mapping software for GPS
Submitted: Friday, Dec 10, 2004 at 20:02
ThreadID: 18479 Views:3090 Replies:9 FollowUps:11
What is the general concensus on the best programs - we have a garmin GPS and have seen the OziExplorer but not used it.
Appreciate your comments and advice.
Dian
Reply By: Member - Clive G (WA) - Friday, Dec 10, 2004 at 20:23
Gday
It all depends on what Garmin you have,, in another words whether you can upload mapping to the garmin, if so then mapsource may be the way to go, as oziexplorer is great, you cant upload the mapping,
I myself use both software packages, oziexplorer and in my case mapsend for magellan, I did have a garmin etrex legend, and used oziexplorer with it for the moving map side of it, and for plotting routes, but used mapsource for uploading base maps,
Clive
AnswerID: 88237
Reply By: Wetty (W.A) - Friday, Dec 10, 2004 at 20:58
G'day Dian
I have both Mapsource and OziExplorer, both great programs(when you figure out the nitty gritty bits) I use a Garmin GPS 72, mainly for keeping track of where the cray pot is but also for the trips down south. I am looking into a laptop for moving map capabilities, but I think I will end up with a plotter of some sort as I have limited room in the Jack. I used Mapsource when I was working in the Goldfields and found it most useful to store the waypoints for the monitoring bores I needed to locate, and for producing maps for the Enviro's so they knew where the bores were too! LOL In the end, I guess the best thing to do is try to get hold of both and try them to see which suits your purpose. In my own opinion though, Ozi is the easier of the two to use.
Good luck
AnswerID: 88242
Reply By: Pluto - Saturday, Dec 11, 2004 at 09:01
Hi Dian,
Both Clive and Wetty have hit the nail on the head. Depending on what you want the mapping software to do will decide for you what you want to do.
For base map uploads, use Mapsend.
For the management and sharing of navigation data (i.e. Waypoints, routes & track plots) and moving map capability, OziExplorer is the pick. There are other similar applications available, such as Track Ranger & Fugawi, but for the price, functionality and after sales support
, Ozi is hard to beat.
There is one thing you should be aware of, OziExplorer is a digital raster map reader & GPS interface. It does not include a library of maps, apart from tutorial examples and handy some free downloads from the website. You will have to obtain the digital versions of the maps that you want to use, along with Ozi.
Having said that, there is a large and growing collection of maps available that are directly compatible with OziExplorer. Have a look at the EO digital map section to get an idea of what is available. There are plenty of other compatible maps available, out there.
AnswerID: 88301
Follow Up By: Utemad - Saturday, Dec 11, 2004 at 09:47
You can also scan your paper maps and use them. Either using an A4 scanner and scanning it in segments and then piecing it back together again or getting the mapshop to do it for you in one hit on a big scanner. About $7/map or so I've been told.
FollowupID: 347164
Follow Up By: Pluto - Saturday, Dec 11, 2004 at 10:05
Hi Utemad,
I thought about adding that, but I didn't want to overload a prospective Ozi newby.
Do you scan you own maps? What software are you using to stitch the images together?
FollowupID: 347165
Follow Up By: Utemad - Saturday, Dec 11, 2004 at 10:26
I scan my own using a Canon A4 scanner. Then I piece them together using Adobe Photoshop. I have been told there are better programmes for stitching but I'm used to Photoshop so I just use that. I then save them as low quality jpegs which gets them down to about 15mb.
I just thought I should add that you can scan your own maps as there is not a huge selection of digital maps out there. Plus scanning your own saves lotsa $$$.
The $7/map figure came from a mate of mine that works in a GPS shop. He said they have a guy that scans them for them but has a minimum of 10 maps per CD. So that means you have to do 10 maps for $70 but you can always get some mates together if you don't need that many. Much better quality than doing it on an A4 scanner.
FollowupID: 347168
Follow Up By: Pluto - Saturday, Dec 11, 2004 at 10:52
Photoshop is very good, but if you have to rotate images to get them to align, it can be a bit hit & miss.
I use the hp scanjet 4670 which makes laying out the map for scanning very easy.
After chasing reviews of the available stiching and panorama software, I settled on the one that Ozi recomends (
have a look at their information page). Dollar for feature, Panavue is way ahead all of the others and it's fairly easy to use.
You'll still get a better image from a large format scanner, but ther's not much in it.
FollowupID: 347170
Follow Up By: Pluto - Saturday, Dec 11, 2004 at 10:57
Oh I forgot to mention, I scan the map as tiff images and then convert the stitched map image with Img2OZF from Ozi's Optional Extras page to speed loading.
FollowupID: 347171
Follow Up By: Utemad - Sunday, Dec 12, 2004 at 00:22
Pluto,
Thanks for the tip about Img2OZF. I hadn't seen that before but I just finished converting my maps using it. It really speeds things up!
Not sure how I never noticed it before but you learn something new everyday.
FollowupID: 347253
Reply By: Bill n Di - Saturday, Dec 11, 2004 at 12:28
Thanks to everyone for your replies - I can;t really answer any of your questions as we've never used the GPS with software.
I understood that there is some program you can run with the GPS and the laptop and can have it running as you are travelling - it showing the track to take.
Sorry it is really Bill's questions - he just asked me to find out :-(( I'm just the blonde!
Dian
AnswerID: 88313
Follow Up By: Member - Errol (York WA) - Saturday, Dec 11, 2004 at 13:07
What you,re talking about is oziexplor moving maps . Thats what we use all the time now. Dos,nt matter what gps you use , as long as you can plug it into the laptop . Also good advice to get an external antenna , that way you get near full coverage of sats most of the time . Down side is , the laptop sits on the passenger,s lap . Next step is to make a braket to hold the puter soas to remove it from said lap (this will make passenger happy ) . Or , buy an xeternal screen and mount that on or near dash . Then you can start puter and close it up , put out of harm,es way , and use external screen . But , if you go this way , make sure you get a touch screen , that way you can work the puter from the external screen . This is what we use , and it works well ,cooks happy as well as she dos,nt have a puter on her lap . Cheers Errol
FollowupID: 347184
Follow Up By: Pluto - Saturday, Dec 11, 2004 at 13:30
Dian,
The feature you're asking about is 'Moving Map'. When it comes to that, OziExplorer is definately the pick of the crop.
FollowupID: 347186
Reply By: Member - Errol (York WA) - Saturday, Dec 11, 2004 at 13:09
P S Makes trips a lot more interesting as well , you can tell whats around you and put names to it as well . Cheers
AnswerID: 88316
Reply By: Bill n Di - Saturday, Dec 11, 2004 at 13:53
Thanks for the replies - so it looks like Oziexplorer with Moving Maps - last question I promise - how much and where is the best place to go?
Dian
AnswerID: 88319
Follow Up By: Bob of KAOS - Saturday, Dec 11, 2004 at 14:21
From the ExplorOz shop of course :-) (see tab at top of page).
FollowupID: 347192
Follow Up By: Pluto - Saturday, Dec 11, 2004 at 14:25
Right here. You can also get it over the counter at most map & chart shops or direct from OziExplorer.
Don't forget to look at their site for optional extras, free upgrades and a variety of other useful info.
FollowupID: 347193
Reply By: Mike Harding - Sunday, Dec 12, 2004 at 07:26
There is another prog. no one has mentioned:
www.tumaus.com.au
This programme includes the complete 1:25000 topographic map set for Victoria (I think the ACT is also available) but, at present none of the other states - so it may not suit your needs.
Mike Harding
AnswerID: 88368
Follow Up By: Pluto - Tuesday, Dec 14, 2004 at 13:29
Hi Mike,
I've just had a look at Tumaus. It looks like a very neat program. It's a pity that you're limited to using only their maps. Makes for poor value for money, considering the range of their maps.
FollowupID: 347497
Reply By: geocacher (djcache) - Monday, Dec 13, 2004 at 23:36
Not mentioned yet are Ozi3D - the 3 dimensional add in - which when used with the 3 second height data for Australia will let you see your flat map in 3D. Then you can follow not only your moving map but see what terrain you are approaching.
The next accessory to Ozi worth having is Oziphoto Tool which, when pointed at the directory of your digital photos and also at the directory where you stored the GPS track file you downloaded from your last trip, creates a waypoint for each photo and a link to the image file.
It does this by reading what is called EXIF data from the jpeg file which is the picture - which stores the Time Picture Taken info, and matching that to where you were on the track at that time. Just make sure your clock on the camera is right - set it to the time on your GPS.
Best trip diary out!
Oh and I use DiscoverAUS to upload regions for detail maps to my SD Card for my Magellan Meridian Platinum and pretty much nothing else, and OziExplorer for everything else from geocaching to trip planning. Acquiring your map library is the hardest part, once you have it you are home and hosed.
Join the Ozi Users group OziUsers-L-subscribe@yahoogroups.com on Yahoo groups for a great resource.
The Magellan Meridian group is pretty usefull too.
AnswerID: 88613
Reply By: Bill from Custom Boat Loaders Pty Ltd - Tuesday, Dec 14, 2004 at 11:09
Thank you all for your responses it was very helpful.
Dian
AnswerID: 88656
