patrol gu 4 3.0l cruise recall
Submitted: Wednesday, Dec 08, 2004 at 15:48
ThreadID: 18412 Views:3366 Replies:4 FollowUps:11
Just got a recall notice from Nissan Aust " vehicle safety recall S4002 genuine accessory cruise control"
Description of problem. the installation of the cruise control accessory has been found to be subject to a number of fitmant quality issues, the most severe of which may result in the vehicle throttle cable becoming stuck. If this cable becomes stuck, the vehicle throttle may become unresponsive.
It then goes on to say that that the removal is free of charge and the full cost of purchase will be refunded . the cruise control has been withdrawn from sale.
aud no other unit are available
I have had a look at the fitting of this unit and unit is mounted under the dash and the cable is wrapped around the steering colum then conected to the accellerater pedal.
The cruise control worked a treat no surging like the old model held very steady,
but if the cable gets stuck it will have to be removed.
Does anyone know of a unit that will connect to the ecu and is safe and still looks apart of the car eg. mounted as the factroy one in the steering wheel
Reply By: Member - Stillthinkinaboutit - Wednesday, Dec 08, 2004 at 15:55
Hi Bob,
Have a look at post 18931 about this issue.
It looks like another brand is available and it does not use a throttle cable.
AnswerID: 87804
Follow Up By: Member - Stillthinkinaboutit - Wednesday, Dec 08, 2004 at 15:59
I should have said look at post 18391
FollowupID: 346604
Follow Up By: gu bob - Wednesday, Dec 08, 2004 at 16:05
thanks
tried to look up the Autron unit, but cant find any thing on cruise control.
Do you know what was fitted as genuine nissan cruise
FollowupID: 346607
Follow Up By: Member - Stillthinkinaboutit - Wednesday, Dec 08, 2004 at 16:17
It looks like they were fitting the Command AP500 units, not 100% sure though.
FollowupID: 346610
Follow Up By: Member - Stillthinkinaboutit - Wednesday, Dec 08, 2004 at 16:21
Hi Bob,
Have a look at the Autron website
FollowupID: 346612
Follow Up By: Member - Stillthinkinaboutit - Wednesday, Dec 08, 2004 at 16:22
Hi Bob,
Autron
FollowupID: 346613
Reply By: Member - Captain (WA) - Wednesday, Dec 08, 2004 at 16:45
Hi GU Bob,
I have the Autron cruise fitted to my GU. It was not done by Nissan, but recommended to me by Nissan, just worked out cheaper to do it direct with the installer rather than by the dealer. From other posts, it seems that different dealers offered different types of cruise control as optional extras.
As far the the Autron goes, its a great unit and has the steering wheel buttons to operate - can thoroughly recommend it.
Captain
AnswerID: 87812
Follow Up By: gu bob - Wednesday, Dec 08, 2004 at 17:24
Thanks a lot for your replys and info you have made my day
Talk to a guy that fits the fly by wire units they leave the nissan wire cable pull for dead .
A very nice bloke explained the system and all the features a lot more than the original.
Brett at Redwood park in S.A runs N.E Car Security
Can have the genuine button if I want.
The unit is priced at $695 fitted. has speed alert and "clutch resume"
This feature is if you need to change down the cruise will resume the set speed after the clutch is released.( don't know about 5th to 2nd , but that should be common sense maybe 5th to 4th )
Can have other features fitted speed memory where you can have an extra pad fitted to the recease on the other side of the steering wheel so as to have 3 set speeds eg. button 1, 80k. 2,100k. 3,110 these are programable to the speeds you want. this is extra $150
anyway what a great forum
Thank you very much
back cruising
FollowupID: 346625
Follow Up By: Bonz (Vic) - Wednesday, Dec 08, 2004 at 20:09
Bob, I have an Autron on my GU3.0l. The clutch needs an off switch on it for manuals, so that if you throw the clutch the motor wont try to maintain speed and overrev. The Autron has a memory, so if you change to 4th just press resume and away it goes, even the next day after its been switched off. I didnt think the extra buttons were worth the extra $150 after all youve got to accelerate to whatever speed you want, then just press the button and sit back....if you've got a Winnebago , than apparently you can go make a cuppa and it'll auto drive you :0)
FollowupID: 346652
Follow Up By: gu bob - Wednesday, Dec 08, 2004 at 22:02
now a winnebago my back hurt enough saving up for my nissan, but xlotto and the pain would go away.
The unit comes with a clutch cut out , it must remember where you were before you disengaged
FollowupID: 346703
Reply By: gu bob - Wednesday, Dec 08, 2004 at 16:46
Just had a good look at the site in aust if they do the fly by wire job for it, it sounds like the go.have e-mail them and will wait their reply. nissan aust while were simpathetic to me the bloke realy could not give a shag.
AnswerID: 87813
Reply By: Member - Andrew(WA) - Wednesday, Dec 08, 2004 at 19:22
This is a copy of my response to an earlier thread on this subject.......
This is a long story but I will try and keep it short. I posted an extensive thread on this issue about 18 months ago but can't find it in the archives.
Anyway, When I bought my Patrol 3.0tdi new in june 2002 I had it fitted with cruise before delivery. Nissan don't (or didn't then) make a factory cruise for the 3.0tdi but used the 'Command' brand system which had a throttle cable from the accelerater through the fire wall to an actuator. How the whole thing works I'm not sure but anyway I had a heap of trouble with it which I brought to the attention of my dealer. They fiddled with it but it was never any good.
I did some home work and found out about the new 'Auscruise' by Autron for drive by wire specific vehicles. I sussed things out and found documentation purporting to be from the 'Command' company that specifically stated that the command systems for drive by wire vehciles are NOT recommended and should not be used for the same reason as set out in this recall notice, and others more serious.
Back then (late 2002) I brought this information and the documents (photocopies) to the attention of my dealer.
The result was...I was told the cruise would be changed ASAP at no cost, to the Autron Auscruise. I was told that the Auscruise could not be fitted without training first so the dealer sent his techie to do the course. I was fitted with the Auscruise about 6 weeks later from memory and it has been joy ever since.
The Auscruise has no wires or cables and talk directly to your ECU making smooth transitions and holds your speed accurately.
The Command system pulls on the accelerater and brings the car up to speed. I'm not shore why but because the cable is not exact as the ECU electronics, it constantly tries to get the speed right by increasing speed and going slightly too fast then adjusting by slowing down and vise vera creating a rollacoaster road.
I know some people have these fitted a swear by them. That's great. Please don't bombared me with "mines great" responses because I know some have been happy. I would suggest however that if Nissan are now offering a recall and changing them to the Auscruise. JUMP and get it done.
I am surprised that it has taken this long for the recall. Many 3.0tdi's would have been fitted with the old cable type since it was first brought to the attention of Nissan. I was told that the information was passed to HQ.
And if your wondering, I have nothing to do with and never have had anything to do with the Autron company or the Command company in any way. Just a concerned consumer.
Finally I would just add that the recall my not be for the Command systems alone but may be for all the non drive by wire units fitted. This information serves only as a information tread in relation to my own experiences and the current recall as stated by stillthinkinaboutit at the top of the page.
FollowUp 1 of 1 posted 08 Dec 2004 at 15:04 - (FollowupID: 346606)
Member - Andrew(WA) posted this followup
I see in another thread posted that Nissan are giving refunds and not replacing the cruise control.
This is probably because of the cost factor to upgrade.
Whether or not you jump up and down and demand the Auscruise is up to you! but it worked for me
AnswerID: 87843
Follow Up By: gu bob - Wednesday, Dec 08, 2004 at 21:56
they are not giving you any option just money back.
FollowupID: 346698
Follow Up By: Member - Andrew(WA) - Wednesday, Dec 08, 2004 at 22:21
I understand.
But, from my point of view, I bought a car with cruise that was INCLUDED in the deal.
If now, for what ever reason, they have to remove it and there is a product that can safely do the same job (in this case a better job) then as a consumer I should be given the option to have that product installed.
I personally would not have purchased the patrol if it could not have been fitted with cruise. Lets say for the argument that there was no other option and the cruise had to be removed and a replacement was not available. I would be stuck with a car that has no cruise but a car I purchased on the proviso it would have one. Now I would be left with a 50 grand mistake, no fault of my own. I would never accept that. Even if I lost, the journey would cost the manufacturer more just a replacement cruise control.
As a consumer we should expect only what we pay for, anything else is a bonus. If we pay for something with an expectation and it is taken away, one shouldn't be left out of pocket.
That's what I recon anyway.
FollowupID: 346711
Follow Up By: Member - Andrew(WA) - Wednesday, Dec 08, 2004 at 22:25
Sorry, my point is FIGHT or just accept a loss through bad market research by multi national companies who only care for their profits.
After all, the basis of this recall is 'safety'. They knew about almost two years ago, and now we hear about it.
FollowupID: 346715
