2004 at 19:48
Good move Earvin, I endured 7years of punctures and tube and tyre failure with split rims on an FJ55. I had at least 10 flat tyres for various reasons. I changed to a vehicle with tubeless in 1989 and have have had one flat tyre in the following 15 years. Split rims went out with manual locking hubs and part time 4wd in my opinion.
AnswerID: 80753
Follow Up By: Utemad - Monday, Oct 18, 2004 at 20:29
Yeah my Rodeo with it's manual locking hubs and part time 4wd is so old hat. The only reason I don't bin it is because of its tubeless rims.
FollowupID: 340003
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 22:10
Aandy - one thing at a time. I will get rid of the manual locking hubs and part time 4wd in good time :)
FollowupID: 340021
Follow Up By: Aandy(WA) - Monday, Oct 18, 2004 at 22:36
By all means hang on to it Utemad. It's similar to the 1979 FJ55 Landcruiser I had some time ago and believe me I had a lot of fun in it!
FollowupID: 340029
Reply By: Willem - Monday, Oct 18, 2004 at 20:03
I ran splits on my vehicles for 30 years and had my fair share of punctures. I relied on the ease of repairing out bush, carried a few spare tubes and generally gave the tyres a hard time. I still run spilts on my trailer. But recently I upgraded to a later model Nissan and now run 2 sets of 265/75/16 wheels and touch wood no punctures so far. The quality of tubes these days leave a lot to be desired AND running splits on late model more powerful vehicles tends to run the tyres at higher speeds and therefor higher temperatures. This in turn reneders the tubes vulnerable.
Yes your 225's should fit a 17x7 rim
AnswerID: 80762
Follow Up By: Steve - Monday, Oct 18, 2004 at 20:55
The quality of tubes these days leave a lot to be desired .....now can you please tell us why this is so ????
FollowupID: 340009
Follow Up By: Willem - Monday, Oct 18, 2004 at 21:04
Cheap imports...resellers don't care.....more money to be made if tubes fail.........
FollowupID: 340010
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 22:18
Hi Willem,
When I was under a different name I actually sought your advice re: the splits via member msg before my trip. Unfortunately it just went a bit pear shaped on the trip and after that it was easy to make up my mind to go to one piece rims. You are obviously happy with the change from splits so far.
I kept a look out for you on my travels as Ruth said you were around but must have just missed you at Innamincka, probably passed by you in the dust storm :)
FollowupID: 340022
Follow Up By: Willem - Monday, Oct 18, 2004 at 22:30
Hi Earvin
Yes that was some dust storm. We high tailed it in and out of Coongie in a morning. Will have to go back some other time and relax by the cool waters chasing flies :o)
FollowupID: 340026
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 22:51
Willem,
We stayed one night at Coongie and it was definitely the pick of the camp sites for our trip. Wish we could have stayed longer.
We were travelling along the Walkers Crossing track when the storm hit, and it was a real challenge to see the road. The guy I was travelling with went a bit stir crazy prior to the storm and took off towards Innamincka, leaving us behind. He only had handheld UHF so he was soon out of range. We did not see him again until Innamincka where he turned up two hours after us. He had gotten himself lost in the storm.
A good reason to all stick together when you are travelling.
FollowupID: 340040
Reply By: Mark- Monday, Oct 18, 2004 at 21:19
You can feel the difference in quality between the korean tubes and the Australian made tubes. The Korean tubes are MUCH thinner rubber. This is usually what you will get if you dont specifically ask at the tyre shop for the better tubes eg Bridgestone. Believe me, the tyre shops know the difference. Dont forget the rust bands which are essential with split rims. They help to protect the tube from chaffing.
AnswerID: 80775
Follow Up By: Earvin Johnson - Monday, Oct 18, 2004 at 22:20
Hi Mark,
I had brand new rust bands and Michelin Tubes which were made in Italy. Not sure of the quality of tubes from Italy.
FollowupID: 340023
Follow Up By: V8troopie - Tuesday, Oct 19, 2004 at 00:44
Earvin, it is highly likely that you or your tyre supplier never bothered to COMPLETELY remove the little stickers that are placed inside new tyres.
I had the same problems you are talking about with new Cooper AT's. The tyre supplier/ fitter tried to fob me off initially but when I contacted the distributor I was offered a pro rata discount on a new tyre as one was destroyed as it went flat due the inner tube rubbing through on the sticker.
All the other tyres were inspected, the offending stickers removed and in one case a distinct rectangular rubbing pattern could be clearly seen on the tube.
The tyre industry knows about this. I am told these tyres also fit tubeless rims, where the stickers do not matter.
BUT YOU MUST REMOVE THEM FOR SPLIT RIMS.
I am happy with split rims, they are easy to fix and I had no more punctures (2) than one could expect during the life of the previous set of Cooper tyres ( which apparently had the stickers removed).
Klaus
FollowupID: 340049
Follow Up By: Earvin Johnson - Tuesday, Oct 19, 2004 at 06:14
Hi Klaus
That is interesting because I did notice the stickers on the inside of the tyres when I dismantled them.
FollowupID: 340053
Follow Up By: Steve - Tuesday, Oct 19, 2004 at 20:15
Mark: would like to know which company makes their tubes in Australia...the ones you reckon are thicker than those pesky Korean ones ??? rust bands are part and parcel of tubed rims...or am I going potty ??
FollowupID: 340177
Reply By: Mark- Tuesday, Oct 19, 2004 at 20:44
Steve,
I believe the Bridgestone branded tubes are Australian made, its worth looking at them side by side with the cheap ones to see the difference. I've only seen rust bands used on split rims, not one-piece rims - is this what you mean?
AnswerID: 80930
