FollowupID: 347500 Submitted:
Tuesday, Dec 14, 2004 at 12:43
Dolci posted:
I brought one of the repco fridges and i have tested it.
I performed the following:
1) Ran the
fridge on gas for about 5 hours. in a very large room with no ventillation. (approx 25 deg), internal temp was about 8.5 deg, which is 4 deg higher than what the units documentation claims it can do.
2) Increased the room temperature to a constant 33 degrees.
3) Put 12 warm VB's in the
fridge.
4) After 4.5 hours the beer was cold and the fridges temperature was about 6.5 deg.
When i ran the
fridge at night on 240v (the ambient temp was approx 12 deg) the fridges temperature was 4 deg.
I have also noticed that when i run the
fridge on 240v it gets a couple of degrees cooler than gas. The
fridge is 100% level when running on gas. The documentation says that the
fridge will run 2 deg cooler on gas than 240v, which is not what i am seeing.
It comes with an ice tray, i have not been able to produce ice, even at night when its been cold.
I am a little bit worried on how this unit may perform on hot days (35+), i am looking at insulation options to improve its cooling ability, as i think the unit may not be well insulated.
I am basically after a gas
fridge for
camping and i am not sure whether this unit is going to be good enough on hot days. I think a chescold freezer might be better for me.
Any advice ?.
Dolci
