hj 60 high temp
Submitted: Wednesday, Dec 15, 2004 at 20:53
brian
have hj60 when it runs the temp gauge quickly registers high temp but when you get out and check everything appears normal restarting gauge shows normal then later shows high temp which appears ok anyone can help??
Reply By: greenant - Wednesday, Dec 15, 2004 at 22:17
Have a look at this site it may be your answer I found this a while ago and kept it in my favorites in case
mine had the same problem
www.cruizers.com/ubb/forum1/HTML003813.html
Hope this helps
Greenant
88980
Reply By: greenant - Wednesday, Dec 15, 2004 at 22:20
Sorry there should be a forward slash between HTML and 003813.html
cruizers.com/ubb/forum1/HTML/003813.html
Greenant
88982
Reply By: Davoe - Thursday, Dec 16, 2004 at 00:22
does your fuel gauge head north at the same time? if so this is normal.
89004
Reply By: chappobriz - Saturday, Dec 18, 2004 at 09:50
Hey Post,
Have you had any success with this? I have an FJ62 with similar problems.
Chappo
89335
Reply By: greenant - Saturday, Jan 08, 2005 at 14:45
I dont know if I was any help peviously but look at the following site
www.cruizers.com go to Discussion technical
forum then to Technical questions/answers there is a post there Goofy Temperature Gauge listed on
12-31-2004 this will give you all the info you require
91939
