free wheeling hubs
Submitted: Thursday, Oct 21, 2004 at 21:07
ryna
hey everyone
why does everyone tell me its bad to drive with your hubs locked if youre not in 4wd? dont the hubs just 'free wheel' when locked, and then only 'drive' when you shift into 4wd. Just curious, because sometimes i forget to turn my hubs back to 'free' after 4wdving, and i want to know what damage it can cause.
thanks
Ryan
Reply By: Leroy - Thursday, Oct 21, 2004 at 21:12
It doesnt cause any damage. It's good to engage them every month so the front driveline gets a bit of a lube etc. You will find the steering a little heavier and may use a little bit more juice also.
Leroy
81146
Follow Up By: ryna - Thursday, Oct 21, 2004 at 21:16
thanks alot, my hub is screwed but i wanted to go 4wdving, so i unbolted it, manually pushed it in so it locked, and then put the casing back on, so my hubs will be locked for a few days til i get time to go get a new hub ;)
340427
Reply By: Jimbo (WA) - Thursday, Oct 21, 2004 at 21:14
Ryan,
Generally it's NOT bad to drive with your free-wheeling hubs locked and the transfer case lever in 2wd. Almost all mining sites for example leave their hubs in the locked position all the time because of the amount of 4wd ing required.
The only reason I've added the word "generally" in the above statement is to cover my arse in case there's a vehicle I've never heard of where it's not recommended. IMHO you could run your vehicle with the hubs locked for the whole lifetime of the vehicle without any problems at all. Most of the reasons for not doing so are "old school" and no longer valid on modern vehicles.
81147
Reply By: Member - Sand Man (SA) - Thursday, Oct 21, 2004 at 21:19
ryna,
I don't think it is "bad". It does mean that with the hubs locked, the front drive shafts etc. are also turning, thus putting unnecessary wear on these components.
But you are not going to stuff something up if you leave them locked on an irregular basis.
In fact, it is good practice to lock the hubs and drive for a minimum of 20 kilometers or so once a month, to enable the components to be lubricated.
Just my 50 cents worth mate.
81148
Reply By: Utemad - Thursday, Oct 21, 2004 at 21:24
Some of my friends look down on others now they have 'upgraded' to vehicles with auto hubs. However I just lock
mine in at the last fuel stop or so and don't unlock them til a fuel stop on the way home.
My handbook even says to lock them in for 30kms every month to keep things lubed.
81151
Follow Up By: Flash - Sunday, Oct 24, 2004 at 08:41
Give me manual hubs any day. No contest.
340633
Reply By: Savvas - Thursday, Oct 21, 2004 at 21:43
The only downside is that if you leave the hubs locked in unnecessarily, you increase the drag on the front axle and use a little bit more fuel as a result. You are not likely to break anything though.
81154
Reply By: Rossco100series - Thursday, Oct 21, 2004 at 21:53
Hi Ryan
Leroy is correct but fuel consumption will go up. I engage
mine once a week and drive to and from work this turns the crown wheel in side thus circulating oil around and heating the bearing grease and circulating it. Also it stops what is called brenelling ( any one in the bearing industry should know ) it's, when the bearing sits in one spot and from the vibrations where the balls contact the in and outer raceways of the bearing it starts to chip of the case hardening thus shortening the bearing's life.
Rossco
81157
Reply By: Andrew from TrekTable - Thursday, Oct 21, 2004 at 22:14
Ryan,
I agree with all previous comments but also want to point out that the crown wheel in your front diff is not completely immersed in oil. The top half is exposed to air. Any condensation you have in your diff will result in a thin film of
water sitting ontop of that oil, all combining to create slight surface rust on what should be a very clean and shiny crown wheel. This is obviously not good.
I've seen diffs that were not used enough (ie not engaged by locking the hubs) and this rust created havoc and greatly reduced life expectancy.
So it's a good policy to lock them regularly for better lubrication. Plus, you will know that everything is working fine. You don't want to find out that something is wrong when you really need 4WD! Better to test regularly.
My 2.2cents worth (inc GST).
81162
Reply By: Bilbo - Thursday, Oct 21, 2004 at 22:37
On a Ford Maverick ute, I left my hubs locked in after a prospecting trip up around
Meekatharra. Went all the way back to
Perth (800km) with 'em in at around 100kmh. Result - burnt out both internal oil seals that stop the diff oil from contaminating the hub grease - sloppy mess. Plus cut a groove in the drive shafts that had to be metal sprayed and machined as the new oil seals wouldn't stop the oil.
Bilbo
81169
Follow Up By: Member - Clive G (WA) - Friday, Oct 22, 2004 at 22:31
Bilbo, yes that happened to a mate of
mine as
well, after new seals where put in, it still wouldnt stop the leak,
Clive
340540
Reply By: Rosco - Bris. - Friday, Oct 22, 2004 at 07:32
Ryna
One point not mentioned above is that it's not that long ago that 4WD's left the factory with the front hubs permanently locked. Free wheeling hubs were an after market accessory ppls put on themselves.
If it's not a constant 4WD vehicle it makes no difference, other than the comments about turning extra bits, fuel consumption and the need to lubricate all those turning bits.
81184
Follow Up By: Ian from Thermoguard Instruments - Friday, Oct 22, 2004 at 07:44
Gees Rosco, you just beat me by 'that' much!
340452
Reply By: Ian from Thermoguard Instruments - Friday, Oct 22, 2004 at 07:42
Locked hubs shouldn't cause a problem. Remember, for a couple of decades no common 4WD came with FWHs. All Land Rovers, Landcruisers and Nissan G60s had fixed front hubs, as standard. FWHs were an accessory item only. And now all superior(?) 4wds [Range Rovers, Land Rovers post Series III, etc.] have permanent 4WD, so the front axle components are always in use - and these don't suffer any premature failure of these components AFAIK.
I suppose it's possible some manufacturers have down-graded some front axle components on the assumption that the standard FWHs would only be locked for part of the time but it sounds unlikely to me. That said, I can't explain what may have happened in Bilbo's case but find it hard to believe the locked hubs were the only factor leading to the seal failures.
81187
Reply By: Member - Brian (Gold Coast) - Friday, Oct 22, 2004 at 09:06
Mine are in quite a lot.... mostly 'cos I forget to unlock 'em! But a mate who has a 95 GQ like
mine has had his engaged since the day he picked it up.... 7 years ago!!! He believes it's better to have the oil circulating at all times..
We do unlock ours from time to time, but generally they're "in" and no damage has occurred so far!
81199
Reply By: floyd - Friday, Oct 22, 2004 at 14:54
Should run the hubs locked (in 2WD) for40 or 50 kms before actually using 4WD so as the diff oil warms up. Broken axles can occur when people lock the hubs just before using 4WD and putting the front end under excessive load when the oil is cold.
LSD's also work better after the oil gets up to a warm temperature. Can also take a bit of time in the morning for the LSD to actually work. On my Hilux it takes about 15 kms before I can feel the diff working properly.
81239
Reply By: Phil G - Friday, Oct 22, 2004 at 23:01
The other benefit of locking hubs is that you might extend the life of the front diff bearings. They don't like sitting still on the corrugated roads. All that vibration can cause the rollers to work on one spot and make the bearings rough.
81289
Reply By: D-Jack - Saturday, Oct 23, 2004 at 15:58
What about the fact that with each hub locked there is absuloutely no give in the axle line. What I mean about that is when you go around a left corner for instance, the left wheel turns less than the right wheel has to meaning there would be twist (or attempt twist) in the axle line. Wouldn't this lead to much more pressure on the axle and hubs, and also mean the tyres would scrub more as the axle resisted the turn that the outer wheel wanted to make? I'm no engineer but I always thought this was the reason not to lock them in full time. Otherwise, there the front hbus would me manufactured locked in without the option to disengage????????????? I know I'm probably completely wrong, so if anyone can correct me I'm
well and truly open to it!
81333
Follow Up By: Jimbo (WA) - Saturday, Oct 23, 2004 at 18:25
D-Jack,
I'm no engineer either, but I think that this "twist" (transmission wind-up) you are talking about is not a problem because the diff can sort it out, as it's meant to; and also because the front driveline is still disconnected at the transfer case.
340578
Follow Up By: Flash - Sunday, Oct 24, 2004 at 08:47
Sorry D-Jack, that's what you have a differential for... (nothing to do with free wheel hubs.)
..and why constant 4 wheel drive vehicles have a 3rd diff (between front and rear).
340634
Follow Up By: Ian from Thermoguard Instruments - Sunday, Oct 24, 2004 at 21:07
Yes, D-Jack, Jimbo and Flash are right. That's why all driven axles have a differential in the middle of them. Your point about potential 'twist' applies equally to the rear axle of a 4wd as the front one, but they all have diffs.
"Otherwise, there the front hbus(sic) would me manufactured locked in without the option to disengage" -
well yes, that's exactly what the situation was for light 4WD vehicles from the advent of the WWII jeep, through Land Rovers from 1948(9?) and LandCruisers from the late 1950s, until the mid 1980's when factory-fitted FWHs started to appear (please see several posts above).
And as Flash points out, permanent 4WD vehicles have a third diferential in the transfer case to prevent wind-up between the front and rear axles.
340687
