recycled car batteries
Submitted: Monday, Dec 20, 2004 at 21:43
ThreadID: 18730 Views:2199 Replies:3 FollowUps:2
Not that i need one but i would like to know how do you recycle a car battery.
Reply By: Rosco - Bris. - Monday, Dec 20, 2004 at 22:45
Easy cob
Do as I did today. Take it to a battery place, give him mucho dollaros, walk out with a new one, leaving the old behind. QED
Cheers and merry Chrissy
AnswerID: 89664
Reply By: greghud - Tuesday, Dec 21, 2004 at 00:32
when recycling the battery they throw the whole battery in to a big tank of boiling water and that melts the plastic witch floats to the top lead sinks to the bottom and they collect it melt it down and make cheep batterys like u will get at kmart or super cheap u know the NO NAME brand ones, they usualy dont last as well as the better quality batterys coz of the quality of the material being used.
dont know if you would want to do that at home? maby to make some sinkers and go fishing, now theres an idea
AnswerID: 89678
Follow Up By: V8troopie - Tuesday, Dec 21, 2004 at 01:13
May I suggest that melting down a battery at home to get the lead is a lousy idea?
I actually tried such a foolish thing many years ago, when backyard incinerators were still the norm, got lots of nasty smoke and fumes and a few dribbles of grotty lead for my troubles.
It ain't worth it, believe me.
The bit above, where plastic battery cases are supposed to melt in 100 deg water is either a furphy or very worrying. Please tell me the brand that 'melts' at 100 deg so I can avoid it.
What more likely is happening is that the boiling water melts the tar seal of the plastic battery case and it falls apart.
The case could be re - used as is or granulated to make new cases.
The lead grid ( mostly oxide anyway) would have to be recycled cemically or by electrolysis, just heat is not going to do the trick, IMO.
I have no idea if they recycle the seperation grids as well.
FollowupID: 348489
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Dec 21, 2004 at 08:39
Boiling water wont melt plastic!!!
FollowupID: 348500
Reply By: greghud - Tuesday, Dec 21, 2004 at 01:18
u are right bout melting down at home. it is stupid i just like the fishing idea re the plastic again correct its just to seperate and also dissolves the acid in the batterys just let the pros take care of it for you.
AnswerID: 89687
