Laptop maping guru needed
Submitted: Thursday, Oct 28, 2004 at 21:09
ThreadID: 17397 Views:2515 Replies:6 FollowUps:19
does anyone know if you can run ozi explorer and discover oz at the same time ?
Reply By: Member - George (WA) - Thursday, Oct 28, 2004 at 21:18
I know Oziexplorer but what is discover oz ?
AnswerID: 82165
Follow Up By: Member Eric - Thursday, Oct 28, 2004 at 21:21
discover oz , is another maping program desighned for magellen gps units , good for adding maps to sd card
FollowupID: 341288
Follow Up By: Member - George (WA) - Thursday, Oct 28, 2004 at 21:29
As I see it you can have Discover Oz running in the back ground whilst you are running ozi Explorer.
But you cannot view both of them at the same time but you can switch from one to the other, similar to running, for instance, Microsoft Word and Exel at the same time and switch from one to the other
Hope that makes sense
FollowupID: 341289
Follow Up By: Member Eric - Thursday, Oct 28, 2004 at 21:41
I can view both programs at once by splitting the screen , bit i am trying to have the GPS log both programs at once . It seems that it cant be done
FollowupID: 341293
Reply By: Member - Luxoluk - Thursday, Oct 28, 2004 at 21:19
Hi Eric,
It didn't take you long to get into the swing of things? LOL You have been taught well!!
I run both but not simultaneously. To do it I reckon you would at least have to run it off the Magellan GPS as that's all, from my experience, Discover Aus will recognise. The issue then becomes will Oxiexplorer recognise the GPS as well. My gut feeling is that its quite likely provided the required comms format can be activated!! I'll try it over the weekend...let me know if you have any succes in the meantime. Cheers
AnswerID: 82166
Follow Up By: Member Eric - Thursday, Oct 28, 2004 at 21:20
lol , actually ill try it now , see what happens
FollowupID: 341287
Reply By: Member - Luxoluk - Thursday, Oct 28, 2004 at 21:27
Hi Eric I should have asked earlier but is there something specific you are trying to achieve by this, eg waypoint, track log sharing. If that's the case then I have worked my way through this previously and happy to share info. Cheers
AnswerID: 82169
Follow Up By: Member Eric - Thursday, Oct 28, 2004 at 21:38
Just wanted to log my trip on both programs , I just tried and if I open one program and activate gps log , it ocupies the com port for the other program and vise versa . So I am guessing it cant be done
FollowupID: 341291
Follow Up By: Member - Luxoluk - Thursday, Oct 28, 2004 at 21:49
Hi Eric
I suggest you try logging your trip/waypoints on Discover Aus. Down load your files to the laptop in Discover Aus. Switch to OxiExplorer and then download again from the Magellan into OxiExplorer. The common link between the two systems is your GPS unit and if you use this as the medium to share you can swap files between the two, eg. if you already have old files in Discover Oz format but want them in oxiExplorer just down load them into your GPS and suck back into OxiExplorer. Works a treat on my Magellan Colour. Cheers
FollowupID: 341295
Follow Up By: Mad Dog (Victoria) - Thursday, Oct 28, 2004 at 21:50
That's exactly what happens Eric however it can be done with a little program that allows multiple programs to share the same com port. For the life of me I can't remember what the programs is called, I was looking at the website a month or so ago but didn't bookmark it. I'll try and track it down and get back to you.
FollowupID: 341296
Follow Up By: Mad Dog (Victoria) - Thursday, Oct 28, 2004 at 21:54
Well that didn't take long, found it already.
http://franson.biz/gpsgate/
GpsGate lets you share one GPS between several applications. GpsGate can create any number of virtual serial ports which most NMEA enabled GPS applications can connect to.
FollowupID: 341297
Follow Up By: Member - John (Vic) - Thursday, Oct 28, 2004 at 21:56
Mad Dogs got the answer, you need to split the port access, only can be done with the specific program that he has mentioned and now can't find.
The pressure is on Ray, get your finger out and find it for us. LOL
FollowupID: 341299
Follow Up By: Member - Luxoluk - Thursday, Oct 28, 2004 at 22:01
How are you Ray and John? Nearly got a reunion going here! LOL Have you guys cleaned the Wombat State Forrest out from underneath and inside your vehicles yet? And John, one for you, have you got that mapping software up and running as yet?? Cheers
FollowupID: 341304
Follow Up By: Mad Dog (Victoria) - Thursday, Oct 28, 2004 at 22:14
I found it John the site is above.
All is well here Leigh, flat out at work at the moment. Well I managed to give the engine a clean but It still need some work to remove the muddy stains. The rain has helped with the body but I'll have to hit the car wash to clean underneath but I'm thinking it's hardly worth it as I might hit the dirt again this weekend.
FollowupID: 341306
Follow Up By: Member - John (Vic) - Thursday, Oct 28, 2004 at 22:29
Hi Guys
Spent a bloody age with the Gernie under the truck getting the mud out.
The carpet dried OK and only required a vacuum to bring it up like new.
The winch problem cost me $150 to fix, turns out that the earth wire/connection behind the brush carrier had corroded and was causing the intermittent contact problem.
Leigh as for OE Have loaded it but have not had enough time to learn to drive it as yet.
Leaving tomorrow morning for 5 days up the Avon and McAllister river area with the Toyota Landcrusier Club will wash the underside of the truck once or twice in the drink up there should be fun.
Will have to organize a trip up there with you guys soon great place.
FollowupID: 341310
Follow Up By: Member - Luxoluk - Thursday, Oct 28, 2004 at 23:04
Good to hear from you guys. I hope you all have fine weather for your trips. It'll be like Bourke Street at peak hour up in the high country this weekend so be carefull John. Ray I had a look at that site you posted before and will download their free trial amd have a play. Have to work on Monday so time will be available. Good to hear you ae all doing well and I hope there's plently of O/T for you Ray!! Catch up again soon. Order gets placed next week so should be out to play in Feb...oh so long!! Cheers
FollowupID: 341324
Follow Up By: Member - John (Vic) - Friday, Oct 29, 2004 at 00:30
February, Jeez all the water will have disappeared out of them Wombat Bog holes by then.
How are we going to get it dirty, Hmmmm I think a High Country weekend will have to be the way to go.
As for this weekend being busy in the H/C I think Robe will be worse. LOL at least there is more room in the H/C.
We have 8 trucks in my group this weekend.
Leigh what option's you getting fitted from scratch ?
FollowupID: 341329
Follow Up By: Mad Dog (Victoria) - Friday, Oct 29, 2004 at 14:08
A high Country trip sounds good John, can't stand that bloodly hot summer weather when camping though.
Guys, I've just tried gpsgate and it's working fine with a magellan 320, discoveraus v1.00b and oziexplorer 3.95.4d. I set the gps into simulate mode and both programs are tracking well at the same time. Took about 1 minute to have it all running :) I'll have a play for a week, if I consider it worthwhile I may just purchase it.
It will be a long wait for the troopy Leigh but worth it in the end eh. Hopefully you'll be able to hitch a ride with John again to get your fix.
FollowupID: 341385
Follow Up By: Member - Luxoluk - Friday, Oct 29, 2004 at 14:23
Hi Ray. I have only just this minute finished downloading the trial version. Glad to hear you got it working. I'll try this weekend. Yeah..I'm looking forward to placing the order next week. I have one more quote to arrive on Monday then its off to place the order. Have got separate quotes for accessories and so far quite happy with the price offered on a bundled package. Cannot wait to get back on the track again and really looking forward to the Canning in May 2005. I think I'm just about organised to go except no wheels!! Might go and wring the neck of my V8 Commodore over the weekend for a rush?? Cheers for now...must get back to work!!
FollowupID: 341387
Follow Up By: Member Eric - Friday, Oct 29, 2004 at 17:10
i downloaded the program and couldnt get it to work , gave me the same conflict . i will try again tonight
FollowupID: 341399
Follow Up By: Mad Dog (Victoria) - Friday, Oct 29, 2004 at 17:52
Eric, Make sure the GPS, Oziexplorer, discoveraus and gpsgate are all set at the same baud rate, I used 9600. Configure gpsgate for the physical port that the gps is connected to, in my case it was com1. Setup two virtual ports in gpsgate I told it com 5 and com 6. Configure oziexplorer to use com 5 and fire it up, you should have connectivity.
Fire up discoveraus...can't remember if I had to configure anything there or if it found it automatically (I'm at work now so cant try it) but try connecting to the gps if it ask any questions tell it com 6 and 9600bd
FollowupID: 341404
Reply By: theratt - Thursday, Oct 28, 2004 at 21:38
i have tried running both and cant do it, the problem i have is the com ports on the computer can only be accesed by one program at a time, i think if you want to run them both at the same time you need two gps units connected to different com ports
AnswerID: 82171
Reply By: Member - Gerk Yorke Pen (SA) - Thursday, Oct 28, 2004 at 22:48
If anyone can get gpsgate working on a navman 4410 blue tooth I would like to here about it.
AnswerID: 82181
Reply By: Wazza (Vic) - Friday, Oct 29, 2004 at 16:06
Eric,
You should also be able to split the serial line at your 9 pin connectors (half way between the GPS and the laptop) and send one each to both your USB ports (ie comm 5 and 6). You will need a splitter and a second serial to USB converter. Use Discover Oz on Comm 5 and Exploroz on Comm 6. If you get confilicts, then you want to use only pins 2 and 5 so that you are only getting one way comms from the GPS to the laptop and not back again (usually on pin 3)
If you ask Mad Dog nicely enough he might make one up for you ... hehe
Have a good trip. i got called back to Perth early and fly out Monday.
Wazza.
AnswerID: 82250
Follow Up By: Mad Dog (Victoria) - Friday, Oct 29, 2004 at 18:10
Thanks Wazza just what I need, fiddling around wiring up rs232 cables is not my idea of fun. Had enough of that when I was into packet radio and gprs. Trouble these days is that my eyes are half shot, no not blood shot, and I can't see the bloodly wires. Eric should be able to get gpsgate working ok and then be able to run any mumber of applications.
Enjoy ya break before work next week....cya
FollowupID: 341406
