AnswerID: 360 Submitted: Saturday, Apr 21, 2001 at 00:00
David
replied:
Les, first you must work out what amperage your
fridge is drawing, eg. a 60 lt Engel running on freeze
draws approximatly 5 amps, multiply this by by the voltage, ie, 12volts, this will give you the size panel you will require in watts = 60 watt panel, this will keep your deep cycle battery fully charged, providing that you are getting full sun.ŒIf you are running your
fridge only as a
fridge and not as a freezer you wont need such a big panel as the
fridge will cycle on and off, hope this has been of some help, cheers, David.
Reply 1 of 1
