Fridge running on gas
Submitted: Friday, Dec 10, 2004 at 00:57
ThreadID: 18452 Views:3526 Replies:7 FollowUps:4
Could some one please tell me how long a fridge running on gas should take to get down to temp at say 2 or 3 degrees. I have packed the fridge with about 20 cans as well as some coke bottles etc. These where warm when they were put in, the fridge is a 35l i think old chescold.
I am doing a bit of a test on the unit but am unsure how long it should take, also is it better to test it full to get down to temp or empty?
Help appreciated
Corey
Reply By: REX.....(Adelaide) - Friday, Dec 10, 2004 at 01:17
my chescold takes around 3-5 hours in 30+ to get to -2 and its best to test empty
but once its there it stays there unless you leave the lid open
i always pre chill mine before i put anything in it.
AnswerID: 88079
Reply By: motherhen - Friday, Dec 10, 2004 at 01:58
We bought a small caravan a couple of years ago with a 3 way fridge - the vendor said he had only used it on electricity and it did keep things cool. If it did - it was not by very much! Our local refridgeration mechanic tested it by fitting a new heating element (for eletricity) but when that didn't improve it, he said that the pipes were most likely blocked and it was unrepairable. We purchased a new Engel 12v/240v caravan fridge and it is excellent, cools quickly, works well on 12v. Much prefer the compressor type to a gas fridge. But i am also a bit paranoid about fire - seen caravans go up in smoke!
AnswerID: 88082
Reply By: Member - Ross P (NSW) - Friday, Dec 10, 2004 at 08:13
Corey,
My experience would suggest that the time taken to cool to say -2 Deg C and even if it can ever get there depends on the outside Ambient Temperature, and the installation of the fridge.
My three-way fridge running on gas in ambient temps around 35 to 40 Deg without mods barely kept the food cool, certainly not down to -2.
On investigation the heat exchanger at the back of the unit was very very hot. My plan is to do two things. Install some baffles to to make sure I get cooling air flow to the right place and to mount a twelve volt fan or fans to assist in heat dissapation.
AnswerID: 88100
Follow Up By: Member - Ross P (NSW) - Friday, Dec 10, 2004 at 08:39
Corey,
I should point out that my fridge is an Electrolux and is built into the caravan.. I use and Engel compressor fridge in the car to keep the important commodities cold.
Regards,
FollowupID: 346967
Follow Up By: David Au - Friday, Dec 10, 2004 at 11:39
Ross 99% of the problems with Dometic/Electrolux is poor installation.
Putting in a fan is not a terrific solution and often causes to much air to pass over the wrong components. If the fridge is installed correctly, no fan is every needed. Here are two URL for you that should assist your issue.
http://ourworld.compuserve.com/homepages/MLeete/Carafri.htm
If you look at the bottom of this page 'Almost Good Venting' which is the fridge type you probably have, it is impossible to get proper air flow and fridge operation if the vent is level with the top of the fridge. The vent has to extend up past the top. You can also see it is imperative the correct air gap at the back, as to much is as bad as to little.
http://www.rvmobile.com/Tech/Trouble/vent.htm
The heat exchanger should be hot. Once vented and the air gap is corrected, you will find a major improvement in operation. If you go to the Dometic website, you can download the correct installation manual for your model. The fridge should be installed exactly as per the Dometic/Electrolux manual.
FollowupID: 347002
Follow Up By: Member - Ross P (NSW) - Friday, Dec 10, 2004 at 14:00
Thanks Dave,
I'll try to modify the baffles/venting first. It would be much better if the caravan manufacturers did it properly in the first place!
FollowupID: 347032
Reply By: Marko - Friday, Dec 10, 2004 at 08:19
Hi Corey,
I have a Chescold 3 way fridge RC1180. Personally I run it on 240v two days before I need it to get it down to about 2 degrees. I have a thermometer installed so I can see what the temp is (otherwise it gets TOO cold when on gas i find). It doesn't take two days to get down to 2 degrees however.
I actually turned it on last night with it sitting on 22deg. This morning it was 3deg. Link provided below for the thermostat that I use.
Jaycar Thermostat
AnswerID: 88101
Reply By: Austravel - Friday, Dec 10, 2004 at 09:54
Your doing it the right way. To test a fridge properly fill it with gear to cool, preferably warm tins etc to see just how long it will take to pull down. Testing empty tells you nothing. If the fridge is level and set up properly it could take a couple of days depending on outside temps. If it's not tropicalised it may not do it again depending on the ambient temp. I have a mate traveling Aus with one, on most of my trips with him his gas fridge has been problem. When the temp and humidity is down and the fridge is level, flame not blown out etc, etc it will freeze everything, that's everything fruit, veggies. Most of the time though it's a pain. He's found around Aus that in Vic, NSW etc were it's cool to cold weather it works quite well. Though you can't beat them for long stays in reasonable weather as a cheap alternative to compressor style.
AnswerID: 88116
Reply By: Boxheadc - Friday, Dec 10, 2004 at 13:24
Thanks for the replies,
The fridge got down to approx 3 degrees overnight but is now on the way up, at present it is around 12+degrees.The fridge works fine on 240v keeping the temp down. I have soaked the jet in metho to clean it as well as the gas flute, and reinstalled as well i pulled the gas temp control apart. All seems fine but has trouble keeping the temp down. It has a T on the model number hich i believe stands for tropicalized.
I am unsure what else to do, any suggestions?
Corey
AnswerID: 88156
Follow Up By: David Au - Friday, Dec 10, 2004 at 14:26
Corey the jets cannot be cleaned effectively and need to be replaced.
If you are in Melbourne, I would suggest you take it into Dometic/Electrolux/Chescold.
One of the major issues with 3 way fridges, is so often people leave the gas line open to the air and dust, spiders, ants etc. get into the gas hose and cause blockage. The gas line should always be sealed/effectively covered to prevent dirt getting into the system.
FollowupID: 347039
Reply By: Wizard2 - Sunday, Dec 12, 2004 at 22:16
When I first used my 3 way fridge in our caravan and it didn't seem to cool down I got some advice that has served me well since..........
MAKE SURE IT IS LEVEL !!!! Regardless of whether it is on gas or 240 volt
As they use heat transfer of ammonia the unit needs to be level to work correctly unlike compressor fridges............
I use a spirit level when parking the van to ensure the fridge has the best chance it can.........
Most 3 ways will run their best on gas or 240 Volt.
Another tip...empty the fridge, let it cool down then place items in it once it has reached correct temp...We usually turn it on 12 - 24 hours before we pack it.
Last tip....ensure their is plently of free flowing air to allow the heat to disperse and keep away from direct sun...
Yes it seems like a lot of fuss but that is the price you pay when using gas...Our next van will have a 2 way compressor fridge........
We carry a Waeco as well (we keep the beer in it as it gets colder) and it usually becomes the back up for the tempermental Elecrolux. I am always amused at how much the Swedes know about fridge operation in the Aussie heat!
Best of luck
AnswerID: 88425
