using metho to help water mix with diesel?
Submitted: Friday, Oct 22, 2004 at 13:40
pathfinder
Hi - related to post two below (17224) is it ok to add methylated spirits to your diesel fuel
tank to help any
water in the bottom of the
tank (assuming you don't have a drain in bottom of
tank) mix with the diesel and be removed from
tank and combusted? I know this works for petrol tanks but am wondering if it is also possible for diesel...
Reply By: Ian from Thermoguard Instruments - Friday, Oct 22, 2004 at 14:28
Don't know if methylated spirit (basically ethanol) is miscible (mutually soluble) in diesel as it is in petrol. The other concern is that it may reduce the lubricating properties of the diesel to some extent. AFAIK, all the commercial biocides/
water dispersants claim to add lubricity to the diesel to protect pump and injector internals. And their pretty cheap, so if you can't physically drain sediment/
water from the
tank, why not use a bottle say once a year?
81234
Reply By: hoyks - Friday, Oct 22, 2004 at 14:43
I don't think that methanol will mix with diesel, I saw a thing on telly about a trial of dieselahol powered busses in the ACT and they had to use an enzyme to get the two to mix properly.
I was glanced at a story in an air safety magazine (didn't read the whole thing so if I am wrong I am happy to be corrected) and they had a test to see if there was methanol in the fuel by mixing in a measured volume of
water into the fuel then measuring the volume of the fluid that separated out of the fuel. The methanol would mix in with the fuel, but would separate out in the presence of
water. I can’t remember if it was AVTUR or AVGAS though.
81236
Reply By: Bob BLW - Friday, Oct 22, 2004 at 14:49
Pathfinder, I was thinking of the metho trick for the people without drains on their fuel tanks, ie non Toyota owners, when I replied to (17224), I have a few tech reps in the oil industry that I can contact ( they are not answering their phones) I will ask the question and post a reply sometime in the future.
An experiment would be to put equal parts
water, metho and Diesel in a glass jar and shake it up and if in 24hrs it settles out to two fluids I would say it should not be done and if it did mix I would be very suprised.
81237
Reply By: Davoe - Friday, Oct 22, 2004 at 14:52
dont know if it would work and I wouldnt advise it because your fuel systm has features to trap
water you dont want
water bypassing these features - BECAUSE
water does not not ignite and it doesnt compress you should know how bad
water yhrough your air intake is for a diesal -
well it is just as bad through your fuel delivery
81238
Reply By: sub - Friday, Oct 22, 2004 at 22:10
try using product called FUEL SET. check out www.liquideng.com.au
worked
well for me when i got a
tank full of comtaminated fuel.had to replace fuel filter and then run this stuff through for a few
tank fulls.used alot in the marine industry.
81286
Reply By: Bilbo - Saturday, Oct 23, 2004 at 21:22
Be careful - "methylated spirits" is not the same thing as "Methanol". Methanol will help remove the
water. The other won't
Bilbo
81382
Reply By: Mike-TS - Sunday, Oct 24, 2004 at 21:19
Methylated spirits will pick up
water as
well. Use about 20%
water in your Metho
camping stove and it doesn't smoke.
Can't see why there would be a problem with diesel. Run
tank to empty, put in litre of metho, run to petrol station over bumpy road on sub
tank then fill with diesel. Sounds logical!?
But in fairness I don't really know so advice is opinion not factual!
81480
