FollowupID: 345921 Submitted:
Friday, Dec 03, 2004 at 18:12
Billy posted:
porl,
You make a good point, there is often no one ideal solution for a lot of
camping needs. Summer
camping is different from winter, moving camp every day is different to staying in the one spot for a few days or more without using your vehicle. Travelling in convoy is different than going solo, with kids different to without, the list goes on. We all like to share our opinion and many have arrived at by the school of hard knox, but no one size fits all.
Personally, given the price of
camping gear relative to what else we spend our money on, I think it's worth it to buy the best for the given situatuation even if you end up with a couple of duplicates. I've found the compromise drives you crazy and is not worth it.
To use your example of lights, like you I have fluro's and also a Northstar Duel Fuel and a couple of old Tilley's. For winter and quick stays, it's the Northstar, convenient and gives out some heat. Longer stays justify getting out the Tilleys for the extra heat (and just gotta love the sound). In summer there is nothing worse than sitting around a hot light so the fluro's come into play. Similarly,
cooking over a fire is a PITA in summer that somehow takes on a new attraction on a -4C morning.
FWIW on stoves etc, we've found the cast iron gas rings expensive on gas (if that's a problem) but good for the wholesale jobs eg: heating a 20L drum of
shower water when you can't have a fire. For regular use we have one of the two 10,000BTU electronic ignition regulated Coleman LPG stoves that have already been univerally lauded here. Just not having to find the bloody lighter every time is worth it! But we also carry and old fashioned fire grille/plate in winter!
I know some of the purists think that a certain way is nirvana but it's just not the case for most people. Like the argument about only having to carry one type of fuel. If I were doing a vehicle only (no trailer) desert crossing, MAYBE this would become a factor, but if you have some space, particularly of you are not going away long enough to consume much, it does not come into play. On some weekends in Winter we have been known to carry Coleman Fuel, Kero, LPG, firewood, Diesel in the vehicle tanks, 12V in the battery and used every one!
Wolfie is correct too...opinions are different but most bepoe are correct in some kind of way.
