60 L.E.D. v flouro
Submitted: Thursday, Dec 16, 2004 at 10:53
ThreadID: 18622 Views:3077 Replies:7 FollowUps:11
Hi all,
Just a follow up to my previous post re. the 60 L.E.D. lights. I went back to Campmart to confirm specs and compare outputs.
60 L.E.D light has 60 x 8,000 MCD L.E.D.'s... total 480,000 MCD
2.4 watt and 0.2 amp current draw
L.E.D.'s arranged in 3 rows of 20, all facing one direction
Current price $100
When compared with 12v flouro, it is many times brighter in 1 direction but 1/2 as bright or less in wide angle brightness.(I was going to take my light meter along to take precise measurements but but chickened out 'cause I didn't want the store attendent to think I was a weirdo).
IMHO it would be fantastic over the stove to cook under, but a flouro would be better as an area light. The limiting factor with the L.E.D. light is its narrow angle of light.(it makes a fantastic backup torch though). It needs a "wide angle diffuser" over the light to make it the ultimate camping light.... If anyone knows of a suitable light diffuser (maybe like photographers use) to either slip inside the glass or slide over it, please put forward any ideas.
Adrian
Reply By: porl - Thursday, Dec 16, 2004 at 12:10
Thanks for that Adrian, i was gonna head to one this weekend. i have an excellent waterproof LED torch that is specifically a wide light rather than an intense narrow beam, so am not sure if that is a type of LED or it has a light diffuser. But clearly i don't need a mega bright light in one narrow beam at the campsite.
Look forward to any replies.
AnswerID: 89060
Reply By: TheUndertaker - Thursday, Dec 16, 2004 at 14:38
Campmart at Lawnton price is $74.90 ea, bought 2 this morning, got deal for $130.00 the pair.
AnswerID: 89089
Follow Up By: rb30s - Thursday, Dec 16, 2004 at 14:51
WOW,
I better go for a drive up there!!!.....or maybe the Slacks Creek store may match that price???
By the way, what sold you on these lights?
Adrian
FollowupID: 347964
Follow Up By: rb30s - Thursday, Dec 16, 2004 at 17:19
Hi TheUndertaker,
I couldn't resist myself and printed this thread, went down to Slacks Creek Campmart, showed them your "2 for $130" deal. They rang Lawnton to check up and every staff member denied knowing anything about it. In the end they said I could have one for $75, so I took it. I feel it is still good value......now..... some way to diffuse maybe 1/2 of it?
Thanks for your imput.
Adrian
FollowupID: 347995
Reply By: TheUndertaker - Thursday, Dec 16, 2004 at 15:53
What sold me on the lights was that they seem fairly robust and the minimal amp draw for the amount of light output, also can usually "haggle" at campmart as long as item not in current specials catalogue.
AnswerID: 89100
Reply By: Wok - Thursday, Dec 16, 2004 at 16:44
Re : Diffuser
If you look at the recessed fluro fittings in offices, you will[usually] see a diffuser plate. They are a flat plate with small pyramids on one side.
It may do what you want?
My last bit came from Haymans/Lawrence+Hansen.....can't remember now!
Rgds
AnswerID: 89105
Follow Up By: rb30s - Thursday, Dec 16, 2004 at 17:25
Wok,
Thanks, that might be the go!.... Or maybe something flexible. mmmmm
I'll keep watching for more idea's.
Thanks again.
Adrian
FollowupID: 347999
Reply By: Member - Davoe (WA) - Thursday, Dec 16, 2004 at 17:19
Sounds interesting but for simular price i think I will stick to my versa lite and led headlight
AnswerID: 89107
Follow Up By: rb30s - Thursday, Dec 16, 2004 at 18:16
Davoe (WA),
Yes Versalite's ARE good, but use 5 times the power as the 60L.E.D. light, this just gives people 1 more option.
Thanx
Adrian
FollowupID: 348011
Follow Up By: rb30s - Thursday, Dec 16, 2004 at 18:20
And I love light weight L.E.D. headlamps too.
Adrian
FollowupID: 348012
Reply By: Member - Davoe (WA) - Thursday, Dec 16, 2004 at 18:37
5x? more than 60 leds wow thats pretty impressive especially as versa lights dont use a great deal in the first place. I started off using incandescent headlights for reading and cooking but I barely got 1 night out of them. The geos I was taking out used led lights so i looked into it and ended up getting an 8 light set up with 4 on low beam and changing batterys almost became a thing of the past. One question - how long do the globes last and can they be replaced?
AnswerID: 89118
Follow Up By: rb30s - Thursday, Dec 16, 2004 at 18:54
Davoe,
Batteries.......I've forgotten how to change them (not really), and bulbs.... never again!.. Good ah!
Adrian
FollowupID: 348023
Follow Up By: geocacher (djcache) - Thursday, Dec 16, 2004 at 20:35
A bit of interesting theory on LED's for those who are or might be interested.
LED's aren't globes. They are Light Emitting Diodes.
They are a photo electric junction of materials like galium arsenide, gallium phosphate and indium arsenide. They are a PN junction which generate light when current flows in one direction (forward) only and require a minimum voltage to begin generation. They have a low reverse voltage breakdown threshold so if you hook them up incorrectly they are likely to be destroyed, unlike a filament globe.
Because they are solid state and generate very little heat and also as they do not use a degenerating filament or gas to generate light they are long lasting. In fact most light emitting diodes will last for something of the order of 60,000-100,000 hours.
They are very efficient requiring between 2mA and 20mA to operate. That's 0.002 Amps to 0.02 Amps. To increase brightness they can be pulsed for a short duration at higher currents - eg. 10 pulses per second (or more) of very short duration of say 60mA, giving off what looks like constantly bright lights.
They switch on in a millisecond or so unlike a filament which may take 25-40milliseconds, therefore their implications for saving rear end collisions are huge.
If all brake lights were LED's at 60kmh the person travelling behind the braking vehicle may have a reduced braking distance of up to 6 metres!! At 100kmh the reduction is as much as 10-12 metres. City drivers should get an insurance premium reduction for fitting LED brake lights IMHO.
The long and the short of it is that you shouldn't ever have to replace them. If you weren't interested in the rest of it I apologise....but LED's aren't globes and koalas aren't bears, but you can call them what you like, they don't care and I don't either.
FollowupID: 348045
Follow Up By: Member - Davoe (WA) - Friday, Dec 17, 2004 at 11:06
wow aways good to see aome data as well as opinions. With all that phosphate and arsenide I am assuming they make a vey poor food choice in survival situations. I am unsure about the never having to change them as I notice alot of trucks lights have at least some out (probably get 100x more use than most people would)
FollowupID: 348121
Follow Up By: geocacher (djcache) - Friday, Dec 17, 2004 at 21:46
The brighter they are the more expensive. I mentioned in one of my messages you could drive them harder for a very short time. This is to say pulse them 10 -15 times a second or more at much higher currents.
By doing this you can achieve the brightness of the expensive LED's from cheaper ones that if they were run at one lower current constantly would be much dimmer.
Of course this increases the failure rate. The advantage with theses is that 20 or 30 out of sixty could fail and you would still have a brake light or indicator, where one filament fails in a globe and that's it.
The failure rates were a lot higher in the spoiler brake lights of 10 years ago than now, and you notice that the ten year old ones now are starting to look a bit grim, but you can still see when they are on or not.
I found a great high mount stop/tail lamp from Hella which i cut into the fibreglass canopy of my ute. It's got two brightness levels, a tail light and brake light in one.
FollowupID: 348203
Reply By: Glenno - Thursday, Dec 16, 2004 at 19:38
Thanks for the info Adrian.
Is MCD's a measure of light? Ie can you convert MCD's to Candle's etc so they can be compared to other light sources?
Glenn.
AnswerID: 89131
Follow Up By: rb30s - Thursday, Dec 16, 2004 at 19:52
Glenn,
I'm not sure how MCD's compare with candle power etc. I have just noticed when researching that L.E.D.'s carry a MCD rating and it relates to their brightness. Try Google.
One day I might pull out my light meter and take some readings.
Adrian
FollowupID: 348039
Follow Up By: geocacher (djcache) - Thursday, Dec 16, 2004 at 20:56
The optical power of an LED is referred to in milliwatts. mW
The luminous intensity is referred to in millicandela. mcd
milli = thousandth
ie 500mcd = 500 millicandela
The candela is
Definition: [n] the basic unit of luminous intensity adopted under the System International d'Unites; equal to 1/60 of the luminous intensity per square centimeter of a black body radiating at the temperature of 2,046 degrees Kelvin
For a much better description than I can give (I started trying to explain it but I've forgotten too much physics and electronic theory to do it easily - this stuff doesn't matter much to a patient with chest pain :o) try this one. It's the simplest I can find on what is a very complicated topic.
Click here
FollowupID: 348049
