Toyota 4.5lt engine idle speed wants to drop rpm's
Submitted: Tuesday, Dec 14, 2004 at 14:33
ThreadID: 18562 Views:2496 Replies:4 FollowUps:7
Toyota 4.5lt petrol engine. The engine idle speed every now and then wants to drop down from the 550rpms to 250rpms for no apparent reason. I can reset it, but I am wondering if it has some problem or pending component failure ie the computer.
Has anyone experienced this and advise of the solution??
Rod
Reply By: Member - Bradley- Tuesday, Dec 14, 2004 at 15:12
sounds like a prob with the air bypass valve, give the throttle body a clean along with the bypass valve, and clean the connector on the valve. costs nothing and is a good place to start.
AnswerID: 88693
Follow Up By: Rod W - Tuesday, Dec 14, 2004 at 15:25
Thanks I'll check it.
FollowupID: 347510
Reply By: fozzy - Tuesday, Dec 14, 2004 at 15:16
rod
i had similar scenario in 94 4.5 man 80 series
every few months this problem occurred
start car and car would want to stall ie come up to set of lights and as you slow down engine wanted to stall-had to keep engine revving til lights changed. this may go on for 5-10mins or bit longer sometimes and would be fine for next few months and same would happen again. not always when cold either from memory
nfi what problem was to this day
AnswerID: 88694
Follow Up By: Penguin (NSW) - Tuesday, Dec 14, 2004 at 16:38
I had a similar problem to this when my speedo sender unit packed it in. Normal driving was OK but it did have a tendency to drop revs and even stall when braking.
I imagine that the computer was not getting all the information it needed which confused it.
Mike
FollowupID: 347540
Reply By: Member - Jeff M (WA) - Tuesday, Dec 14, 2004 at 15:23
Hey rod woldn't co-inside with the air con cutting in would it? When I had my feroza it would do that as the idle up (vacume operated) was leaking pressure and would cause the car to stall when braking if the air con cut in.
AnswerID: 88695
Follow Up By: Rod W - Tuesday, Dec 14, 2004 at 15:33
Giday Jeff, haven't used the aircon for awhile (might this arvo going home thought). It idles up proportionally when the aircon is on. It doesn’t want to stall when braking.
So how's the Bub and the sleepless nights?
FollowupID: 347517
Follow Up By: Member - Jeff M (WA) - Tuesday, Dec 14, 2004 at 15:38
I must be the luckiest bugger on earth, sleepless nights????? What are they?
She's even had a couple of 8 hour sleeps overnight and she's only just over 1 month old! She's a/my little angel! We are taking her away after Christmas for a week down south, not camping though! :-( But if she travels well it won't be long before we can come along on another Bushcamp!
FollowupID: 347518
Follow Up By: Rod W - Tuesday, Dec 14, 2004 at 15:50
That's good break em in young. Yep I read in an earlier post you'll be down that way. Jim and me will be moseying way down to the south coast probably somewhere between Albany and Bremer Bay. So if you see one white one and a red one following... keep going LOL.
Have a good one. See ya
FollowupID: 347522
Follow Up By: Member - Jeff M (WA) - Tuesday, Dec 14, 2004 at 16:10
Excellent, hope you have a great time! I'll be listening on Channel 10 for ya. :-) LOL
FollowupID: 347529
Reply By: Rosco - Bris. - Tuesday, Dec 14, 2004 at 16:44
Rod
Don't know about Tojo's but I had a similar prob with a V8 Disco. Apparently it was most likely the Air Flow Meter playing up. A proper mongrel of a job to accurately diagnose as the prob needs to occur when connected to the external computer.
As I said, may not be the case, but sounds familiar. If it is, see if you can source a reconditioned unit .... a new original will send you broke. ... Assuming Tojo parts are similarly priced, which would most likely be the case.
As an aside. I recently bumped the rear door on the Fender. Reversed into a tree that grew in the few seconds since I looked in the mirror. Rear door steel spare wheel bracket $78 ............. rear door "XTreme" plastic decal $110 ..... you work it out. ... buggered if I can.
AnswerID: 88717
Follow Up By: Member - David 0- Wednesday, Dec 15, 2004 at 18:43
I once had an Alfa Romeo. Two new complete rear disk brake rotors $80 each. CV joint boots $75 each!!
Just for fun one day I priced a Lucas relay for an old rangie I had from Landrover dealer- $220. Bought one for $3 from Supercheap.
FollowupID: 347812
