Fridge insulation
Submitted: Wednesday, Dec 29, 2004 at 21:34
ThreadID: 18938 Views:4687 Replies:3 FollowUps:0
A few weeks ago there was several posts regarding adding extra external insulation to camping fridges from bought bags to making your own from various types of material. My question is do they help in any way or is the original suffice.
Reply By: ianmc - Wednesday, Dec 29, 2004 at 22:24
After a trip thru FNQ with a 45l Waeco where I occasionally slept beside it in back of ute in warm weather I had the IMPRESSION that it didnt cycle nearly as much with a sheet of 2 inch foam wrapped around it. This also protected it from bumps & vibration & may have quietened it a bit. No measurements done but must help.
AnswerID: 90701
Reply By: Member Colin - NSW Bungendore - Wednesday, Dec 29, 2004 at 22:58
My extra insulation was added to the frig at the same time as a 12v fan and direct 'heavy' wiring from the battery. So i'm not sure how much the insulation itself made - all I know is that the frig now frosts up the element inside the frig when running on 12v, which is a huge difference to the way it was.
The insulation I used was from Clark Rubber - it is a foam backed HD foil and is self adhesive so was easy to fit.
The frig is a Sadec 3 way - about 22 years old.
AnswerID: 90704
Reply By: Flash - Thursday, Dec 30, 2004 at 10:07
It's virtually impossible to have too much insulation.
The thickness provided by manufacturers varies, and is always a compromise on a number of factors including size and price.
Adding extra will ALWAYS help a fridges performance, as long as you are NOTcovering an area used by your fridge to get rid of heat (condenser).
AnswerID: 90729
