Recommendations for Hydrometer & Amp-hour meter
Submitted: Tuesday, Dec 21, 2004 at 18:18
Wok
Hello,
I after suggestions for a hydrometer & amp-hour meter to monitor my batteries.
I have one of the 'leadshot in glass tube ' things and I can't get consistant/repeatable measurements.I prefer a model with digital readout [bad eyes] & a serial output would be nice.
Ditto for Ah meter.
The idea is to hook up the devices to an old PC set up as data logger.
Reply By: Chucky - Tuesday, Dec 21, 2004 at 20:46
G'day Wok,
The most accurate type of hydrometer is the buld and pipette type, where you suck the electrolyte into the hydrometer and read the float. They should be stored in a shock proof storage, something like a roll of foam is fine and stored on their side after they have been flussed out with fresh
water and dried. Of coarse these are only good for liquid batteries and not gel type. You can get digital ones but they do take up a lot of room and I have found that they lose calabration quite easily and quickly. As for the amp-hour meter I haven't really heard of such a thing. The amp hour rating of a battery is the amount of amps that a battery can put out for one hour. So if a battery has a twenty amp-hour rating you can put a load of twenty amps on it and it will last for one hour. However you can also put a 5 amp load on it and it will last 4 hours, one amp- it will last 20 hours ect. This is assuming that the battery is in good condition and fully charged of course. So all you really need is a amp meter to measure this. But I recommend that you compare the amp meter to a multimeter at least every twelve months as they can go out of cal.
As for data logging I can't really help there as I haven't done it before but would be interested to find out how you do it.
Hope this helps.
89802
Follow Up By: Wok - Wednesday, Dec 22, 2004 at 07:47
Thank you Chucky,
That is the hydrometer I have......bad eyes = bad results!
348640
Reply By: Eric Experience. - Tuesday, Dec 21, 2004 at 22:21
Wok.
If your prepared to go to the trouble of setting up a data logger you can do it the way its done in proffesional battery systems. What you use is an A/D converter conected to the negative terminal of your battery measuring the voltage across the earth lead of the battery. then write a program to sample the voltage about every minute, store the data in two files one for negative numbers and one for positive.At the end of the day total the files and record your gain or loss. Eric.
89818
Follow Up By: Wok - Wednesday, Dec 22, 2004 at 07:51
Hello Eric,
Yes..I would just need a shunt to measure the current [need calculation after]...then measure voltage through 2nd port....should work.
Any thoughts on hydrometer?
Thks
348641
Reply By: John - Tuesday, Dec 21, 2004 at 22:46
Dear Wok
The Plasmatronic regulators (PL20,PL40 & PL60) have an amp hour display. They can also be hooked up to a PC, but the stand alone display will give you AHrs in, AHrs out, SOC, bat V, SolarV, A in, and A out. Much better than Hydrometer. There may be cheaper ways if you dont need a good regulator (about $400 for the PL20 from memory).
Cheers John
89827
Follow Up By: Wok - Wednesday, Dec 22, 2004 at 07:54
Hello John,
I was looking at the PL20 a while back......brilliant unit.......just can't go the $....to work for monitoring it needs shunt & PLS2 interface as
well....really brings up the $
Thks for your suggestion
348642
Follow Up By: Member - David C (QLD) - Wednesday, Dec 22, 2004 at 08:04
Hi Wok,
Go to ebay following this link and you will find a cheaper alternative to the plasmatronics unit complete with amp hour logging. There is also a link to the manufacturers website for more info.
348644
Reply By: Nudenut - Wednesday, Dec 22, 2004 at 08:26
lots of info on "digital hydrometers" on net ...but expensive approx US$2000
89856
Reply By: Wok - Wednesday, Dec 22, 2004 at 15:28
Thank you David C & Nudenut,
The Manson product is interesting........even found they make Dc-dc converters!...bonus.
Nudenut.....I never even thought of putting 'digital' in front of hydometers!!........duh..duh...........
Have a great Christmas & safe 2005 guys...........
Thks
89924
Reply By: Eric Experience. - Wednesday, Dec 22, 2004 at 22:44
Wok.
If you use the voltage on the negative terminal to input your data logger you dont require a shunt as the battery earth strap is the shunt, as far as calibrating it goes you just turn on your lights and note the voltage and calculate the amps from the lights power. If you have this system you dont have to use a hydrometer because you know the state of charge. Eric.
89997
