FollowupID: 345778 Submitted:
Friday, Dec 03, 2004 at 09:11
GO_OFFROAD posted:
side note;-
dtronic or similar?,
though there is other things on the market, that make more grunt, none are similar to the dtronic, as the dtronic adjusts timing, as well as fuel, where as any other brand currently is no different to winding up the fuel screw on an old style pump...
Dtronic also changes what the ecu see's from the engine, and can actually help save your engine if water temp goes high [ monitoring combustion temps as water temp changes very quickly] by pulling fuel back beyond factory settings if required, by changing what the ecu see's.
Most other types change what the engine see's from the ecu, so it just keeps adding more fuel to try and make more grunt regardless of what the ecu is seeing, bit like winding up the fuel screw on the older type pumps....
