Best Engine
Submitted: Friday, Nov 19, 2004 at 07:36
ThreadID: 17919 Views:3255 Replies:6 FollowUps:6
Hi all just wondering what the best turbo diesel is to get for an 80 series?
Reply By: theshadows - Friday, Nov 19, 2004 at 08:21
I'd say one that works! If it dosnt work then at least the fuel consumption would be cheep :-P
shadow
AnswerID: 84967
Follow Up By: jbwetzels - Friday, Nov 19, 2004 at 08:22
now why did'nt i think of that
FollowupID: 343613
Reply By: Davoe - Friday, Nov 19, 2004 at 10:53
Do you mean the best turbo to put on your 80seriees 1hz or a complete turbo diesal? I guess the best toyota turbo diesal at the moment is the one in the 100s (1hd-fte I think) To get one of these fitted to your 80 you would be talking big money and it may even be cheaper to it a brunswick td v8. The td fitted to the 80 series (I forget its deignation ) would be the best option for a straightforward fit but I dare say there will be plenty of xtra nick nacks that would set you back. Also this motor was not up to toyotas standards for reliability and was pulled from the market. The td from the 60serios (12ht)was a beuty although it now pales against the modern tds. Vast diferences in drivelines would make fitting one of these a problem. As for fitting other makes of td - get your wallet out.
AnswerID: 84985
Follow Up By: jbwetzels - Friday, Nov 19, 2004 at 11:04
ok then adding a turbo the motor is not a good cost option, i have been told about tuned extractors that give almost as much power as a turbo is this true??
FollowupID: 343633
Follow Up By: Davoe - Friday, Nov 19, 2004 at 12:52
adding a turbo to your existing donk would be ok, certainly your cheapest easiest option - plenty of people do it I personally would have a few reservations as these motors were not originally built to take a turbo. you would want to make sure your donk is ok in the first place. Extractors will help but not to a significant point
FollowupID: 343654
Follow Up By: 80scruiser - Friday, Nov 19, 2004 at 20:58
OK
Just fitted my turbo to my 80 series last week.
Back ground info first.
12/92 Gxl natural 1hz diesel 273 000 km.
I suggest you get a compression test done on the engine first and then get the injector pressures checked and nozzles serviced or replaced first. I suggest while its at the diesel man get the top seals in the pump replaced along with the throttle shaft seal and shaft as well. The low sulpur diesel has a habit of causing fuel leaks on older models so why not get it done at the same time. (preventative maintenance)
I fitted my kit my self as I am a mechanic who has my own business.
Give one of the sponsors of this site a call Denco as this is the kit I fitted. Its usual retail price is around $3100 including a full exhaust system. It will cost you about $500 bucks roughly to fit depending on how they fit the oil drain. Some places just drill a hole in the sump and screw in a fitting. The best way is to remove the sump and braise in the fitting. Thats probably one of the biggest parts of the job along with fitting the damn exhaust. If you want to email me through my business site I can snap some photos of mine to send you or answer any further questions you have. I probably wouldn't put an intercooler on an older engine, don't want to overstress it and keep your boost under 7lb. The Denco kit will be preset and just pushes 7lb.
My site is www.lonards-automotive.com.au
Best of luck
80scruiser
FollowupID: 343732
Reply By: snow - Friday, Nov 19, 2004 at 12:39
Tuned extracters that provide as much power as a turbo!!!!
Difficult to imagine in my opinion
AnswerID: 84994
Reply By: jbwetzels - Friday, Nov 19, 2004 at 12:54
thats what i thought about the extractors, what do you reckon it would cost to add the turbo and all other stuff?
AnswerID: 84997
Follow Up By: Davoe - Friday, Nov 19, 2004 at 13:42
Plenty of info around on this Ive got a feeling it starts at about 3,500 to 6,000 for turbo and intercooler. As said previosly make sure your donk is good as putting a turbo onto a tired motor to power it up will just kill it
FollowupID: 343658
Follow Up By: Member - T-bone (ACT) - Friday, Nov 19, 2004 at 15:11
I seem to remember there was a diesel place up here that quoted around $3500 for a complete turbo installation on the 80-series atmo 4.2.....
FollowupID: 343680
Reply By: Howard T - Friday, Nov 19, 2004 at 13:09
Hi jbwetzels,
i have extractors on my series 80. yes they do make a difference and it is noticeable but not as much as a turbo.
AnswerID: 84999
Reply By: TLS - Friday, Nov 19, 2004 at 21:47
jbwetzels
Give Kenwick Motors at Kenwick WA a ring as they do Toyota conversions.
One of the conversions they do uses imported used yank Chev 5.3L V8 Turbo diesels.
Phone 08 9493 4455
TLS
AnswerID: 85090
