Duel Batt solenoid
Submitted: Thursday, Dec 16, 2004 at 13:01
ThreadID: 18625 Views:2536 Replies:9 FollowUps:26
Greetings all, to all budding auto sparkies out there, can you confirm for me what I've been told by my local sparky that it is OK to use these solenoids (about $50) for a duel batt system on an EFI GQ. I had concerns based upon what I had read that I could get Computer damage from spikes when the contacts closed, but my sparky says alot of that is scare tactics by the more expensive manufactures and the computers are quite robust these days.... I don't want to spend a fortune if I don't need to.
Scott
Reply By: Nick R - Thursday, Dec 16, 2004 at 13:14
Our local auto electrician has installed about 100 voltage sensitive relays in fourbys in the south west of Vic. they have been very happy with them, no problems of spikes to speak of. they can handle 90 amps, turn on at 12.8 volts and out again if it goes over about 14.8. It was about $80.
nickR
Carpe Cerevisi
AnswerID: 89070
Reply By: David Au - Thursday, Dec 16, 2004 at 14:21
And you think your local sparky would know - what a worry.
It is most definitely not OK to use solenoids without protection on modern vehicles. Considering you can buy a proper battery isolator system like a Redarc with proper protection for $125.00 why would people be so stupid as to fit something on hearsay from a local sparky.
I just love these posts that give not only totally incorrect advice, but advice that could result in damage to vehicles that could cost thousands of dollars.
AnswerID: 89083
Follow Up By: Ferret - Thursday, Dec 16, 2004 at 14:27
Thanks for the reply, the cheapest redarc I could find in Perth was about $160. Can you tell me where I can find a Redarc for that price please as this was my prefered choice initially
Scott
FollowupID: 347958
Follow Up By: Member - Captain (WA) - Thursday, Dec 16, 2004 at 15:23
Hi Ferret,
I have bought several redarc solenoids from coventrys for $99 trade price. Normally only Morley branch has them in stock, if you order before 10:00am, it will be at your local branch by the arvo.
Captain
FollowupID: 347972
Follow Up By: toymn8r - Thursday, Dec 16, 2004 at 15:39
Hey David.
Did you think that maybe Ferret is asking for advice here before committing to advice from a local sparky.
You would think that a local sparky should know.
Many people use this site to confirm advice given from other quarters.
How do we know that people wouldn't be considered stupid taking advice from you.
I'm not trying to start an argument but who made you God anyway.
I write in to this forum from time to time for advice, confirmation or just a chuckle not abuse or condescending comment.
Just my opinion
FollowupID: 347977
Follow Up By: AT4WD ADVENTURES - Thursday, Dec 16, 2004 at 16:45
Hey David,
Can you please elaborate on your statement and I quote "with proper protection" what does proper protection in your book mean.
Correct me if I am wrong but this product is basically a high current switch rated for the purpose that its used and is controlled to open and close when voltages reach certain high/low thresh holds. What other protection does it provide apart from opening the circuit between the primary and secondary batteries connected to it based on preset conditions....like low volts on the secondary battery.
Regards,
Stuart M.
FollowupID: 347990
Follow Up By: Ferret - Thursday, Dec 16, 2004 at 17:22
Rotten buggers at coventrys at Rockingham said $158 on special, 1 only, morning price etc etc...i'll try Morley
FollowupID: 347998
Reply By: Member - Hugh (WA) - Thursday, Dec 16, 2004 at 15:32
This is for Feret.
ALANCO in Perth sell REDARC solenoids. I got mine through work at trade price, however retail ~ $125 as mentioned above.
Hugh
AnswerID: 89096
Follow Up By: Ferret - Thursday, Dec 16, 2004 at 17:20
Onya, i'll give 'em call
FollowupID: 347996
Follow Up By: Ferret - Thursday, Dec 16, 2004 at 18:34
You wouldn't have their Phone number by chance would you, I couldn't find it in my White Pages.
FollowupID: 348016
Reply By: Mainey... - Thursday, Dec 16, 2004 at 19:10
Ferret,
Your Auto Sparky, I assume is licensed, he had to sit examinations etc...
And he also had to pass them… so he is qualified to give you advice!
You have ask him his opinion and he gives you an answer you don't like, and ask the same question on the forum and place your trust in the replies received from people that may not have a "certificate of competency in Auto Electrics".
However, some do have motives such as the desire to sell you a redarc isolator.....
FACT IS; Redarc specify in the centre of their own solenoid specifications sheet in BOLD their solenoid should only be used with two identical batteries… undisputable fact.
#Do you know why Redarc prints that warning there ???
#What is it Redarc know, that guys flogging them don’t want you to know ???
#Should we believe Redarc print the warning there for no reason at all ???
If you are using two identical batteries then buy redarc in place of the qualified advice of your sparky, if you have two different batteries consider this; what gives someone on a forum selling redarc isolators the right to tell the isolator manufacturer their own tech specifications are wrong ? ? ?
I have asked Redarc to explain to me 'in writing', why they print the warning there in the centre of the page and in bold, to date no will do, just say some people have them connected with two different batteries…
and send me a catalogue.
just my thoughts, and I have no connection to anything electrikaal.
AnswerID: 89120
Follow Up By: Ferret - Thursday, Dec 16, 2004 at 19:46
Hmmm, good point, didn't think that far. I currently have a Calcium wotsit battery and was going to put in a cranker/deep cycle hybrid thing.
what DOES happen if the batteries are diferent? Surely the Redarc treats each battery individually???
FollowupID: 348034
Follow Up By: Ferret - Thursday, Dec 16, 2004 at 19:51
Hang on a sec, I just checked there website and the picture shows a starter batt and a deep cycle batt???
FollowupID: 348038
Follow Up By: Mainey... - Thursday, Dec 16, 2004 at 20:20
Ferret,
Not when I checked just now on the Redarc website-> http://www.redarc.com.au/
There are no pictures of batteries at all, that is not the point, the technical specifications sheet in the redarc box clearly states in Bold in the centre of the page “the batteries are to be identical”, what is indicated in an advertisement picture is not what you get in fact.
Is Like the pictures of pizza in the local pizza shop display never look like the product.
What is the web address where you saw the two batteries ??
FollowupID: 348042
Follow Up By: Tim HJ61 - Thursday, Dec 16, 2004 at 20:37
Mainey,
Indisputable facts can vary it seems.
On the instruction sheet of my Redarc isolator purchased at the 4WD show last month for $140, it does not state "identical":
It states in bold, in the middle of the front page:
"We recommend the use of similar style batteries in one installation. If uncertain, always check with your battery supplier."
Obviously your instruction sheet reads differently, maybe for an older version.
I have contacted Redarc several times by phone and email regarding my isolator and my Charge Equaliser - for my 24v system. They have always been very helpful, understood my problems, provided more information that I expected, and are currently resetting the isolator to different cut in cut our voltages to suit my circumstances. None of my queries are related to the quality or faults in their products, just me trying to get my set up right. Full marks to them for customer service.
Tim
FollowupID: 348046
Follow Up By: Ferret - Thursday, Dec 16, 2004 at 21:26
I went via the short cut in this thread and if you look around there is a drawn picture of a wiring diagram clearly showing a starter/running battery and a deep cycle.
FollowupID: 348057
Follow Up By: Mad Dog (Victoria) - Thursday, Dec 16, 2004 at 22:29
It clearly says "START & RUN BATTERY" and for the second battery it clearly says "DEEP CYCLE BATTERY"
http://www.redarc.com.au/sbi-techspec.htm
FollowupID: 348070
Follow Up By: Mainey... - Thursday, Dec 16, 2004 at 23:57
Ferret, I apologise to you
I did use the wrong word, however the content is still essentially factual and accurate, and as Tim HJ61 has decently shown me the error, and posted in confirmation -->
"It states in bold, in the middle of the front page: We recommend the use of similar style batteries in one installation. If uncertain, always check with your battery supplier."
Mad Dog, I went to the web address you kindly supplied, it actually shows a drawn "Diagram" not a picture, yes it has the words as you posted, however when the Technical Specifications sheet as supplied with the actual isolator states emphatically in plain simple English "similar style" and as redarc refuse to put in writing to me that a Deep Cycle and a cranking battery can be used without any problems, I would not use one.
Pity as they are cheaper than electronic isolators, so I bought a product where the manufacturer actually states; "Allows the use of dissimilar batteries i.e. age, design or size. e.g. cranking/deep cycle"…….. IMO is better to be safe than sorry.
FollowupID: 348083
Follow Up By: Mad Dog (Victoria) - Friday, Dec 17, 2004 at 18:15
A starter battery used in conjunction with a conventional deep cycle works just fine Mainey. This is what it's made for...see the diagram on the Redarc website.
FollowupID: 348178
Reply By: hl - Thursday, Dec 16, 2004 at 21:34
There are 2 issues. If you use an ordinary solenoid that just parallels the batteries, there will be a voltage spike from the solenoid coil whenever it is de-energized. This may or may not damage the computer over a period of time.
The computers are obviously protected in some way and it may never happen. A simple precaution is to connect a diode across the coil. Some solenoids already have this.
If you use 2 different batteries, i.e. a normal starting battery and a deep cycle one, there will be problems when the deep cycle one is discharged. As the solenoid (or relay) closes, it will apply the full voltage to the deep cycle battery and will charge it at a very high rate, which is something that should be avoided as it will severely shorten the service life of the deep cycle battery.
Some, but not all battery controllers have current limiting to avoid this probblem.
AnswerID: 89157
Follow Up By: Pauly - Thursday, Dec 16, 2004 at 22:07
As a sparky i chose to stay out of this one but i must say very well said hl i couldnt have said it better.
FollowupID: 348065
Follow Up By: Ferret - Friday, Dec 17, 2004 at 12:00
Perfect, just the sort of info I was after.
Many thanks
FollowupID: 348130
Reply By: Member - Stillthinkinaboutit - Thursday, Dec 16, 2004 at 22:55
Only problem with your theory is that a Deep Cycle wet lead acid battery has a higher internal resistance than a starter battery and will not draw anywhere near the current a starter battery will.
Most will only draw a few amps even after being heavily discharged.
You will certainly not require any current limiting for a conventional wet lead acid deep cycle battery.
Most AGM batteries and GEL batteries are another story, they can draw anywhere up to 75% of their A/H rating whilst charging.
AnswerID: 89167
Follow Up By: muzzgit - Friday, Dec 17, 2004 at 02:26
Oops, I have a redarc under the bonnet of my 3.0 patrol, which is absolutely and positively computer controlled, and I have just fitted a wet lead deep cycle on one side and a GEL type starter on the other!
Am I asking for trouble ????
Cheers Muzz
FollowupID: 348087
Follow Up By: hl - Friday, Dec 17, 2004 at 06:38
It is not a theory, it is a fact. Yes, a deep cycle will not take as much current, but still much more then is good for it at the initial surge.
And, as you pointed out, gel cells will be really hairy,
FollowupID: 348090
Follow Up By: Wok - Friday, Dec 17, 2004 at 07:25
Muzz,
What GEL did you get?
rgds
FollowupID: 348094
Follow Up By: Member - Stillthinkinaboutit - Friday, Dec 17, 2004 at 09:03
Hi Muzzgit,
The Redarc isolator is fine, it has spike protection and is considered to be quite a good isolator. ( And no, I do not use a Redarc ).
As for the GEL battery, ( if it is a TRUE GEL battery ) well, you could have a problem here.
Most GEL batteries do not liked to be charged at 14.4 volts which is what your typical vehicle alternator/regulator is set to. Typically a GEL battery when charged at this voltage will have an extremely short life.
I would suggest having a look at the datasheet for your battery and see what the manufacturer states.
Regards,
Mark
FollowupID: 348105
Follow Up By: Mainey... - Friday, Dec 17, 2004 at 12:28
Mark
I don't believe a spike problem exists with the redarc and I understand it to be an excellent isolator when used as the manufacturer has actually specified.
It is only the charge/discharge method when using different "styles" of batteries; hope I have used the right word this time, lol.
Eg; as you have pointed out, the problem is with batteries that do require different charge rates, that is why redarc specify on their own specifications sheet, the "customer should check with their battery supplier…. "
ie; they don’t accept responsibility
And you only get this really good information after you have bought the isolator and opened the box, it is not mentioned in any adverting blurb in their brochures or on their website :(
The undisputable fact still is the problem does exist……..
FollowupID: 348133
Reply By: Member - Andrew O - Friday, Dec 17, 2004 at 09:14
Do a google search on TRAXIDE. This is the only isolator around that will keep the batteried connected in parallel until their combined voltage drops to 12.0V (still enough to start the car on one battery) - adding quite a bit of "free" power into the system. Australian made - and the owner is happy to work with you. No affiliations either, and my car has an ARB unit (fitted by the dealer)!
AnswerID: 89197
Follow Up By: Austravel - Friday, Dec 17, 2004 at 12:24
Looks like a great unit, wish I'd known about it before I brought a Redarc. Will have to check it out a bit more as I want to put in an extra battery and was just going to buy another Redarc.
FollowupID: 348131
Follow Up By: Mainey... - Friday, Dec 17, 2004 at 12:56
Below is pasted from the Traxide website
"The SC40 is a 40 AMP Automatic Dual Battery Monitor & Charge Control System that will control either the charging of an Auxiliary Battery or the operation of Accessories powered from the Auxiliary Battery"
"The SC80 is a 80 AMP Automatic Dual Battery Monitor & Charge Control System that will control the charging of one or two Auxiliary Batteries at the same time"
The system does 'look' as in appearance similar to various other brands
it is obviously a fully electronic system, as those other brands also, so charging different “styles” of batteries would not be a problem for it, do you know a price?
FollowupID: 348139
Follow Up By: Mad Dog (Victoria) - Friday, Dec 17, 2004 at 13:21
The prices are on the website
Prices
FollowupID: 348143
Follow Up By: Wok - Friday, Dec 17, 2004 at 14:19
TRAXIDE is made by 'drivesafe'.
FollowupID: 348153
Reply By: muzzgit - Sunday, Dec 19, 2004 at 01:58
Oops. I stated GEL starting battery, and this is absolutely wrong!!!!!
I should have typed CALCIUM starting battery.
Sorry about that.
Muzz
AnswerID: 89427
Reply By: Member - Hugh (WA) - Monday, Dec 20, 2004 at 15:52
Hi Scott,
Per your other question re contact details for Alanco who supply Redarc solenoids, amongst many other electrical needs.
Alanco Automotive Products
83-85 Welshpool Rd
Welshpool, WA
9458 1300
www.alanco.com.au
Regards,
Hugh
AnswerID: 89586
