Marks Adapators
Submitted: Monday, Oct 25, 2004 at 12:51
Member - Collyn R (WA)
Has anyone out there any firsthand experience of the Marks adaptor unit that lowers the low-range transfer box ratios, and also increases the fifth gear ratio by 8%?
Vehicle is a 78-series Troopy.
In particular: is it noisier? Is the 8% fifth-gear increase worthwhile. Any known problems?
Collyn Rivers
Reply By: Baz (NSW) - Monday, Oct 25, 2004 at 14:36
Collyn i don't have knowledge on these but it has been talked about on this
forum, at the top is a search option type in Marks adaptors then below is active archive or both click both should bring a lot of threads on this.
Baz.
81574
Reply By: fourstall2000 - Tuesday, Oct 26, 2004 at 10:18
Collyn,
I had a set of low range gears from marks fitted in a auto gq Nissan,and currently a set in my 3.0 litre Nissan diesel auto.
They are great,they do not change the high ratio,only the low.
They give me Better than manual gearbox reduction on downhill speeds,and have turned the auto into a real bush performer.
Marks products are always of the highest quality.
81704
Reply By: Member - Collyn R (WA) - Wednesday, Oct 27, 2004 at 09:04
Thank you for the info
Collyn
81870
