Unrelated Laptop question
Submitted: Saturday, Dec 18, 2004 at 21:41
ThreadID: 18684 Views:2046 Replies:11 FollowUps:22
I have to take the Big Bird to a distant land in the new year. Having not taken a laptop with me before, I would like to know from other travellers......is it safe to have the laptop scanned through the airport security system as far as Xray scanning goes? Or do I have to make other arrangements.
All answers appreciated
Reply By: GTBen - Saturday, Dec 18, 2004 at 21:44
Willem, I've been to Sydney many times and the laptops are quite fine through the xray machines.
AnswerID: 89398
Follow Up By: Willem - Saturday, Dec 18, 2004 at 21:50
Thanks mate...it all helps.
FollowupID: 348263
Reply By: Member - Jimbo (VIC) - Saturday, Dec 18, 2004 at 21:55
Willie,
I travel more than I would like with a "Fliptop"; in and out of many airports and there is no issue.
Trust you are well and how is Uncle Milton?
Kind Regards,
Jim.
AnswerID: 89399
Follow Up By: Willem - Saturday, Dec 18, 2004 at 22:03
Ta Jimbo
Yeah, I am well...very busy with all sorts of projects...as usual.....
Unlce is hanging in there with a few minor health issues...keeping busy...will see him tomorrow as he will be coming to our Xmas Party....some forumites are coming as well....should be a good get-together...lots of tucker and booze........................
FollowupID: 348269
Follow Up By: Member - Jimbo (VIC) - Saturday, Dec 18, 2004 at 22:28
I'd love to be there Willie.
Hope you all have fun and best wishes to all.
Jim and Stevo ( he still talks about you blokes).
FollowupID: 348276
Reply By: Bob of KAOS - Saturday, Dec 18, 2004 at 22:06
Willem,
I hate just sitting in an aluminium tube not knowing where we are on the Earth's surface. I find the moving map display that they provide doesn't have enough detail. At least while flying over Oz I run OziExplorer with the GPS against the window. You need a window seat. Be reasonably discrete as some flight attendants get twitchy. The Map330 usually gets enough of a signal even when sitting on the fold down table.
AnswerID: 89403
Follow Up By: Willem - Saturday, Dec 18, 2004 at 22:26
Thanks Bob
As you might be aware I have more to worry about than where I am on the earth's surface. I have a 35hour flight schedule from the sticks to the Big Smoke in Africa and beyond and I have to take the laptop with me for info. Carrying all the stuff with me is posing a problem especially as movement is restricted but I will make a plan. Sometimes when flying over Central Aus I look out over the vast desert and wonder...have I been there? Is that a track to somewhere?
FollowupID: 348275
Follow Up By: Tuco - Sunday, Dec 19, 2004 at 10:37
Bob,
Quite rightly so!!
There have been many documented instances here in Australia of aircraft navigation systems being influenced by mobile phones, portable GPS, and other electronic devices.
Use of these devices can and will give false position information to the cockpit instruments. This is why we are told not to operate this equipment on board the aircraft.
Mobile phones and GPS are constantly transmitting a signal, in order to gain cell information or locality information. Most people are under the misconception that a mobile phone only transmits when in connection with another phone.This is incorrect.
FollowupID: 348312
Follow Up By: Patrol22 (Queanbeyan - Sunday, Dec 19, 2004 at 11:22
Tuco - while mobile phones are constantly looking for a new cell to lock onto the same is NOT true about GPS. GPS are passive devices only they have no capacity to transmit anything. They simply listen for the signal from the various GPS satellites in orbit around the planet.
FollowupID: 348317
Follow Up By: Bob of KAOS - Sunday, Dec 19, 2004 at 14:48
Tuco,
I think Patrol 22 is right. The GPS may have an oscillator but would emit no more interference than a GameBoy or CD player. The phone on the other hand is designed to transmit RF at pretty high levels in weak signal areas, so is a different kettle of fish.
The other aspect is that navigation is critical around airports but less so once the aircraft is at cruising altitude.
FollowupID: 348336
Reply By: Member Eric - Saturday, Dec 18, 2004 at 22:51
Willem the lap top will be fine , but you may have a issue with the full automatric weapon you are taking with you for security lol .
AnswerID: 89412
Follow Up By: Willem - Saturday, Dec 18, 2004 at 23:00
You know what happened to that bloke when asked "what do you have in that violin case?" and he said(jokingly) " A machine gun..what else"?...Hmmmm they took him to the cleaners....hahahaha
I have to worry about the steel knee prosthesis...have a letter from my Doc tho...so should be Ok ...........:o)
FollowupID: 348282
Reply By: KiwiAngler - Saturday, Dec 18, 2004 at 22:56
You will have to take the battery out when it goes through the scanner. Once through u can put it back in
AnswerID: 89415
Follow Up By: Willem - Saturday, Dec 18, 2004 at 23:03
No one else has mentioned the battery........what does the scanner do to the battery?
FollowupID: 348283
Follow Up By: KiwiAngler - Saturday, Dec 18, 2004 at 23:06
It doesnt do anything to the battery but they make you take it out so they can see the contents of the laptop. They cannot scan through the battery so they remove it from the puter body
FollowupID: 348284
Follow Up By: Willem - Saturday, Dec 18, 2004 at 23:09
So I will have to carry a screwdriver with me as well..........sigh!!!!
FollowupID: 348285
Follow Up By: KiwiAngler - Saturday, Dec 18, 2004 at 23:21
mmm..not sure what sort of laptop you have but it has been a loooong time since I saw one that needed a screwdriver to remove the battery, Usually they just slide out when u push the relese button thingy (technical term...heheheheh)
FollowupID: 348286
Follow Up By: Willem - Saturday, Dec 18, 2004 at 23:43
Pioneer laptop...generic Aussie made from bits 'n pieces put together...ex Sydney...November 2002 build........still need a small phillips :o)
FollowupID: 348289
Follow Up By: Member - JohnR (Vic) - Sunday, Dec 19, 2004 at 00:11
Willie, I hope you have a great trip and get the puter set up for the moving map and all. I have never had to remove the battery though I heard about it after 9/11. I have travellled Europe and Australia and a couple of Asian airports between with a laptop with the battery remaining in every time. US with the previous laptop and no battery removal either.
Has been the case in Kiwiland too Angler.
Willie, have a great Christmas - you and Judith, cheers mate.
FollowupID: 348293
Follow Up By: Member - Mungo Explorer (NSW) - Sunday, Dec 19, 2004 at 00:27
I've travelled with laptops all over the world, including the post-9/11 paranoia that is the US, but I've never had to take out the battery. Be aware though that you often (including in Sydney) have to have the laptop ready for inspection as you approach customs, so don't bother to bury it deep in your luggage. Sometimes they ask you to switch it on to verify it's a laptop rather than a Toshiba-branded bomb.
FollowupID: 348294
Follow Up By: Member - Jimbo (VIC) - Sunday, Dec 19, 2004 at 09:47
I've heard that they ask people to remove the battery but it has never happend to me. The theory I heard was that they want to check that it is in fact a battery and not some form of explosive.
BEWARE about carrying a screwdriver, they will confiscate it as it can be construed as a weapon.
Jim.
FollowupID: 348304
Follow Up By: Member - Crazie (VIC) - Sunday, Dec 19, 2004 at 10:34
Depends on the Airline and the airport, if you have to pull the battery. I have had to do it a few times, but lately I have never had to.. If you require a scewdriver, doubt you will have to pull it out mate. cheers
Ads
FollowupID: 348311
Reply By: Member - John (Vic) - Saturday, Dec 18, 2004 at 23:22
Hmmm S.A. sounds like that ships on the move again. LOL.
Hope it's a positive trip.
AnswerID: 89418
Follow Up By: Willem - Saturday, Dec 18, 2004 at 23:40
Nah.........Ship's idle.......some one else is paying...gotta go though...one of those things......think I told you about it once...maybe :o)
FollowupID: 348288
Follow Up By: Member - John (Vic) - Saturday, Dec 18, 2004 at 23:45
Yeah I think you did.
When you going and for how long ?
FollowupID: 348290
Follow Up By: Willem - Saturday, Dec 18, 2004 at 23:52
End of January for 2 weeks
Have to be back in Melbourne by end of February so Eric can fit those sprinngs and shocks he has been promising for months......I really don't know,,, you can't find good tradewpoeple these days LOL
FollowupID: 348291
Follow Up By: Member Eric - Sunday, Dec 19, 2004 at 10:20
Well drive to Melbourne , leave car at my house , catch flight , come back , Eric picks you up in you new pimped out GQ lol
6" lift , 3" body lift 38" swampers lol
FollowupID: 348309
Reply By: rihearn - Sunday, Dec 19, 2004 at 08:17
If you take a screwdriver to remove the battery remember it will be confiscated unless you leave it in the luggage going to the hold. That defies the purpose of taking it as your laptop will be in your handbaggage.
I'd not bother taking the screwdriver/lethal weapon. If they want the battery out let them remove it.
I've had a set of nailclippers confiscated as they were felt to be dangerous. They were the sort without scissors or a blade. I took it as a compliment that they thought I looked big and mean enough to be able to take over a plane with a pair of nailclippers!!!
AnswerID: 89434
Reply By: CUM800 - Sunday, Dec 19, 2004 at 10:35
Willem
They will ask you to remove the battery so be prepared and remove the screw and tape it to the laptop before you go. You can put it back in on your arrival and likewise on your return. They will confiscate your screw driver.
I have done this on a few trips and no dramas.
AnswerID: 89442
Reply By: Karsten from Birdsville Studio - Sunday, Dec 19, 2004 at 11:05
Did anybody see SPOOKS last night on ABC ???
AnswerID: 89451
Follow Up By: Bob of KAOS - Sunday, Dec 19, 2004 at 14:44
Yeah - good ending.
FollowupID: 348335
Reply By: Cabbage - Monday, Dec 20, 2004 at 00:25
Don't worry , I know all about computers, see ,Powerunit here ,Hard drive here and look even has the M/B clock over herrrrrrrrreeeeeeeeee Um
Last two words oooooooohhhhhhhhhhhhh shhhhhhhhhhhhhhhhhiiiiiiiitttttttttttttttttttt
Leave nothing but footprints & take nothing but photos
AnswerID: 89516
Reply By: Willem - Monday, Dec 20, 2004 at 07:25
Thanks for all the replies, fellas.
I think I will go with a Removable Hard Drive or something similar. Might even see if I have enough left over from Xmas shopping for a Navman and a 1Gig card.
I see that MY Documents is still only 901Mb in size despite the hundreds opf pics and data.
Less hassle and much lighter to cart around.
AnswerID: 89524
