Up Another Inch
Submitted: Friday, Nov 19, 2004 at 19:07
ThreadID: 17939 Views:1798 Replies:2 FollowUps:2
About to add another inch lift to our 4 Runner by use of ball joint spacers in the front and coil spacers in the rear but need to know a couple of things.
Has any one got coil spacers fitted with polyair bags?Are they compatable with each other?
Does anyone know if any other OME shocks(ie 80 series/Patrol) will fit a 4 Runner/Hilux? as the ones on it are now at max travel.
Thanks Nick
Reply By: desray - Monday, Nov 22, 2004 at 01:12
I used to have 80 series rear shocks on my 4runner (22.6"" long) Rancho 5208.
AnswerID: 85318
Follow Up By: Member - Nick (TAS) - Monday, Nov 22, 2004 at 18:58
What year was your 4 Runner?
FollowupID: 343983
Reply By: desray - Tuesday, Nov 23, 2004 at 13:58
Hi Nick My 4Runner was a 91 V6 . Coils on the rear, torsion bars on the front. I also used coil spacers to lift the rear but bought longer coils later. The polyair bags will lift the car a little (should be used to keep the car level not lift it ) but these will limit the wheel travel because the spring cannot compress fully with the bag in it.
AnswerID: 85537
Follow Up By: Member - Nick (TAS) - Tuesday, Nov 23, 2004 at 17:54
Thanks desray,I already have 40mm longer springs in the back but will be lifting the front up 75mm so need a bit more in the back.The Polyairs are only used to level it out when loaded but I wasnt sure how they'd go with spring spacers.
FollowupID: 344109
