quick/dumb question..
Submitted: Wednesday, Dec 15, 2004 at 21:07
ThreadID: 18611 Views:2541 Replies:3 FollowUps:2
Can anyone tell me quickly -
- if you are charging a deep cycle battery either in a camper or caravan via mains power(e.g powered site) through the onboard battery charger, doesn't the battery if it's being charged need it's caps off.
When I charge a battery at home I was advised to always unscrewed/removed the caps.
Oddy
Reply By: Eric Experience. - Wednesday, Dec 15, 2004 at 21:58
Oddy.
No, that was in the bad old days when battery chemistry involved a lot water ading and acid bubling, Eric.
AnswerID: 88973
Follow Up By: oddy - Wednesday, Dec 15, 2004 at 22:36
Thks Eric
better safe than sorry.
FollowupID: 347869
Follow Up By: Gajm (VIC) - Wednesday, Dec 15, 2004 at 23:07
The only dumb question is the one you don't ask, as you said, better safe than sorry
FollowupID: 347875
Reply By: MrBitchi - Thursday, Dec 16, 2004 at 10:21
Used to run a battery shop when I was is the Army and we used to remove the caps to vent the batteries and prevent hydrogen build-up. Used to have 4 banks of up to 20 batteries each, charging off enormous 3 phase chargers.
Most commercially available chargers wont put out anywhere near the current of those jobbies so you shouldn't have a problem. Just keep an eye on the temperature of the battery and make sure the vents aren't bloked.
As always though, the battery should be in a well ventilated area while being charged. Any charging action will cause hydrogen output which can be explosive.
Cheers, John
AnswerID: 89041
Reply By: bruce - Thursday, Dec 16, 2004 at 14:34
Just a short question...do you take the caps off your car battery when you are travelling ?.....it is charging
AnswerID: 89087
