Tropicalising Van Fridge....
Submitted: Wednesday, Dec 15, 2004 at 20:27
ThreadID: 18608 Views:3786 Replies:7 FollowUps:18
Just wondering where the debate is at the moment re fitting fans to the rear of 3 way Dometic fridges to assist in blowing out the hot air. I tried it on my Jayco van and did not notice any difference...except complaints from fellow campers re the noise from the fan....Maybe if i fitted a thermostat so that it only ran when the air temp got over 20 degrees... your comments as always most welcome...
Reply By: AT4WD ADVENTURES - Wednesday, Dec 15, 2004 at 20:54
Hey Rick,
I have carried out some extensive research of my own and have come to the conclusion that if the vent chamber at the rear of this type of fridge is designed and built properly then no additonal active equipment is required to create the appropriate draft to cool the fridge.
On the other topic of the word "tropicalising" I have looked into the fact that dometic 3 way fridges do indeed have climate ratings and the 'T' or Tropical rating is present on some but not all the fridges in there range. This rating basically indicates more insulation and the quality of the design and installation of the vent chamber still applies.
I would also say that if you have an existing installation then look into removing dead air spots etc. and if you need I can point you in the right direction of a document that explains the best design for venting.
Regards,
Stuart M.
AnswerID: 88964
Follow Up By: Rick Blaine - Wednesday, Dec 15, 2004 at 21:13
I guess that the important thing to remember is to ensure that the airflow which is by thermal induction.. hot air rises is clear and the cooling fins are free from dust and spiderwebs etc....My installation is as supplied by the van makers with a plastic vent top & bottom on the outside and dosent appear to have much of a draft... unlike other instalations where if a tissue is offered up to the bottom vent it is held there from the draft.....I also seem to have to run the fridge on around 6 to get it really cold whereas others seem to freeze at around 6... just dont know. I have seen a solar fan kit but I dont think they would do much...but with these absorbtion cycle fridges the cooler you can keep the condensor the better they work....
FollowupID: 347843
Follow Up By: AT4WD ADVENTURES - Wednesday, Dec 15, 2004 at 21:18
Rick,
Don't despair as there are things you can do to improve the airflow.....like reviewing the current installation on your van and installing new inexpensive sheetmetal baffles in the appropriate places to ensure cold air coming in at the bottom displaces hot air in the chamber. I will try and post some links for you to look at.
Regards,
Stuart
FollowupID: 347845
Follow Up By: AT4WD ADVENTURES - Wednesday, Dec 15, 2004 at 21:28
Rick,
Follow this link and all will be explained....
http://www.rvmobile.com/Tech/Trouble/vent.htm
If this doesn't help or you need more info let me know. Remember the fan is a band aid and will not do things like direct air over the components that need the draft to operate efficently. These fridges have no moving parts and by introducing some (like a fan) you are taking away the K.I.S.S principle that they operate on.
Regards,
Stuart M.
FollowupID: 347848
Reply By: TheUndertaker - Wednesday, Dec 15, 2004 at 21:14
I tried it on my jayco and got complaints about the noise from the fan ,,,lol ,,, check the archives way way back , early 2002 , the size fan to use comes out of a computer, uses less than 100th of an amp per hr and is so quiet the sound of normal breathing would be 1000 times louder,, is over 36 in bris , my old chescold FRIDGE sitting on -10 deg ,on gas+ 12v fan.
AnswerID: 88966
Follow Up By: Nudenut - Thursday, Dec 16, 2004 at 08:27
yep the small comp fans should be OK
FollowupID: 347901
Reply By: David Au - Wednesday, Dec 15, 2004 at 21:46
There is no debate and never has been.
If the fridge is installed exactly as per Dometic/Electrolux instructions there should be no issues whatsoever.
Fans generally cause more problems and should not be used.
AnswerID: 88970
Follow Up By: Nudenut - Thursday, Dec 16, 2004 at 08:31
mmm dont think your entirely right here ...a fan Correctly Installed and selected to come on in high ambients will certainly improve performance of the fridge.....
if done correctly they should not cause "more problems"
FollowupID: 347902
Reply By: GOB & denny vic member - Wednesday, Dec 15, 2004 at 21:47
goodday rick
1 of the things i did when we were having a problem was to make sure the insulation on top of the fridge was on top and not blocking air movement and then i got a piece of aluminium and curved it gently so that all hot air was pushed out the top vent took a bit of stuffing around but next trip fridge seemed to work better
dometic (jayco ) deny that there is atropical rating on there fridges they say they are all the same bloody useless without some alterations in hot weather if you nare in melb the blokes at i think melb refridge in westall were very good to talk to about the problem if you want to chat about problem mem mess me and i will send mobile no
steve
AnswerID: 88971
Follow Up By: David Au - Thursday, Dec 16, 2004 at 07:32
Steve Jayco know only to well about 'T' rated fridges. If the fridge is correctly installed they require no alterations. The only time alterations are needed is if the fridge is not installed exactly as per the instructions supplied by Dometic/Electrolux. Unfortunately fridge manufacturers have no control over the installation. I came across a Waeco upright last week that was not working properly - why - installed incorrectly without proper ventilation by the caravan manufacturer. It does not matter if it is a three way fridge or electric fridge, attention to detail on installation is vital for the fridge to perform to the required standard.
FollowupID: 347893
Reply By: sean - Thursday, Dec 16, 2004 at 00:01
If you van frigde is not rated for the tropics, it will not work in the tropics. Well at least not in my experience.
I have a van and currently have it located on a block where temps range this time of year from 28 at night to 44 at day being south of darwin.
The fridge is new and has had everything done that can possibly be done and at the end of the day just cant cope with the temperatures. It is installed as per the Installation manual. It has extra insulation sealing off air gaps that may reduce teh draft. It has a computer fan.
It should work but it does not. At the end of the day after trying everything I found that the standard 3 way will not work when the temps get high. Anything above 30 - 33 and you are in trouble. I dont know how much better the climate class T fridges are though.
Sean
AnswerID: 89000
Follow Up By: David Au - Thursday, Dec 16, 2004 at 07:27
Sean often a computer fan will cause the fridge not to cool. If the fridge is installed correctly, and that means the vent must be above the top of the fridge as per the diagram at the bottom of this page "Almost Good Venting"
If your fridge is not vented as in the diagram (above the top line of the fridge), you will have problems.
Even an non-'T' rated three way fridge should work well above 33°C. If it is new, and even if it is not a 'T' rated fridge, it would be a minimum of an ST
http://users.bigpond.net.au/goldway/page16.html
FollowupID: 347890
Reply By: Nudenut - Thursday, Dec 16, 2004 at 08:44
No such thing as tropicalising your fridge.....
David is correct in what he says about ensuring correct airflow over the condenser
This is a Prerequisite
how-ever in high ambients (forget the word "tropical") a small fan to assist with more air movement over the condenser will increase the the fridges' efficiency ....but remember at a cost of battery storage.
("Tropicalising" is used for solutions that are intended to reduce condensation problems in high humidity conditions)
AnswerID: 89021
Follow Up By: AT4WD ADVENTURES - Thursday, Dec 16, 2004 at 16:31
Hey Nudenut,
The info below is a direct quote posted on another forum from a guy named Collyn Rivers who is renowed for his wealth of knowledge in the caravan and camping circles. I have also carried out extensive research to confirm what is said below is true and it is. The point is that if you are trying to run a non 'T' rated fridge in the higher temp climates then you will find that the efficency of the fridge will suffer.
As I have posted above it is imperative that the vent chamber be built or modified to direct airflow over the correct components that require heat to be removed away from them using a draft to do so. Adding a fan will only move air and not direct air unless a path has been formed for the air in the first place. Pay particluar attention to the installation of metal baffles across the rear of the components as mentioned in the electrolux manuals, these sit approx. 25mm from the components creating the air path mentioned and also the top, sides and bottom of the fridge.
Quote from Collyn Rivers...
"Many (but not all) fridges in the range are obtainable with a choice
of different design operating conditions. This is not universally
understood by those selling these fridges and one needs to be
persistent and careful when buying.
Inside the fridge there is a compliance plate. On the bottom line
there is the phrase 'Climate Class' This is followed by the
letters 'S', 'SN', or 'T'.
Those fridges designated 'S' or 'SN' are designed to operate at
maximum room temperature of 32 degrees C. That designated 'T' is
designed to operate up to room temperatures of 43 degrees C.
Note there is no other way of telling which is which: the type
numbers are same.
I have recommended the 'T' rated fridge to many people and have yet
to meet anyone who is disappointed by their performance. They must be installed correctely, with adequate ventilation. The 12 volt wiring
must be specified for the heavier current draw (15 amps) of these 'T'
rated models."
Regards,
Stuart M
Incidentally they now appear to be fitted as standard in Winnebago
motor homes.
FollowupID: 347986
Follow Up By: Nudenut - Thursday, Dec 16, 2004 at 16:57
I agree with the fact that vents to allow airflow across the condenser must not be blocked. However, in high ambient conditions a fan assisting the movement of airflow will lower condensing pressure and subsequently the back pressure. The refrigerant being temperature pressure related will be colder!!!
Having said all that … a condenser which does have a restricted airflow can be greatly improved upon by the installation of a fan…..the correct size fan will overcome the restrictions and if of adequate size can allow the fridge to run as if it had been installed correctly with adequate standard vent relief…..fact!!!! ….and not an engineering secret
FollowupID: 347992
Follow Up By: AT4WD ADVENTURES - Thursday, Dec 16, 2004 at 19:30
Hey Nudenut,
You can always place a fan in a poorly designed vent chamber to move air around but then that defeats the purpose of the design intent of the fridges....that is they are designed for use without them and if where possible the correct fridge is purchase to match the climate where it will be used then the fan is likely to be unnessary.
I still say the major problem in the correct installation of these fridges is there is no upfront thought and it is a little bit of thought upfront in the design of the enclosure that will save all the screwing around adding fans etc. I would also say that most existing installations can be corrected (at least the ones I have seen so far) without the addition of a fan by adding the air path that I continued to refer to and as per Electrolux guidelines......and that is fact!!!!
I might also point out again that its not just the input and output vents that make up the installation but baffles and formed chambers in the rear vent chamber as well as the addition of insulation around the fridge that will ensure a successful install.
Regards,
Stuart M
FollowupID: 348031
Follow Up By: Nudenut - Thursday, Dec 16, 2004 at 21:21
so now you agree...that they do work with a fan...and can do so more efficiently?
my argument has not discussed poor installations....rather someone asked if a fan would help....and yes it will!
between you and me...poor airflow over the condenser of any refrigeration system reduces its efficiency.... that also includes airconditioning systems for the house or car
FollowupID: 348055
Follow Up By: AT4WD ADVENTURES - Thursday, Dec 16, 2004 at 21:54
Hey Nudenuts,
Where did I agree with the installation of a Fan....what I said was you can always install a fan to move air around......I didn't say it would fix the problem.
What I have been saying and you know exactly what I have been harping on about and that is get the design right before, during or after the install and your fridge will be efficent and operate as designed without adding any active device.
The most likely scenario where a fan has been added if the install is correct and as per manufacturers recommendation is to try and overcome the use of non tropical rated fridges in tropical rated climates and improve there efficeny.
This again is poor design and/or poor product selection.......
Regards,
Stuart M.
FollowupID: 348062
Follow Up By: AT4WD ADVENTURES - Thursday, Dec 16, 2004 at 22:02
Also Nudenuts,
The original post said that he tried adding a fan.....and the result was and I quote "I tried it on my Jayco van and did not notice any difference"
So I say you can tell him to keep adding more fans to your hearts content but more the original installation needing improving and that is what I have been preaching......
You can give a man some food to last him today or give him some seeds and show him how to grow and that will feed him tommorrow...
Regards,
Stuart M.
FollowupID: 348064
Follow Up By: Nudenut - Friday, Dec 17, 2004 at 08:06
The name is nudenut! So drop the ‘S
please.
Fit a fan and it will fix the problem!!!
You need some engineering experience to see how….some persons remain blind by choice!
Yes get it right as per the manufacturers instructions! I agree!!
Could you please tell me what the difference is between a standard fridge and your intereptation of a tropicalised fridge? No such thing if its simply refering to high ambients ….i was always taught that to “tropicalise” something are for humidity problemsor the very wet environment if outside…. Eg a Tropic Proof electric motor. You can have high ambient temps and not be in the tropics, right?
“The original post said that he tried adding a fan.....and the result was and I quote "I tried it on my Jayco van and did not notice any difference"”….obviously not the right one, or fitted incorrectly! because and read my lips…a fan correctly installed will increase the airflow over over the condenser and there-fore increase the efficiency of refrigeration…..and as I guess you’ve most like seen one, why do refridgerated air conditioners have condenser fans?....no condenser fan, and the physical size of the condenser would be (mmm taking an educated guess here, after all i have been in the game for 38+ yrs) twenty times the size if wanting to use natural convection to condence the refrigerant.
And I reiterate, a fan, correctly selected and fitted will overcome a restricted airflow if no other solution is available for what ever reason.
FollowupID: 348098
Follow Up By: AT4WD ADVENTURES - Friday, Dec 17, 2004 at 09:23
Good Morning Nudenut,
At least I have reffered to you by name......you could do the same..!
As for engineering experience....I may not be a refrigeration mechanic but I am a sparky by trade, with electronics & comms certifcates and have worked in many different industries including large HVAC plants....so I do have some idea of how things are designed and intended to operate.
If you persisit in your advice on fitting fans to this guy and you are such an experineced engineering dude then you should have advised in your first post specifically how to add the fan rather than just saying and I quote "yep the small comp fans should be OK" rather than piece by piece.
As for why fans are added to AC units described by you it is because that is how they are designed.....compressors, fan motors, gas, thermostats, indoor/outdoor units blah, blah, blah. Heat rejection!!!
I am not some useless pup and have been around (24 years experience) and the thing that I have been very careful about doing in the past is to try and answer other forumites questions with as much information as possible that I have at hand based on my experince and not just throw away one liners.
This forum is also not about who has the biggest nuts and how many times they have been used but more about ensuring ideas are put forward, analysed and implemented to a successful outcome.
So place that in the fridge and freeze it....but I am sure you will want the last word so start thawing!!
Regards,
Stuart M.
FollowupID: 348107
Follow Up By: Nudenut - Friday, Dec 17, 2004 at 09:48
Stuart,
I am plum tuckered out trying to get you to accept the fact that condenser fans will aid in heat rejection..............whoopie at least you know what the condenser does....same as a radiator in your car ...rejects heat eh? why does it have a fan?....cos it make things work more efficiently.
Maybe I need to tell and or show you how to install one correctly to get better performance during high ambient conditions.
and what is your interpretation of tropic proofing eh? you should know....your a sparky right.
FollowupID: 348109
Follow Up By: Nudenut - Friday, Dec 17, 2004 at 09:55
Hey Stuart,
click on waeco link on Forum page and select fridges freezers and tell me what the two little round things are below the carry handle and what do you think they are there for?
FollowupID: 348110
Reply By: Wok - Thursday, Dec 16, 2004 at 17:15
Re : Fan
If anyone is interested in adding a fan.....this one directional....found it effective in my 12v fridge.
Blower fan
rgds
AnswerID: 89106
Follow Up By: Wok - Thursday, Dec 16, 2004 at 17:20
Sorry the link doesn't work...you will need to see it the hard way!
Its the smaller fan....big one is very noisy.
rgds
FollowupID: 347997
