80 series instrument bulb
Submitted: Thursday, Dec 16, 2004 at 01:10
ThreadID: 18617 Views:5391 Replies:7 FollowUps:3
Does anyone know where i can buy the small instrument globes for the altimeter and sub fuel tank gauge on a 80 series gxl ( 92) other than from toyota. I have checked the archives and lcool without any success. i am in Perth WA.
any part numbers(even genuine toyota) would be a great help
Reply By: Peter 2 - Thursday, Dec 16, 2004 at 07:57
Sometimes you can get them at a good auto leckie or auto parts store, depends on whether wht has been used is model specific or a generic design.
I've found that if the little globes are detachable from the plastic holder and are 'clear' you might have a chance. If neither of the above, then it's off to Toyota.
I recently had to buy a couple of globes for a HZJ75 and a Coaster bus, both required a visit to Toyota as no aftermarket was available.
AnswerID: 89013
Reply By: fatz - Thursday, Dec 16, 2004 at 08:38
Dick Smiths, thats where I got the last ones I got, there web site is here http://www.dse.com.au/cgi-bin/dse.storefront and it will give you the nearest store locations.
AnswerID: 89020
Reply By: tour boy - Thursday, Dec 16, 2004 at 09:22
The last green ones I got from Toyota cost me $1 ea
AnswerID: 89025
Reply By: Steve - Thursday, Dec 16, 2004 at 09:56
Hi Mate.
my globe has also blown. i tried to get to but was hell of a job i unscrewed but nothing budged, is there a special knack?
thks steve
AnswerID: 89037
Follow Up By: Ruffstuff - Thursday, Dec 16, 2004 at 10:27
Thnaks guys,
i will try tricky dickies, other wise its off to Toyota.
Steve, they are a nuisance.
If yours is the same as mine, it is in the centre of the roof near the rear view mirror.
There are three screws, two at the corners closest to the windscreen, then one in the middle of the map light assembly, take these out.
You then need a flat head screwdriver to remove the map light assembly from the rest of the housing that has the sub fuel tank guage and altimeter in it- it should come away fairly easily.
under the map light assembly are some more brass screws undo these and the altimeter etc housng should come off and be suspended by the wiring.
Good luck.
FollowupID: 347921
Reply By: Kiwi Ray - Thursday, Dec 16, 2004 at 12:12
Hi Ruffstuff
The small globes as used by the 80#, Prado and a number of the other Toyota models can be purchased at RS Industries
There is three different sizes you need they have them all
Ray
AnswerID: 89061
Reply By: geocacher (djcache) - Thursday, Dec 16, 2004 at 21:06
I recently repaired my next door neighbours exact same unit.
Bought slightly bigger diameter globes (only ones I could get on a sunday afternoon with the longest pigtails I could - they were Narva globes from Autobahn. You could get smaller ones any other day of the week from RS, Farnell or possibly Dick Smith. Hobby shops specialising in train sets are also a possible source.
I'm surprised you can't just get them from Toyota but anyway.
1. Remove the globes (quarter turn to unlock from PCB) and lift out.
2. Remove globe from globe holder by unwrapping legs.
3. Enlarge hole slightly using drill bit (by hand not in drill) or tapered reamer.
4. Wrap contact points in small fuse wire
5. Insert new globe and solder legs to fuse wire (quickly)
**Last two points are redundant if you can source globes with long enough legs to wrap around holder.
6. The green globe cap is a silicon rubber cap that can be removed from the old globe and put on the new one.
About half an hours tinkering in the shed and 2 stubbies should do it.
AnswerID: 89150
Follow Up By: Ruffstuff - Friday, Dec 17, 2004 at 10:56
Thanks geocatcher,
the thieves at toyota want $3.10 each for these little buggers.
What you have done sounds like the way to go- i didnt realise you could get the old globe out of the base.
FollowupID: 348119
Follow Up By: geocacher (djcache) - Friday, Dec 17, 2004 at 21:50
I think the narva ones were about 90 cents each. My time was free.
If there's a selection of power levels go for the lowest. You don't need brighter ones and they make more heat.
FollowupID: 348205
Reply By: Member - Matt Mu (WA) - Friday, Dec 17, 2004 at 12:37
Hmmmm, a few hrs tinkering, soldering, searching and a buck or 10mins and $3.10 seems odd when you look at it like that. But to tell you the truth...I probably would have made my own and enjoyed the few hrs tinkering in the shed.
Just a thought, I have used the redundant globes from ash trays and other obscure locations in the vehicle to replace the important ones in instuments and dash lights etc on a number of occasions. Doesnt solve the problem permanently but does make do until you get around to finding the right globes without paying $3.10.
Matt.
AnswerID: 89225
