High Lift Jacks
Submitted: Monday, Oct 25, 2004 at 15:01
ThreadID: 17294 Views:2593 Replies:6 FollowUps:7
How practical is it to use a high lift jack on vehicles without a bull bar to hook onto? I have a Navara dual cab and it looks like the jack might do more damage than good. Any advice please...
Reply By: Leroy - Monday, Oct 25, 2004 at 15:09
I couldn't see how it could be used unless you have a suitable jacking point. Some bull bars are suitable and others have adapters. When I have seen them used they look very unstable. Are you thinking of purchasing one?
Leroy
AnswerID: 81580
Follow Up By: Leroy - Monday, Oct 25, 2004 at 15:25
Should of mentioned also that I saw a vehicle jacked up from the bullbar in the mud with a hilift and it moved to the side falling off the jack.
Leroy
FollowupID: 340783
Follow Up By: BrianR - Monday, Oct 25, 2004 at 15:29
Yes I was thinking of getting one but had reservations. Have even more reservations now! Don't think it is the right tool for me.
I once had one of those bull-bag jacks but when it came time to use it I discovered a hole in my exhaust (that was down in the mud) that made it useless.
FollowupID: 340786
Follow Up By: Leroy - Monday, Oct 25, 2004 at 15:42
Sounds like a good hand winch may be the go. I have one and they are hard work but a saviour if really needed.
Leroy
P.S. I now have an electric!
FollowupID: 340788
Follow Up By: Member - Haldo (Sydney) - Tuesday, Nov 02, 2004 at 00:29
In the hands of one who has received training in the correct operation of the HL jack, they are better than not having one. Imagine being stuck in a rut and not having anything to give that little bit of lift.
Solution is to liaise with a local 4WD club and get as much hands-on training and help from like-minded people. You will find a lot of people who have experienced the shortfalls (pun?) of the jacks where their vehicles have fallen off them, but they come to understand the importance of securing the vehicle to the jack.
There will be times when you will wish you had bought the one you saw in the shop.
Hop under your truck and have a look for somewhere to hook it onto, remembering there are adaptors available to secure the lifting point to your vehicle. Consider a piece of an old tyre to go between the bumber and the metal of the jack. It might protect it somewhat.
Remember safety is foremost, especially when having others around the vehicle. Make sure you have everyone (especially kids) well away from the vehicle.
I have been in situations where I would still be there today if it were not for the HL jack. I found out the hard way that I should have chained it to the vehicle and should have had a larger base plate for it to be bolted temporarily to. With experience being the best teacher and hindsight (I think it's really called criticism from armchair experts [ mates? ]) I think I have a fair idea of how to use them now.
Drop in to your local 4WD equipment outlet and tap their wealth of experience.
All the best.
FollowupID: 341722
Reply By: flappan - Monday, Oct 25, 2004 at 15:11
Advice please ?
Yeah . . . dont.
IMO , highlift jack would have to be one of the most dangerous pieces of gear around.
The potential hazards are plenty
In the wrong hands and with the incorrect mounts . . . . well . . . I wouldn't go there.
Having said that though , in the correct hands used the proper way , they ARE handy to have , but, I think , you either do it the right way , and have all the correct highlift mounts , or you make alternate arrangements. Not something to do half heartedly.
AnswerID: 81581
Follow Up By: Davoe - Monday, Oct 25, 2004 at 15:41
you are right they are potentially dangerous as are split rims andsnatch straps and winches etc. It would be wrong to think that just because these things are sold over the counter at autopro by a kid making cash after school that they are safe without adequate training and knowing the risks and how to minimise them. When I started work we were given an induction on all these things. We use hublifters on our l/c utes and I reckon they are the way to go. This field season I have used the hi lift 4 times 3 when I was hung up on stumps and once when bogged on the edge of a salt lake to jack the vehicle out of the mud and placing bog boards under the wheels letting the tyres down and just driving out on top of the crust
FollowupID: 340787
Reply By: Member - Jack - Monday, Oct 25, 2004 at 15:40
Flappan got it in one. Correctly set up, they are handy at times. Not set up so and they are as dangerous as anything else you can think of. One benefit to their basic instability is if you are stuck, you can jack them up and push your vehicle off to more solid ground. Saw it done and have since done it myself. With me, the highlift is the last resort before walking.
Jack
AnswerID: 81584
Follow Up By: Member - Roachie (SA) - Monday, Oct 25, 2004 at 18:07
Jack is quite correct.....I have seen a vehicle turned a full 180 degrees in it's own body length by the "raise then push off" method. Safe in the right hands....don't try to lift a vehicle with plastic bumper.
I used mine on our recent Cape York trip when Pud's camper trailer shocky came adrift and the coil spring popped out. I raised the back end of his TrakShak with the high lift so the coil could be put back in place. A normal jack simply wouldn't have been able to get the body up high enough.
FollowupID: 340807
Reply By: Member Eric - Monday, Oct 25, 2004 at 18:39
Hi lift jacks should only be used for swinging a vehicle across , like what hase been discribed above & only to take the weight of the vehicle and then to place a standard jack under to lift the wheel off the ground . If you dont have front and rear steel bars , dont bother .
AnswerID: 81605
Follow Up By: Davoe - Monday, Oct 25, 2004 at 21:12
I disagree we use hub lifters for the work vehicles and have no bullbar fittings and they work a treat, the times I have used a high lift jack there is no way the standard yota jack would have done the job. one particulary bad hang up I got needed us to jack nearly to the top of the high lift with hub lifters to get it off. also the idea of crawling under a vehicle bogged in a salt lake sound messy
FollowupID: 340830
Reply By: Willem - Monday, Oct 25, 2004 at 20:49
My old Hi lift is languishing in the corner of my shed. Have carted the bloody thing all over the country and have used it a few times but not enough to warrant the extra weight. Got my Zook bogged on a log once in a pool of mud. The winch decided it wasn't going to work so I jacked the little truck up 16 times and pushed it off the jack to turn it around. Energy sapping work. Hi Lift jacks have their uses but I only take mine when going on a Big trip. Yes they are dangerous if you don't know what you are doing with them but so is sneezing(you could bust a blood vessel in your head)...:o)
AnswerID: 81628
Reply By: geocacher (djcache) - Monday, Nov 01, 2004 at 23:04
High lift and a couple of drag chains and voila - a hand winch.
Great if you need to go back a few feet (slowly but surely) and the Warn is permanently mounted on the front.
And it can be used as a jack too....
And a tirfor can be used as a chock while the jack is doing the work.
I bought the HiLift cos it had multiple applications.
AnswerID: 82655
