L300 - 4G63 TO 2.6ltr SIGMA CONVERSION
Submitted: Friday, Oct 29, 2004 at 14:31
Wayne&Tricia
Hi, just wondering if anyone has completed this conversion and can let me know whats involved, and wether its worth it or not.
thanks
wayne
Reply By: navaraman - Friday, Oct 29, 2004 at 14:39
Haven't done the conversion but I've replaced two cylinder heads on 2.6 Sigma's in the past, they have a tendency to be very weak.
82239
Reply By: Member - Robb (NSW) - Friday, Oct 29, 2004 at 14:44
I havent done the conversion either, but I had an L300 a few years back and had the original engine turbo charged to give it more herbs...
82240
Reply By: flappan - Friday, Oct 29, 2004 at 14:52
I haven't done it myself , but spoke to someone who has , a while back.
He was very happy with it , and was relatively easy to do. In physical size , there is no difference bewteen the 2.6 , and 2.0l. However the Gearbox IS different , and you will need one matched to the 2.6.
The problem I think , is getting hold of a decent 2.6 motor. Most 2nd hand ones blow that much smoke , and rebuilt , recon motors , would cost as much as the vehicle itself.
82241
Reply By: Simon - Saturday, Oct 30, 2004 at 06:18
There are 2 different sizes of bellhousing patterns used on 4G63 in L300. The smaller ones are 110mm across the top 2 bellhousing bolts(where it bolts to the back of the engine) and 310mm across the bottom 2. The bigger ones are 130 and 330mm. Sigma 4G54 engines also had small and large bellhousings. The automatic transmission engine was the small one and the manual the big one. Sigma engines are so old now that you would have difficulty in finding a good secondhand one. Have you considered using a 4G64 2.4 litre out of a later model L300. It just so happens that I import secondhand engines from Japan, and also happen to have a 4G64 in stock. If you are interested or need any further information or advice, email me at scevans@optusnet.com.au
Simon
82292
