Jackaroo performance problem
Submitted: Thursday, Oct 21, 2004 at 15:07
ThreadID: 17204 Views:3791 Replies:7 FollowUps:2
Howdy,
I have a 2000 model Jackaroo that I put on gas when I bought it 18 months ago. It suffers from what feels like a fuel starvation problem when under load up steep inclines, like when you take it off road! The problem happens both on gas and petrol but no mechanic I've been to can offer much help. They tell me it's hard to diagnose if the problem doesn't occur in the 'shop'. I've replaced spark plugs but it didn't change anything. Any ideas what the problem might be. One Holden dealership said to change the ECU ($1200) and that MIGHT fix it! The car is also a little difficult to start (lean) but has no other problems driving around town.
Reply By: Leroy - Thursday, Oct 21, 2004 at 15:32
I was told to steer clear of gas when I bought my Rodeo as I was thinking of converting it to gas. My mechanic said put up with the fuel ecconomy or don't buy it! But this doesnt help you now. What does the ECU do when the vehicle is running on gas? I'm sure this will only have a bearing if you are running on Petrol. I'd check to see how the gas is plumbed in as it may be restricting air flow. I know you said it appears lean when trying to start but a rich mixture may give you the same symptoms.
Leroy
AnswerID: 81103
Reply By: Member - 'Lucy' - Thursday, Oct 21, 2004 at 17:55
Afternoon Jackass
I have a duel fueled vehicle (not a 4WD) and was told at the conversion stage that I had to run spark plugs one (1) temp range cooler, with a gap 20% smaller.
I did this and have had no problems at all ,other than overall power wise it wouldn't pull the skin off a custard, but is very economical.
Ken Robinson
AnswerID: 81111
Reply By: Patroleum - Thursday, Oct 21, 2004 at 19:44
3.5 Jacks have a problem with fuel pumps,they continue to run but poor power and can also bring check engine light on, however this does not explain the gas problem, otherwise would be looking at the cat converter to make sure that it has not broken up causing restriction or melted the internal monolith. Could be one of many things however these 2 are reasonably common.
AnswerID: 81131
Reply By: Savvas - Friday, Oct 22, 2004 at 15:44
I know this doesn't answer the question, but I have heard that converting the 3.5 to LPG is not a good idea.
Apparently the head castings are too thin to cope with the extra heat of LPG and can crack. It is probably worthwhile trying Lucy's suggestion of a cooler spark plug range.
AnswerID: 81248
Reply By: jackablue - Saturday, Oct 23, 2004 at 12:03
My old man has a 95 se on gas & had the same problem. Frustrated the hell out of him. He had taken it to gas specialist, holden, & other mechanics & replaced various parts including power pack, spark plugs, & leads. ECU checked out ok. None of these answered the problem.
I assume you are using the long range tank as a petrol tank, check your carbon canister & see if any petrol is coming back through your overflow as his was. If so remove valve from inside petrol cap as it causes to much back pressure in your fuel tank. After removing this the problem has ceased, but found that you cannot use all the fuel in your petrol tank due to no pressure. You will only be able to use about 35ltrs as there is no baffles in the tank & you find the fuel sloshing around. He has travelled 8000kms since & had no trouble.
Hope this helps you.
Jackablue
AnswerID: 81318
Follow Up By: Jackass - Monday, Oct 25, 2004 at 09:43
Thanks everyone for your help. I'll try out your suggestions - I'll try anything!
Jackablue, your insight has given me hope - I'm off to my mechanic with a printout of your reply. Thanks heaps. As a follow up, I've had to replace to fuel pumps because they burnt out in the replacement tank. I now have a noise external high-flow pump that does the trick and extracts the last few litres of fuel (supposedly).
FollowupID: 340732
Reply By: jackablue - Tuesday, Nov 09, 2004 at 13:33
Any outcome ?
AnswerID: 83676
Follow Up By: Jackass - Tuesday, Nov 09, 2004 at 14:01
Not yet. I've been up on the Gold Coast for a week and since then I've been offered a very good deal on a LandCruiser from a friend so I'm looking at selling the Jack very soon (if I can get enough for it). Any idea how much it cost to get you father's vehicle fixed? It's it not too much, I'll get it done when I get the roadworthy. His symptoms seemed identical to mine.
FollowupID: 342588
Reply By: jackablue - Thursday, Nov 11, 2004 at 09:11
It took a pair of pliers & about 30 seconds to rip the round plastic valve & the diaphragm out of the fuel cap. He has also told me that around town he is getting down to the last 10ltrs in the tank & is very happy now. He thinks that when he was towing the fuel would slosh around more due to the caravan push,pull, up & down action making it harder for the fuel to be extracted.
At most it will cost you a new fuel cap.
Let us know how you go.
Jackablue
AnswerID: 83966
