FORD MAVERICK GEAR SELECTION
Submitted: Tuesday, Dec 28, 2004 at 09:25
pretender
GIDDAY GENTS,I AM HAVING A LITTLE TROUBLE CHANGING GEARS IN MY 92 DIESEL MAV,IT DOESNT GO INTO GEAR EASILY AND DOESNT MATTER IF I AM CHANGING UP OR DOWN,THE CLUTCH WAS DONE 5000K AGO.IT FEELS LIKE THE CLUTCH ISNT ENGAGING FULLY SO BLED THE SYSTEM AND ADDED NEW FLUID.COULD IT JUST NEED AN GEAR BOX OIL CHANGE.ENGINE ONLY HAS 190000K ON IT AND HAS BEEN
WELL MAINTAINED SO HOPING THE TRANSMISSION CASE IS OKAY. IT DOES SEEM TO CHANGE GEAR SMOOTHER WHEN DOUBLE SHUFFLE IS USED.HAVE TRIED ARCHIVE BUT COULDNT FIND ANY INFO AND HOPING SOMEONE CAN OFFER ME SOME ADVICE
THANKS & HAPPY HOLLIDAYING,IF YOU ARE.
CHEERS PRETENDER
Reply By: Member Eric - Tuesday, Dec 28, 2004 at 09:33
Sounds like my Mav when the Pivit ball snapped in the bell housing , funny enough , it happened about 3 weeks after i fitted a new clutch lol .
have a look inside the bell housing . There is a pivit point for your
fork. It either is broken or needs to be adjusted further out to give you more throw in the thrust.
Now you need to feel it , not look at it . By eye it may look ok , when you wiggle it , it will be a diffrent story.
90519
Follow Up By: pretender - Thursday, Jan 20, 2005 at 21:05
Thanks Eric for the feedback,i have now a new slave cylinder and new gear oil ,hasnt completely solved the problem but it certainly has improved,pivot ball is the next onthe list,will let you know how it goes .
cheers and thanks morto
353141
Reply By: Member - Jiarna (SA) - Tuesday, Dec 28, 2004 at 12:37
Might need to put a clutch slave cylinder kit in. My brother's 1981 MQ had exactly the same symptoms you described. Bleeding the system worked for a a bit, but air was getting in through the clutch slave cylinder seals which had gone hard. Recon with a kit was only about $30 or so (DIY of course), and fixed the problem. Don't know how much for yours.
90534
Follow Up By: Voxson (Adelaide) - Tuesday, Dec 28, 2004 at 15:44
I have a slave cylinder in my recovery kit and it was $62 brand new..
349164
Follow Up By: pretender - Thursday, Jan 20, 2005 at 21:09
sorry about the delay, but appreciate the feedback jiarna.
just replaced slave cylinder and gear oil,seems a lot better,however still doesnt feel 100% yet.Will have alook at vacuum and pivot ball.
thanks again morto
353143
Reply By: Flash - Tuesday, Dec 28, 2004 at 12:49
Definitely sounds like clutch adjustment or one of the above.
If it was a Holden for example, you would hear it "crunch" when you select reverse.
However the Mav gearbox has synchro on reverse which hides the problem of a clutch not disconnecting fully. Although the Mav gearbox is about as indestructible as you can get, a clutch not disconnecting fully won't do it any good.
Jack up the back
wheels and see if they'll turn when in gear (engine running) with the clutch fully depressed- if so then there's your problem. (Be carefull- it has a limited slip differential)
Cheers and happy new year.
90537
Reply By: Kiwi Ray - Tuesday, Dec 28, 2004 at 16:30
Do you have the correct grade of oil in the gear box?
If the oil is not as per spec this can make shifting very difficult as the syncros will not work as they should and you do say that it shifts fine with a double clutch
Ray
90550
Follow Up By: pretender - Thursday, Jan 20, 2005 at 21:15
thanks Kiwi Ray
i now have the castrol vmx in the box and definitely better as i did the slave cylinder first. waiting a week or two to see if there was a difference. both helped .
thanks morto
353146
Reply By: pretender - Tuesday, Dec 28, 2004 at 18:38
thanks for those replies gents,it is definitely harder to find reverse gear and 1st gear when the vehicle is stationary so will follow up on all those suggestions.the car hasnt done many k's over last couple of years and may have been sitting around a while so slave cylinder seals may definitely need doing as
cheers and thanks
morto
90559
Reply By: Truckster (Vic) - Tuesday, Dec 28, 2004 at 21:06
Take it back to whoever fitted the clutch and tell them to fix it.
90574
Reply By: Member - Brian H (WA) - Tuesday, Dec 28, 2004 at 22:55
My lil old mitsi colt had the same problem. Turned out to be oil related. Wound up putting some of that mega buck redline gear oil in it. That was 80000k's ago and still going strong. Try double clutching to see if that improves things.
90595
Reply By: Mark- Wednesday, Dec 29, 2004 at 10:47
Try replacing the gearbox oil with Castrol VMX80 - about $26 for 4 liters which will leave you with a little left over. Makes a huge difference over normal 90 wt gear oil. Also check your adjustment. The earlier post about jacking up the rear
wheels is a good idea due to sycro on reverse.
90630
Reply By: JonnoC - Monday, Jan 10, 2005 at 14:23
G'day Pretender and Others,
I may have a similar problem with my 92 Diesel Patrol. I purchased this vehicle recently and as part of its first service I had all the fluids replaced with top of the range stuff.
My problem is that sometimes (say 10-20%) when I change down from 4th to 3rd, or 3rd to 2nd, it doesn't want to go. I either have to force it or double-clutch. Changing up and down in other gears poses no problems at all.
The funny thing is that for the most part there is no problem at all and the gear changes are very smooth.
It may be my imagination, but perhaps the trouble occurs when I try to change down gears when I am going too fast. It would also seem to me that the clutch engages too early - ie friction point at obout 1 inch from fully depressed. I'm not sure if this is a problem, and if it is I'm surprised they didn't pick it up with the service.
I am not sure if this is the same problem as yours, but I'll let you know if I find out whats causing it.
Jono
92200
Follow Up By: pretender - Thursday, Jan 20, 2005 at 21:25
Gidday Jono
sorry i havent been quicker in my response,busy time of year for fireman,as you will read in responses,have put in a new slave cylinder,changed the gear oil as was also recomended on this
forum , has definitly improved it however still not what i would call 100 %.Still feels like it grinds a little.sometimes it feels great other times a little grindy.Will have alook at a couple of the other recommendations on this
forum,and will provide feedback.
thanks again Jono
353148
