"soft" 4wd vehicles on Border Track
Submitted: Thursday, Dec 23, 2004 at 21:14
Casnat
Hi Guys, 1st time posting (but a long time observer).
Has anyone any experience with "soft" 4wd's on the
Border Track? I have a Patrol and have done the track twice but friends want to join me on the run and they have a Mazda Tribune and a Suzuki Vitara (would be a day trip for 3 families). I have not driven these vehicles and am not aware of their capabilities but I think they should cope. I will be there with the Patrol to help out and we will not be loaded up. Of course tyre pressures etc will be lowered.
The other drivers are not experienced 4WD'ers. I will have recovery gear but not a winch.
Any thoughts / experiences with such vehicles in these conditions?
Thanks in advance for this advice and the tips I have gleaned from the
forum in general in the past
Trevor
Reply By: Truckster (Vic) - Thursday, Dec 23, 2004 at 21:36
Nice having recovery gear etc, but the Tribute has no recovery points... so that wont work...
Vitara will go anywhere they are great 4b's but the tribute, ....
I'd look elsewhere.
90125
Reply By: Bonz (Vic) - Thursday, Dec 23, 2004 at 21:46
Agree totally with the T-Man, Mazda bad Zook good
90129
Reply By: Willem - Thursday, Dec 23, 2004 at 21:59
A winch is not necessary on the
Border Track. Vitara will go anywhere. Tribute might get close but with no low range may have a problem with dunes. Trouble is when you tackle a track with an underrated vehicle then you are looking for something to go wrong. If your mate does not mind some under body damage or the possibilty of damage to the drive train of his ribute then take him with you. I would err on the side of caution though.
90131
Follow Up By: Member - Jimbo (VIC) - Thursday, Dec 23, 2004 at 22:13
Willie,
In your experience, would a relatively light weight vehicle boasting a power output of around 150 Kw necessarily need low range to tackle dunes? I have no idea if the severity of the dunes in this area, just asking the question.
Jim.
348879
Follow Up By: Willem - Thursday, Dec 23, 2004 at 22:24
Jimbo
Power isn't everything. Torque is.
The Tribute might have the grunt on a flat surface but when challenged on a relatively rough surface it may not fare so
well. You have to take into consideration the terrain. With low tyre pressures an whole heap of grunt may be more problematical than anticipated. Sometimes there is a need for low range. Depends on the situation. Coastal dunes, desert dunes and mallee dunes are all different. The last three dunes on the track are severe. I'm not say the Tribute won't get up them but at what potential cost? Break something out there and the recovery will cost aplenty :o)
348881
Follow Up By: Member - Jimbo (VIC) - Thursday, Dec 23, 2004 at 22:44
Thanks Willie,
Understand your point as I saw your low Kw, torquey truck do wonderful things in sand.
I have also seen some examples of lightweight, high powered vehicles, power up dunes that have stopped the the "big boys".
Of couse my understanding of dunes is very limited and I will defer to your knowledge and experience.
I also get your point that power to weight ratio may mean nothing if the car is not up to the task.
Jim.
348894
Reply By: Casnat - Thursday, Dec 23, 2004 at 22:00
Thanks for that, We will obviously have to rethink. Interestingly, without knowing much at all about either vehicle I was more worried about the Suzuki given it is a 4 cyl vs the Mazda 6cyl. Recovery points is something I hadn't investigated. The
Forum comes thru again!
Trevor
90132
Follow Up By: Member - Jimbo (VIC) - Thursday, Dec 23, 2004 at 22:09
Trev,
I speak from a position of total ignorance, but I have seen some fairly "meaty" recovery hooks available at ARB for about $50. Of course they then need to be fitted.
Whether or not the Tribute has a suitable, and strong enough, point to fit them, I wouldn't know.
If it is possible, $50 for the hook, perhaps $100 to fit it (just a guess), could be a cheap investment?
Just the thoughts of an amateur.
Jim.
348876
Follow Up By: Willem - Thursday, Dec 23, 2004 at 22:11
Why not drive the Murray Sunset
Park from Murraytown to Nhill and then maybe down to Little Desert NP. There are some good all wheel drive tracks there(even some of the side tracks on the Murray Sunset run are good for all wheel drives)
348877
Reply By: Casnat - Thursday, Dec 23, 2004 at 22:18
I guess we were looking to give the soft 4by's a bit of excitement without coming unstuck.....always a bit of a guessing game. I think we will re-evaluate. Perhaps we will find a way to cram everyone into the Patrol and go for it. Sounds like everyone thinks the Suzi is up to it. I may have got the 4 cyl thing wrong anyway it seems with regard to the Suzi . Possibly the Mazda can do the centre track and meet us on the other side.
Thanks for your input
90137
Reply By: D-Jack - Thursday, Dec 23, 2004 at 22:52
Casnat
If you're just doing the section between Pinaroo and the edge of the Ng??**)* Conservation
Park, should be no problems. There are multiple tracks over the dunes, if can't get up one, a push backward and reverse will get you back to start to try another.
There are no really deep bog holes to speak of, with deep wheel ruts, as long as you stay within the
park. They have all been filled in the
park by 4wd clubs. If you go further on toward Bordertown out of the
park, you will run into trouble as there are spots you have to take the ruts. Careful skillful driving in a softroader may get though but not worth the worry and risk.
Only 4 or 5 sets of dunes, with ways around each. Correct me if I'm wrong. Shouldnt be hard to get the Tribute out of sand on a
hill, just go the way the
hill is decending. Can always go back the way you came.
My personal opinion is highway terrain tyres in most cases may be as good as muddies in the sand. Differing opinions on this, I will come under fire for saying this. Correct pressures the key.
Trip will not be much fun it if is too hot.
I'm not telling you to do it but giving you the information I have. Having said all this I stuffed up my clutch and alternator in deep sandy
water in deep bog holes last trip (we went on further than the
park though)!!
D-Jack
90147
Follow Up By: Bonz (Vic) - Friday, Dec 24, 2004 at 17:23
Ngarkat
348971
Follow Up By: D-Jack - Friday, Dec 24, 2004 at 19:38
Thats the one. Silly me.
348982
Reply By: Crackles - Thursday, Dec 23, 2004 at 23:06
Trev, I believe both cars would make it down the
Border Track, it would be just a matter of damage. Not sure what tyres are fitted but the Mallee roots aren't kind to road rubber & the trees tend to scratch a fair bit. With good power to weight, low range isn't required. I ran a Subaru down there years ago when it was harder & other than dragging the belly alot got through unaided. Secure front & rear recovery points are a must. Remember also the track is harder when the sand is dry.
One concern; you say it's a day trip. From where? It's a long way around no matter where you come from.
Cheers Craig...........
90149
Reply By: Mad Dog (Victoria) - Thursday, Dec 23, 2004 at 23:24
no probs just don't go past the
red bluff turnoff. Take the track to the east to the
Murrayville track or head west to the bordertown/Pinaroo road...depends on where you want to get to. Two very serious dunes to get over, steep and soft sand, great ground clearance not required, a powerful and light vehicle will have no probs.
90154
Reply By: Casnat - Thursday, Dec 23, 2004 at 23:49
Thanks for the input. As is rightly so, I will pass this on to the relevant owners and let them decide. I think we could cope but it is their decision. Will post on how things progress.
Thanks for advice...Trevor (now that I have broken the ice I imagine we will correspond some more)
90160
Reply By: flappan - Friday, Dec 24, 2004 at 09:57
One of the KEY things here is , ANY vehicle can get stuck. You need to be able to recover it safely.
If ANY of these vehicles DO NOT have PROPER RATED recovery points.
DONT DO IT . . . fullstop.
and back to your original question , the Vitara should do it easily. In sand , assuming that the Mazda is an auto (I think they all are ?) , plenty of torque , coupled with the auto . . . "should" get you out of most problems. Correct tyres pressures will assist.
No low range will hurt more with steep climbs/decents.
90194
Reply By: duncs - Friday, Dec 24, 2004 at 22:21
I don'tknow the track or the Mazda but all above seems relevant. No body has mentioned the fact that the most important piece of recovery gear, especially in soft sand is a shovel.
I assume 3 families means 3 dads. If there are alternate tracks around the big dunes and you have 3 adult males in the group, you should be able to dig any vehicle out and find a way around. No towing involved, no need for recovery points.
Like I say I don't know the track and there may be other problems along the way, sloppy mud is a different story.
Sadly I am in NE NSW, Stuck with beaches, no vehicle access, and blacktop and very little opportunity to get bogged, at least until the last week in January. Oh
well at least the surf is good and we don't see much of that back home in the
Hill.
Merry Christmas all
Duncs.
90265
Reply By: geocacher (djcache) - Saturday, Dec 25, 2004 at 01:33
Did the
Border Track a few weeks ago and had problems with a Hilux in our group not being able to engage 4wd due to problems with the auto locking mechanism. It got around in 2wd with 18psi and a bit of loud pedal at times.
I wouldn't have wanted to be in my wife's Forester (manual with pseudo low ratio) on several of the dunes north of
Red Bluff. The corrugations were over a foot deep and the spacing had Patrols, Hiluxes, Navaras and my Courier bouncing at times. The eggs didn't survive....
Go
camp at Big Billy
Bore and have a drive out around Firebreak Tk and Skeleton
Well. Twelve Mile Patch and Brushcutters are good too.
I'd avoid the
Border Track in those vehicles but only due to a few dunes and some of those didn't have alternate
routes.
You'll struggle to find somewhere that is capable of supporting a proper tow hook safely too.
Another issue is that it is getting really hot and dry up there now. The sand is getting really soft. The aforementioned Hilux would not have made it if we didn't do it with intermittent rain while we were there.
Great country but go in late winter or spring (wild flowers are spectacular)
90289
