Site Search
Section Image
Super Cheap Fridges
Submitted: Saturday, Dec 04, 2004 at 15:34
Shane (QLD)
Any one find out what compressors are in those fridges they are selling and if they have a basket.
Advertisement
ThreadID: 18317 Replies: 6
Views: 1231 FollowUps: 5
AnswerID: 87274   Submitted: Saturday, Dec 04, 2004 at 15:49
David Au replied:
The fridges are a Waeco with a Danfoss compressor. I went into SuperCheap today just to look at them as I was passing the front door. They were sold out, but the guy showed me the paper work, and it is Waeco with a Danfoss compressor. They are getting in more next week, and I will have a good look at them.
I also went into AutoPro just around the corner, and all they had was the standard Waeco range.
Reply 1 of 6
AnswerID: 87331   Submitted: Sunday, Dec 05, 2004 at 12:46
crowie replied:
I had a look at one of the Supercheap Fridges today. Don't look to bad except for the hinges for the lid and the plastic lip on the lid which the clip lock attaches to. The ridge is a molded part of the plastic top and I don't think it would last to long on a rough road. Would have to glue and screw something a little bit stronger to the lid to replace it.
I have been using a Finch 3/Way so can't really compare finish and quality compared with say Waeco and Engel. Probably work as well as the others but whether they would last as long who knows.
Reply 2 of 6
FollowupID: 346116   Submitted: Sunday, Dec 05, 2004 at 12:51
crowie posted:
Forgot to add they don't come with a basket
FollowUp 1 of 4
FollowupID: 346122   Submitted: Sunday, Dec 05, 2004 at 15:17
Black Jack posted:
Crowie, just a question on the Finch fridge. I am leaning that way or its bigger brother the 40 lt, as most my camping is arrive and set up for a week. Do you find the Finch keeps things cold in hot weather?
Balck Jack
FollowUp 2 of 4
FollowupID: 346251   Submitted: Monday, Dec 06, 2004 at 12:43
crowie posted:
BlackJack
I've never had a problem keeping things cold in hot weather when using it on gas or 240V. Low 30s is the hightest temp I've had it operating in. They must be level of course and I carry a little spirit level as part of my camping gear. They are almost too efficient. I have to be careful that vegies do not fall to the the bottom because they will freeze. The bigger Chestcolds probably have even better insulation and probably better. Someone else may comment on that.
12V results in the back of the truck is adequate when travelling and 240V about equivilant to the gas. As some one else has mentioned, keep them clean and covered if they are being stored as insects can get into the pipes to nest etc. They also need to be run every few months. I was told that the refrigerant will Crystallize if left sitting to long. Its almost cheaper to buy a new fridge than recharge them if this happens.
FollowUp 3 of 4
FollowupID: 346295   Submitted: Monday, Dec 06, 2004 at 20:02
Black Jack posted:
Thanks Crowie. I think you answered why a friend hated the Chescold so much. He only ever used it once a year. You hear positive and negative stories all the time and when you dig a little there is always another aspect of the negative story. Always read the intructions. I was also undecided about getting the 40 lt with the freezer so that I knew it would get the temperature down, but nor really wanting to freeze things. The Finch is all I really need.
I dropped in to Supercheap on the weekend to look at these new fridges, but they didn't have one in stock. The small article they had on it didn't mention 240 volt. I'm not sure if this was a misprint of if it is 12 volt only. The saleman knew nothing about the fridge. No basket and 12 volt only is one way of getting the price down, but also limits when and how it could be used.
Thanks again
Black Jack
FollowUp 4 of 4
AnswerID: 87390   Submitted: Sunday, Dec 05, 2004 at 21:40
Member - Jimbo (VIC) replied:
Black Jack,
I've got and old Chescold that I used at Fraser in September ten years ago (not stinking hot, but quite warm) and running on gas it would start to freeze stuff (other than beer with its alcohol which decreases its freezing temp) left under the cooling fins.
This was a fridge only type, not the freezer one. Assuming the newer ones are more efficient, they should work fine. Keep them in the shade. Not sure how they work in extreme temperatures because I don't go camping when its really hot.
Jim.
Reply 3 of 6
FollowupID: 346294   Submitted: Monday, Dec 06, 2004 at 19:53
Black Jack posted:
Thanks Jim,
I was allset to buy a Chescold when a fellow I work with said he just sold his because it never worked properly. Add Crowie's comment about the refigerant crystalizing if not used regularly and that will be the reason for his problems. He would use it once a year only. The 3 way fridge is still the best option for my usage and if I run it as a beer fridge when not camping it should work just fine.
Black Jack
AnswerID: 87432   Submitted: Monday, Dec 06, 2004 at 09:35
RussellV replied:
Hey Black Jack
With the 3 way - I have an old chescold which performs very well in the sub tropics but when taken up to the tropics and that type of heat eg. Lakefield NP etc it did struggle and the gas jets must be kept clean of dust which is bloody hard in the bush!! For that reason I'll prob go for a compressor type fridge next time. But the checolds are pretty much bullet proof apart from that.
Russell
Reply 4 of 6
Activities Index
V8 Race Buggy and WRX Rally Car - 32 Lap Combo V8 Race Buggy and WRX Rally Car - 32 Lap Comb
Gold Coast - QLD
The ultimate in dirt driving!
Beginners Intro. to dinghy sailing at Balmoral Beginners Intro.
Sydney - NSW
On one of Sydney Harbour's premiere beaches, you will be taught a series of techniques to guarantee
Casino Royale Blackjack Package Casino Royale Blackjack Package
Melbourne - VIC
Up to 80 guests compete in a tournament style competition.
Clay Target Shooting for 8 Clay Target Shooting for 8
Mornington / Bellarine - VIC
Get your blood pumping, experience the action with Adam Vella, Athens Olympics Bronze Medalist and 2
Book Now - Things To Do
AnswerID: 87435   Submitted: Monday, Dec 06, 2004 at 10:03
signman replied:
Definately NOT a Danfoss..pulled the back of one this morning (it had been returned coz it didn't work)...The compressor is a Chinese made one..similar in apperance to Danfoss..but nothing like the construction..
Reply 5 of 6
AnswerID: 87869   Submitted: Wednesday, Dec 08, 2004 at 20:26
Boxheadc replied:
I have a problem with my 3 way fridge, I assume it is a chescold but has no identification on it. It came with my pop-top but because it was secound hand it may have been changed. It is a small box,with brown panels on it.
Anyway my problem is that on gas it just does not get down to temp ( except at night when it will get down to approx 3+ degrees) it will be anywhere from 6 to 14 degrees during the day. But on 240v it will get down to about 1-2 degree all the time. I have pulled apart and looked at the jet ( how do you clean it,i have nothing small enough as the hole is mineute) But the flame seems reasonable, although i am unsure how big it should be.
Would anyone have any ideas that i could try?
Any help appreciated
Corey
Reply 6 of 6
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
