nissan patrol gu engine conversion 2.8 to 3.0
Submitted: Wednesday, Oct 27, 2004 at 22:50
ThreadID: 17373 Views:5724 Replies:4 FollowUps:5
hello ,can anyone tell me if it is possible to convert a 2.8td to a 3.0td?
Reply By: Member - Captain (WA) - Wednesday, Oct 27, 2004 at 22:56
Anythings possible, but WHY? A new 3.0TD would be much more than a 6.5 Brunswick!
Captain
AnswerID: 82022
Follow Up By: craigg - Wednesday, Oct 27, 2004 at 23:04
hi captain,what you mean 6.5 brunswick?
i think i should have worded question better,"can you pull a 2.8td out and bolt a 3.0td in without too much fuss?
FollowupID: 341169
Follow Up By: Member - Captain (WA) - Wednesday, Oct 27, 2004 at 23:19
Hi Craigg,
Nah, the 2.8TD had the small gearbox I believe (from memory!) but it was also a 6 cylinder wheras the 3.0TD is a 4 cyclinder and i reckon the engine mounts are all wrong. The radiator on the 3.0TD is larger, as is the intercooler etc...Once you get past that, the wiring harness CPU and general wiring would require a complete harnass changeout, perhaps the hardest job of all.
While i reckon the 3.0TD is a good engine (others vehmently disagree!!!!) I don't think its the right one for a swap. A better option is a V8 diesel as installed by say brunswick diesels here in WA.
Captain
FollowupID: 341172
Follow Up By: craigg - Wednesday, Oct 27, 2004 at 23:36
captain,thanks for your replies. sounds like i should be looking for a new 2nd hand 3.0 rather than mods to a 2.8 as one of the biggest selling points for me is fuel economy.
by the way your bus looks very nicely setup
craig
FollowupID: 341177
Reply By: Truckster (Vic) - Thursday, Oct 28, 2004 at 09:23
The cost of a 3.0 would be moer than a V8 Turbo DIesel 6.5 that he mentioned.. You also get better power, economy as the engine doesnt have to work hard, and they sound SWEEEEEEEEEEeeeeeeeeeeeeeeeet..
Im thinking of the same engine swap, have been offered a GU 4500 petrol for $22k, $10-15k for engine+swap - the sale of the 4.5, and I have an awesome truck!
AnswerID: 82047
Reply By: bruce.h (WA) - Thursday, Oct 28, 2004 at 14:11
Gday all
the 3lt motor for ny gu cost the dealer $13750 +gst direct from nissan australia, That was without the dealer putting their mark up on it or the installation .
so you would be looking at quite an expencive exercize
Regards Bruce
AnswerID: 82086
Reply By: Peter Guy - Thursday, Oct 28, 2004 at 15:49
Can I be cheeky and ask you for your rocker cover off your 2.8 if you upgrade? My 2.8 rocker cover has a small crack!
AnswerID: 82095
Follow Up By: Truckster (Vic) - Thursday, Oct 28, 2004 at 16:42
is it the same as the td/tb42? i got a spare in the shed
FollowupID: 341245
Follow Up By: Peter Guy - Thursday, Oct 28, 2004 at 16:49
Thanks Trukster but I'm pretty sure the RD 28 rocker cover will be very different to the 4.2. But I will check.
FollowupID: 341246
