FollowupID: 345572 Submitted:
Thursday, Dec 02, 2004 at 10:42
theshadows posted:
hang a sec aussichef ......david AU was posying a follow up to bonzo post not yourse. Have a look and settle down.
It is interesting that topics like these get right out of hand.
however somehtimes people reaaly want to bleive in fairy tails and bonzo yourse is a beautie.
for the non mechanical out there the biggest restriction in a TD motor is the turbo compression hub.
Ay idle its only turning about 30k a minute. haveing an inlet device upstream or down stream from the compressions wheel dosnt matter the restrictor is the compression wheel. when the air hits the wheel the air stalls around the hub then is pumped through.
to say the turbo engine spooled up 300 rpm earlier is impossible. no if no but its a law of phyisics ,there will be no corrspondence entered. Take it out with Isaac newton if you wish.
with that i'm takeing a screen shot and posting it to nasa. i'm sure the shuttle could do with one of there.
shadow ....shhh... I keep seeing stupid people.
