Looking at buying Diesel Jackaroo
Submitted: Monday, Dec 13, 2004 at 12:43
timbo73
I am looking a buying a diesel Jackaroo. At the moment I am looking at a 98 or later model (witht the newer Diesel) What I am wanting to know is what is the difference between the L8 model and the U8 model? They appear to be the same or am I missing something? The car is to be used as my wife's day to day car and holidaying and weekend 4WDing etc. Any opionons or suggestions what to look for?
Reply By: Banjo (SA) - Monday, Dec 13, 2004 at 13:12
Apart from the obvious "in really good condition" ensure that the statutory servicing has been done properly (to the best extent possible). Valve adjustment on the 3.0L diesel is a big issue and costs heaps (at a dealer) - so much so that some dealers don't do it (while charging for it !!). Guess all you can do is read the fine print in the servicing guide of the handbook, and then satisfy yourself that someone has at least been paying for it to be done. The timing belt clicks in at about 200k I think.
88497
Reply By: Savvas - Monday, Dec 13, 2004 at 15:08
I never figured out what the difference is between L8 & U8. From the time I was invesitigating my purchase back in 1999, I have seen both L8 & U8 used to describe the same vehicle.
The big thing I guess is to make sure all the recalls have been actioned. Check www.recalls.gov.au, do a search on Jackaroo and make sure you include closed recalls. You will find there are 3 for the 4JX1 engine, however 2 of those are for very early builds of that motor.
Do a search through the archives here. There is a plethora of info on this site.
Happy hunting!
88514
Reply By: Rick Blaine - Monday, Dec 13, 2004 at 17:35
I'm very happy with
mine now. Did have a few probs when new but they were sorted out eventually..Parts can be expensive if you buy from Holden but Jackworld seem to be reasonable. I cant find any reference to L8 or U8 on
mine, 2002 model. As you were advised make sure the recalls have been attended to especially the one relating to the injector seals.....
88533
Reply By: Member - Bradley- Monday, Dec 13, 2004 at 17:40
differences at the ubs 98 update were minor cosmetic, diesel engine 3.0 , and gearboxes.
Make sure the injector update has been done, run the right oil , change both filters and love it..... and if you get one with the factory twin batteries - bonus.
88534
Reply By: bob - Monday, Dec 13, 2004 at 20:22
No expert on the jacks but they did bring out a model a few years ago with a slightly wider wheel track for better on/off road handling
88577
Reply By: morgan - Monday, Dec 13, 2004 at 20:44
I have a 2001 3.0 TD and am pretty happy with it - but as Savvas says, make sure it has been serviced and with the right oil - they are temperamental if this is not done (
mine was difficult to start and this turned out to be leaking injector sleeves) it was fixed under warranty. Great to drive, tows a 2 tonne caravan without difficulty and is reasonable on the fuel side.
88582
Reply By: timbo73 - Tuesday, Dec 14, 2004 at 08:06
Thanks for the info. Looking at a 2000 SE manual at the moment 68,000 on the clock. All the service history is there and serviced at the dealarship where it is for sale. I looked up the VIN and the recall range and it falls out side the range for the faulty injectors. The service intervals are meant to be every 10,000 my brother has a current TD prado and recomends serviceing every 5,000.. What are the servicing costs like on a Jackaroo?
88633
Follow Up By: Savvas - Tuesday, Dec 14, 2004 at 08:34
Dealer servicing can be very expensive, though if you buy it from a dealer 2nd hand you will be roped in from a warranty perspective.
However it is not a bad idea to just do an oil change every 5000km using the correct grade of oil. A good article on oil choice for the Jackaroo is here.
347467
Reply By: timbo73 - Wednesday, Dec 15, 2004 at 12:25
The car I was looking at has been sold so I am still on the hunt.. The Diesels as a bit on the rare side though
88870
Reply By: Mike-TS - Friday, Dec 17, 2004 at 23:49
Buy a petrol - bullet proof and servicing every 10,000 km!
89311
Reply By: timbo73 - Tuesday, Dec 21, 2004 at 08:00
The main thing that is steering me towards the Diesel is the fuel economy side. I think I now know the difference between L8 and U8. From what I can see the L8 has manual locking hubs where the U8 they are auto.
89702
Follow Up By: PAULL - Tuesday, Dec 21, 2004 at 15:11
Seen how much cheaper petrol has been in recent months compared to diesel ??
348548
Reply By: timbo73 - Tuesday, Dec 21, 2004 at 15:26
True Diesel is about 10% more expensive than petrol at the moment but the Diesel uses more than 10% less fuel than the petrol version as is my understanding. From what I have read here and else where it is between 20% and 30% more efficient. Although I think that the diesel is more expensive to service isn't it?
89753
