Cluth problems with LC 100 Diesel
Submitted: Thursday, Dec 30, 2004 at 00:00
ThreadID: 18942 Views:2854 Replies:7 FollowUps:5
Hello all.
I have a 2001 100 series diesel with 113 000km on the clock. The clutch was replaced at 96 000km on the 28/01/2004 under warranty. Until recently it has been fine. Now the thing shudders when cold and on other occasions so I call toyota and they say that the part is covered by warranty even though the car is out of warranty as the clutch was repalced less then 12 months ago.
I then take the car to Toyota and the service foreman says that it is a common poblem only with the diesels and that the problem will return, and that it could possibly be worse then what it is now once a new clutch is fitted.
He also says that Toyota has tried to rectify the problem by using after market clutches, parts and other numerous remidies without success, so they now only use genuine parts. He also stated that the 80 series does not have the same problems as the 100 series.
It seems strange that the 100 series has now been out for around 6 years and they cant fix the problem, its even stranger to think why doesn't the 80 series suffer the same problem as they basically have the same running gear.
So I have booked the truck in for a new clutch under warranty and then the foreman says if the problem returns I will have to put up with it or wear the cost myself, which I think is rubbish as they should again cover it for another 12 months/20000km.
Has anybody else had this problem, I know it is common and Toyota admits it? Does anybody have a solution for the problem with the 100 series clutches e.g aftermarket parts.
Reply By: 100 Series - Thursday, Dec 30, 2004 at 00:03
Sorry heding should read CLUTCH problems
AnswerID: 90712
Reply By: Des Lexic - Thursday, Dec 30, 2004 at 09:25
It is a common problem. My remedy is to carefully take off when the running gear is cold and when warm, it doesn't occur again until the next cold start up. Basically, I ignore it and don't let it worry me.
AnswerID: 90727
Follow Up By: Member - Roachie (SA) - Thursday, Dec 30, 2004 at 17:24
Best solution would be to buy a Nissan Patrol 4.2 Turbo Diesel......they do NOT have the same luxury interior appointments as the all-singing-all-dancing Toyotas, but they DO HAVE a bullet-proof drive train. In fact the clutch in the patrol is probably the weakest part of that drive-train, but is STILL 10 times better than Toyota's equivalent. As for the rest of the Nissan power-track....you wouldn't be able to kill the front diff with a steel bar (I think Toyota's blurb talks about....quote: "couldn't kill it with a stick"). Same goes for the excellent rear diff and LSD, the transmission -mounted handbrake etc etc.
Sorry blokes, I couldn't resist.................
By the way Des; how's the 50 series going????? Not running over any pebbles lately?
Happy new Year mate....
FollowupID: 349326
Follow Up By: Des Lexic - Thursday, Dec 30, 2004 at 21:36
G'day Bill, The 50 is doing just fine thanks LOL.
Just to keep the discussion balanced, you can remind me of the crap fuel economy and overheating problems with the .42
Best wishes to you, the cook and tin lids for the New Year.
Catch up soon.
FollowupID: 349345
Reply By: Member - 'Lucy' - Thursday, Dec 30, 2004 at 11:54
100 series.
Firstly: I have a 75 series Troopy that is always carrying a 'few' kilos that it shouldn't and it gets a very slight shudder when left standing for some time. (like days). When used regularly - no problem/s.
Secondly: In 1982 I purchased a brand new Datsun Bluebird Stn Wagon.
What a B A S T A R D of a machine.
I spent the next 20yrs fixing all its faults and I still have it. I now know it better than the back of my hand.
Anyway, after the first 5000kms this sucker gets a clutch shudder. Becomes real nasty, like it wants to drop the tail shaft.
165,000kms and 8 clutch kit replacements later. (yep 8 of them) I decide to rebuild the engine as I was running it on LPG.
I also decide to get the engine balanced which required a new clutch kit to be supplied for the balance job.
When I drop it off at the reconditioners for the rebuild and balance, I mention the clutch horror story to the dude booking it in and and he gets another guy out to listen to the story again which by now I can recite word perfect without taking a breath.
He immediately says " where is the flywheel"
I go and get it. He inspects it and says without a bat of an eyelid.
"you have got 'hard spots' in the flywheel face"
Yep! we all know what hard spots are don't we. So! feeling a right D I C K I ask what the hell are they.
He then tipped the flywheel on its edge so that the light shone obliquely across the polished surface and pointed out 3-4 areas that where obviously darker than the rest of the face.
What do you do about that I asked, and he stated that machining the face of the flywheel would cure it as long as their was enough 'step down' (meat, depth etc)
to take the hard spots off.
Apparently they are a surface type Phenomenon that occur for whatever reason/s.
RESULT/OUTCOME:
Never had a clutch shudder since then. Replaced that clutch 120,000kms later(worn out). Had the Flywheel re faced and it is still ticking along at 340,000Kms.
ITEMS OF INEREST:
Datsun replaced first one under their exceptional warranty of 12mths/12000Kms (people think they are hard done by these days, warranty wise) and refused to even talk about it after that. Can't say that I am bothered that they closed shop and skulked back to Japan.
Also not one of the 'mechanical geniuses' that I consulted at Nissan/Datsun (tech support) or the large number of Datsun dealer service centres or any other mechanical repair type service had a clue what it was.
No one but the good old fitter and turner/tool maker at the engine reconditioners that is.
RECOMMENDATION:
Seeing as how you are sending it back for a replacement clutch;
DEMAND that the flywheel is removed and sent to a machining shop for the the face to be machined off. Don't let them put you off even if you have pay for it yourself.
Under no circumstance let them send it to a brake place for machining.
In the overall cost of the exercise it is peanuts.
If you would like any further details you can contact me on
krobbo@optusnet.com.au
Ken Robinson
AnswerID: 90734
Follow Up By: Member - Roachie (SA) - Thursday, Dec 30, 2004 at 17:30
Jeepers Creepers, what a long yarn Mr Lucy!!! LOLOL
Can't be long now b4 the new baby arrives, eh?
What warranty do the Yanks provide on their venerable stead these days......????? Hope you're on first name basis with the head of the service department....hahahaha
Have a Happy New Year Ken........
Cya over here in '05 if you can make it this far.....
LOLOLOLOLOLOL
FollowupID: 349329
Reply By: Chaz - Thursday, Dec 30, 2004 at 13:25
Hi Guy's
I have had at least eight 80 Series LC's, and I think I'm driving my fifth 100 Series Cruiser at the moment. All leased work vehicles that we keep for one year or 50,000k's.
From my experience, some do it and some don't. We have sent them back to Toyota for clutch replacements and they come back with the same shudder as they had before. It usually gets better as they warm up, but it can be a horrible feeling taking off when the clutch is cold.
This is not only a Toyota problem, I've also had it with a Feroza, but to a lesser degree.
In the past, I thought that it was common for a vehicle fitted with a "Heavy Duty Clutch" to have this problem, because of the larger springs in the plate, and the higher clamping pressures. If you have ever driven a car with a "SOLID" Centre clutch, you would know what I mean. (It's either on or off, there's no slipping)
Another reason as said in the previous post, is that the flywheel and, or pressure plate could have spots that are "Work Hardened" or "Glazed" by a combination of heat and metal composition. This is also a fairly common problem with Disc and Drum brakes. Ever had shuddering brakes.....I have. Bead blasting the flywheel is a quick fix, but machining or replacement is a better permanent option.
Also, if oil is finding it's way into the clutch or onto the flywheel, it could cause a similar problem, usually if the rear main seal, or even the gearbox front seal is leaking.
Hope this helps
Chaz
http://members.bettanet.net.au/~conody/index.htm
AnswerID: 90746
Reply By: Member - 'Lucy' - Thursday, Dec 30, 2004 at 18:22
100 series
Take no notice of Roachie.
The blood is still rushing to his head after making the cover of 4WD monthly.
You can determine which head I am talking about, however I am guessing its going to take at least a year before the blood pressure comes down and he talks sense again. LMAO.
It also may have been a hot day on the peninsula today and given him a conniption, causing verbal crapola re Nissans.
Who knows as he is normally very FAIR and JUST in his comparisons between the Royalty of 4WD's (Toyotas) and those from the dark side (Nissans). (That will keep the blood pressure up for sure).
AnswerID: 90771
Follow Up By: Des Lexic - Thursday, Dec 30, 2004 at 21:40
Ken, please excuse our poor friend as from where he comes from, nothing exciting ever happens and he needs something to keep himself amused. It's either picking on me or foreclosing on some poor customer of his and I'd rather he pick on me than someone else.
Have a happy new year and I hope the Cherokee turns up in 2005.
FollowupID: 349347
Follow Up By: 100 Series - Thursday, Dec 30, 2004 at 23:16
No notice taken.
oth makers have their pros and cons and it comes down to pesonal choice, or whats available at the time of purchase.
There would have to be more posts on here about problem Nissans than Toyotas.
At least Toyota are going to fix the problem for no cost to me(even though they admit the problem may return)
FollowupID: 349373
Reply By: Member - 'Lucy' - Thursday, Dec 30, 2004 at 23:44
Look at Moi! , look at Moi! 100 series.
Now repeat after me.
I will have the Toyota man at least look at the flywheel aspect when he replaces the clutch and discuss with me the pros & cons of hard spots on the flywheel.
This may be the answer to it NOT COMMING BACK.
Have a good one and the best of British luck to you.
Ken Robinson.
AnswerID: 90818
Reply By: Bilbo - Friday, Dec 31, 2004 at 00:58
My Diesel 100 series Cruiser shudders too! Crap gear change as well.
I have to agree with Roachie - gimme a Nissan driveline BUT with a Toyota 100 series diesel motor.
I currently own both a GQ Nissan and a Toyota LC.
The Nissan clutch shudders a bit - but it's done 245,000 kms & it's had hell knocked out of it offroad. The Cruiser has done 85,000 kms and has only ever seen dirt when it took the rubbish trailer to the local rubbish tip. It made it back though ;)
Bilbo
AnswerID: 90822
