Long Range Automotive fuel tanks
Submitted: Sunday, Dec 05, 2004 at 20:14
ThreadID: 18342 Views:3299 Replies:3 FollowUps:1
Any body had experience of one these tanks on a 100 series?
How long do they take to pump the fuel to the main tank?
S.
Reply By: Big Kidz (Andrew & Jen) - Sunday, Dec 05, 2004 at 21:09
I have a Long Ranger tank through ARB that are different to the Long Range Automotive tanks. It works just like the standard subtank on the Landcruiser and does not pump from one tank to the other.
AnswerID: 87377
Follow Up By: hamiltonblk - Monday, Dec 06, 2004 at 04:21
thanks, but want to try and find out how long the Long Range Automotive takes to pump.
FollowupID: 346196
Reply By: Member - DOZER- Sunday, Dec 05, 2004 at 21:30
Hi I was under the impression 100 series went back to the draw from each tank system on the petrols....so u can select the sub and run on it.
AnswerID: 87380
Reply By: Troopie - Monday, Dec 06, 2004 at 13:01
G'day There
I have a LRA tank fitted to my Troopie. The Troopie has two tanks already - the LRA tank is actually the third tank so gives me a capacity of 275 litres...
Anyhow - the third tank (95L) pumps across to the main tank at the flick of a switch on the dash. It is actually quite slow and probably takes about half an hour to pump the whole lot across. I have never timed it though - this is a bit of guess.
Great product though - no problem with the pump rate and can happily recommend.
AnswerID: 87448
